#1 | |
![]() Drives: 2017 1LS White Join Date: Oct 2016
ZZP Tune Before & After
All,
Here is the list of my current mods and Dyno before tune. I sent the stock tune file to Matt at ZZP today, so hopefully next week I'll post the after tune Dyno. Mods: ZZP catless Downpipe ZZP Throttle Body AF Performance CAI MagnaFlow 3" catback exhaust 93 octane Mishimoto's stock pull HP 231 TQ 256 -BN Last edited by Mjollnir; 09-23-2017 at 01:15 AM. |
![]() ![]() ![]() Drives: 2017 Camaro; 2017 Acadia Denali Join Date: Jun 2016
Ok, so you have no tune. Man. It's too early to try to figure out what the heck you're trying to say.
First thing I see is that you're super FATTTTTTT. Your Air/Fuel shouldn't be 10.anything ever. Getting that closer to 12.0-5 will yield a good amount of HP on it's own. Second. Why is your graph going backwards at like 5900RPM? That's weird. Third. You can not compare to someone else's dyno results. It's pointless. It's impossible to duplicate someone else's results due the amount of variables, let alone the biggest variable being that you're using a Dynojet and Mishimoto is using a Dynapack. |
603 Camaros
Drives: 2017 NGM I4 1LT Coupe Join Date: May 2012
Looks like he had his pull in 5th with those numbers Mishimoto did it in 6th Gear. Should be interesting to see what ZZP does.
MY 2017 I4 CAMARO BUILD JOURNAL | YOUTUBE | INSTAGRAM | 316RWHP - 385 RWTQ HPTUNERS DYNO TUNE | 12.693s @ 105MPH 1/4 Mile |
Sorry for the confusion guys. I bolted up these mods in anticipation of having
them tuned together by ZZP. I wanted to know where my numbers were prior to them tuning with these mods installed (264/265 and 263/277). Your right, comparing someone else's test is meaningless and I should not of included it in the original post. BTW the pulls were done in 3rd gear. -BN |
#5 | |
603 Camaros
![]() Drives: Smart Join Date: Mar 2017
You can't really compare your post tune numbers to Mishimoto's stock dyno numbers. One would think the world works that way, with it being SAE certified numbers and atmospheric corrections, etc. But it's not a perfect world by any means.
#7 |
Also, your AFRs looks really rich on your dyno graph
#8 | |
Too bad we will never know what those mods did for him before the tune since no baseline dyno was performed. We can clearly see the mods are causing a very rich condition. Rich enough that I'd recommend pulling the spark plugs and checking them for fouling. I'd wager they are sooty black. Spark plugs should be slightly toasted brownish ceramic white. |
#9 |
Update:
Dyno results after uploading ZZP tune. |
#10 |
![]() Drives: Camaro 2.0t, 300zx TT, LSTT Mustang Join Date: May 2016
Not bad for libtard gas.
#11 |
![]() Drives: 2016 camaro 2.0t gray Join Date: Apr 2017
If u have a friend that's knowledgeable with hptuners look at the tables I bet they didn't touch timing
#12 |
![]() Drives: 2016 Camaro RS I4T Join Date: Jan 2017
#13 |
![]() Drives: 2017 RS Turbo Join Date: Aug 2016
IM going in for my dyno run this evening after my tune. Ill post it for camparison
2017 1LT | RS | 2.0T | M6
331 rwhp , 350 rwtq ZZP Intercooler | ZZP Catted DP | Magnaflow Catback | Injen CAI | Tuned (BBR) | CNC Honed Turbo (TPC) w 14lb actuator |
#14 |
