Old 10-04-2017, 10:17 PM   #1
Tim202
Drives: 2018 ZL1 1LE
SCCA Autocross and 1LE Tires
Has anyone that is/planning-on competing in SCCA autocross found a good set of nationals legal tires for the 1LE? I have looked some and either tire is too narrow, is for an 18" rim, or just not a competitive tire (i.e. all season).
The SCCA Match Tour rolls through town and I'd like to compete in some legal tires. Maybe even get to Lincoln, but I doubt that.
Tim202 is offline   Reply With Quote
Old 10-04-2017, 11:11 PM   #2
trophy hunter
trophy hunter's Avatar
Drives: 2016 1SS - M6
Hello Tim ....... your question might be better served in the autocross/rr section as there are more SCCA guys chatting in there
I would offer my advice but I'm better versed in F-stock :(
Best of luck !
trophy hunter is offline   Reply With Quote
Old 10-05-2017, 05:38 AM   #3
Chris V
Chris V's Avatar
Drives: 2017 1SS 1LE
We can run the 295/30/20 RE-71R square on the stock rims.
If you take advantage of the +1/-1 rule and downsize to 19x10/19x11 you can run the 305 RE-71Rs.
I'd wait a couple of months to buy tires though - BFG said they were moving the big tires to the 1.5 carcass and adding some bigger diameters, and in time for next year. That will give us more options for sure.
Chris V is offline   Reply With Quote
Old 10-05-2017, 08:27 AM   #4
ICTsccaCamaro
Like Chris said if you want to be competitive at a National level the only tire is the RE-71r
ICTsccaCamaro is offline   Reply With Quote
Old 10-05-2017, 10:05 AM   #5
Tim202
Best of luck !
I appreciate it, but the reason I put it in the ZL1 forum is because that's what I have and I knew I would get answers like Chris V gave which is good for SS 1LE but maybe not for ZL1 1LE. I do thank Chris for his answer though.
I dunno, maybe the 305 71R is still best for ZL1 1LE.
Old 10-05-2017, 12:23 PM   #6
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
You could do 305/30/19 71Rs, but my recommendation would be get a set of 18x11/18x12s and run the the BFGs in 315 & 335. Yes I know you don't really want to change wheels but that would make you the most competitive. I do think the RE71Rs are marginally better grip wise than the BFGs, but 315/335 BFGs vs. 305/305 71Rs is a pretty big difference in contact patch!
IG: @NC_M1SS1LE
Old 10-05-2017, 01:08 PM   #7
Tim202
Interesting, I don't think an 18" rim will fit in the front (Caliper looks like it's almost touching the 19's). Anyone know for sure?
Old 10-05-2017, 05:47 PM   #8
Chris V
Chris V's Avatar
It will, there are people running that setup, though I don’t know the exact specs.
That would be legal for CAM-C, but not for Street Class.
Old 10-05-2017, 08:51 PM   #9
Tim202
1" down is legal for street. So if I can get 18s to fit.....hmmmm
Old 10-06-2017, 08:10 AM   #10
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
I think you will have to get them custom spec'd to fit around the calipers, but they will definitely work!
IG: @NC_M1SS1LE
Old 10-07-2017, 04:45 AM   #11
MoreSpeed
MoreSpeed's Avatar
I have the standard ZL1 but run 19” 285 RE71R’s up front and 19” 305’s in back for AutoX. Slightly different aspect ratios given what Bridgestone provides. I saved 10lbs per wheel/tire combo per side. With the 1LE, you will not save as much unsprung weight but that combo should provide great grip especially with the additional camber that you can get with your car verses mine.
- Life is a highway... I want to ride it all night long...
Sold 2010 997 GT3, 2016 WRX, 2006 997 C2S, 2003 996 C4S, 2001 Boxster S, 1997 E420 AMG
etc..
MoreSpeed is offline   Reply With Quote
Old 10-11-2017, 05:57 PM   #12
lostwon
lostwon's Avatar
Drives: JST FAST
Winner's Woes? Naaa.
Hi, Tim!
Tirerack has now Bridgestone RE-11s in 305 & 325 19s (200TW).
I think at this time, the RE-71 305 19s square on stock rims
might still be the best overall, if not the biggest footprint in the back.
Changing wheels, especially custom sizes, can bring big problem$$$.
Might see all kinds of better tire/wheel combos before the Tour comes around next year, though.....
Don't kill the messenger, but you could get buried in Super Street next year, also. Personally, I'd be happy to see you stay where you are.
See ya Sunday!!
John
lostwon is offline   Reply With Quote
Old 10-11-2017, 06:49 PM   #13
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Originally Posted by lostwon View Post
Hi, Tim!
See ya Sunday!!
John
I agree as the RE-11s are a far cry from the RE71Rs.
