Old 09-19-2017, 10:50 PM   #1
Daboom48
Drives: 32 Ford 55 Nomad 69 Ve 14 M5 17 ZL1
Racing Seats for ZL1
I am road course tracking my car more and more. It's almost being used for nothing but that. Any ideas on compatible Sparco etc..
Seats that would work well. Thinking I would like to go with 5 point harness. Not sure if that would require roll cage...
Not sure of the difficulty level to pull out factory seat as well...
Just looking for thoughts and any feedback...
Thanks!
Daboom48 is offline   Reply With Quote
Old 09-19-2017, 10:55 PM   #2
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
I was thinking sparco
http://www.sparcousa.com/catalog/vehicle/seats
you would need to use a harness bar if you do not have a roll bar or roll cage.
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 09-19-2017, 11:58 PM   #3
Larrio Andretti
Drives: Really Fast
For a seat I would go with Racetech. https://racetech-usa.com/shop/
Yes... you will need a harness bar at minimum.
Larrio Andretti is offline   Reply With Quote
Old 09-20-2017, 08:24 AM   #4
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
I'd like to purchase anyone's stock ZL1 Recaro seats that decides to go with full-fledged racing seats.
Also, not sure if this helps, but there was one other person that I know of that changed over to a more aggressive racing seat. Here's what they went with:
Recaro Profi Race Seats from Stable Energies with Brey Krause Sliders, Adaptors and Planted Seat Mounts.
Hope that helps
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge
93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno)
LesBaer is offline   Reply With Quote
Old 09-20-2017, 08:31 AM   #5
ICTsccaCamaro
The fact that Chevy ditched the pass through's on the 6th gen Recaro seats blows my mind, I'm literally down grading Recaros going from my 5th gen 1LE to the 6th gen ZL1 1LE, pretty crappy on GM's part on a "track car".
ICTsccaCamaro is offline   Reply With Quote
Old 09-20-2017, 09:09 AM   #6
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Preach!
Old 09-20-2017, 09:16 AM   #7
JeromeS13
Drives: 2017 1SS/1LE
IMO, the OEM seat with the shoulder strap pass-throughs are inviting someone to improperly mount racing harnesses. Those seats are NOT designed for the use of 5/6 point harnesses, as there's no provision for the anti-submarine strap. Routing this strap in front of the seat is improper, unsafe, and is not allowed by most track sanctions. This only leaves a 4-pt option, which I'm only aware of one manufacturer that makes a version that's allowed by SOME sanctions (Schroth).
Old 09-20-2017, 10:03 AM   #8
ICTsccaCamaro
Correct I had a Schroth 4pt in my 5th gen and passed tech inspection for SCCA at a national level multiple times with no issue. But at least with the 5th gen you had the option for a 4pt, your just SOL on a nice looking 4pt install on a 6th gen.
Old 09-20-2017, 02:12 PM   #9
nighttowl
nighttowl's Avatar
These look really nice for the money.
Old 07-26-2021, 10:04 PM   #10
DaffyZL1
Drives: 2019 ZL1 1LE, 1969 Stingray
Originally Posted by ZL1 1LE View Post
Preach!
SAY IT!!
DaffyZL1 is offline   Reply With Quote
Old 07-26-2021, 10:16 PM   #11
Motor Fast
Drives: 2018 Camaro SS 1LE
Same thought here. They did the same thing on the C5 Z06 yet the C5 coupe had the slots for belts.
What wheels do you have on your car in your signature? Thanks.
2002 Camaro SS | 2003 Corvette Z06 | 2008 Corvette | 2012 Corvette ZR1 Inferno Orange with PDE | 2016 Corvette Z06 C7.R | 2018 Yenko Camaro
Motor Fast is offline   Reply With Quote
Old 07-27-2021, 04:24 PM   #12
s.hammer
Drives: 2015 Z/28
Sparco, Cobra, OMP, Recaro, Racetech, are all good options but if you want the most out of a race seat you will want to sit in it to make sure it fits you the way you want. If you have a shop that sells them within a couple of hours drive, it is worth the ride to test what they have. If you have no local shops to test seats, try out anyone's seats that will let you sit in there car at the track. Once you find one you like, get the seat measurements online, and measure to make sure it will fit in the car. The Camaro is a little tight with some of the wide/XL seats. The flair out of the sides at the shoulders will sometimes hit the door. Installing is fairly simple, good luck.
s.hammer is offline   Reply With Quote
Old 07-27-2021, 04:27 PM   #13
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
yup i ended up with a sparco qrt r in my car they are only about 15 minutes away from my house so i went down there on a friday visit the showroom and sat in some seats to help me figure it out! not ready for a halo seat since i still drive the car on the streets but its super comfy!
Old 07-27-2021, 08:16 PM   #14
s.hammer
Drives: 2015 Z/28
Cobra Evolution is a good halo seat for the street if you ever decide to go that route. They have holes in the sides of the halo you can see through.
