#1 | ||
![]() Drives: 2017 Camaro SS 50th Edition Join Date: Jul 2017
RPM Cam and Heads Upgrade
If anyone is thinking about getting a heads and cam upgrade I just got the heads and cam package from Race Proven Motorsports done to my 2017 50th Anniversary Edition. I'm waiting to see the final dyno numbers on Monday and pick it up Tuesday. Hoping Fran can work his Dyno Voodoo and see some decent overall gains. The dyno numbers are usually a lot higher on a (M6). My car has ans (A8) and just doesn't seem to throw down to get the dyno numbers as well as the (M6)s I've seen. I've attached a video they made of it cranking up. It has a Kooks full exhaust system. I had the headers treated and coated by JetHot Performance Coatings. I will post the final gains once it's all finished up.
I put the MSD intake and K&N Blackhawk series air filter no tune on the car before taking it in. This car baselined with the MSD and K&N at around 387 rwhp and 402 wrtq. https://www.facebook.com/RaceProvenM...1357994249754/ Last edited by mauldin44; 10-15-2017 at 08:26 AM. |
![]() Drives: 16 Summit white, Ceramic white 2SS Join Date: Jan 2016
HAHAHAHAAH that white 6gen Camaro in the video is mine
Also doing cam package but i'm m6. Cant wait! How long did it take them to get your together?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS Join Date: Jul 2016
The A8's are only 10-15rw behind the M6's from what I have seen. I don't think it was the MSD that hurt your numbers. I am willing to bet that the K/N's MAF transfer function is all jacked up and that is what hurt your numbers. I would have Fran tune it first if you really want to know what their H/C package is worth.
Didn't the 1LE they posted about put down like 444/463rw stock on that dyno? Trust me, your car in basic trim shouldn't be that far off unless they are dynoing A8's in 5th. Then you will see a significant difference. My car usually puts down 23-25rw more in 6th than 5th on the dyno. 6th is the 1:1 gear. Look for the gains a package gives you, not the total numbers. All dyno's are different. That is why base line testing is so critical. Good luck with the package. I am sure they will do a good job.
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS & 2017 1SS Join Date: Apr 2011
OP: Did you do a Converter?
2011 Chevrolet Camaro 2SS/RS L99 (1 of 782)
10.78 @125mph ALL MOTOR SBE Built/Tuned by Me 2017 Chevrolet Camaro 1SS Auto 9.29 @144.57mph ALL MOTOR SBE #TEAMGPI Gwatney Performance Innovation |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS Join Date: Aug 2016
The low-altitude dyno test I've seen of an MSD out-of-the-box slapped onto a stock motor without tuning showed a small gain in peak hp (maybe 7hp) but the torque was less. This test was done by Tim quite a while ago. With your new cam very likely being happiest above 5000rpm though, this manifold will probably work decent in that range.
#6 | |
#7 |
#8 |
The average is about a week or two. Mine took a little longer because of some unforeseen supply chain delays and the dyno went down for a couple of days.
#9 |
![]() Drives: 2017 Camaro 1SS A8 Join Date: Jan 2017
RPM's dyno reads low or something. My Rotofab Dry with Prays Ported TB/IM dynoed 399.6 whp... couldn't give me that extra .4.
#10 |
#11 | |
I've read a couple of articles that the MSD didn't really come alive until the car was tuned as well. |
#12 | |
#13 |
SABIO
Expecting a number will lead to disappointment.
Just pay attention to where you started and where you end up. Trying to figure out or make excuses Why, What is or the classic would have - should have - could have .... this dyno reads low...etc Is just a waste of time. Don't chase a number because you want to post it here. I had the King of Low Dynos. But the end results are what I like
#14 | |
