Old 08-20-2017, 08:55 PM   #1
BIGG_FRANCO
BIGG_FRANCO's Avatar
Drives: 2017 camaro
Usb stop working
Any ideas how to fix? Was working fine night before now dosent recognize iPhone plug
BIGG_FRANCO is offline   Reply With Quote
Old 08-20-2017, 09:04 PM   #2
turbojeep95
turbojeep95's Avatar
Drives: 17 Camaro lt, 22 Camaro LT1
Try asking over in the audio and video section. You'll have a broader audience to answer your question.
turbojeep95 is offline   Reply With Quote
Old 08-20-2017, 09:05 PM   #3
Raph
Raph's Avatar
Drives: Camaro 2.0t
Unplug and shut your car completely off works for me
Raph is offline   Reply With Quote
Old 08-21-2017, 12:04 AM   #4
BIGG_FRANCO
Drives: 2017 camaro
I disconnected negative cable on battery for a hour reconnected and screen was blank, then I pulled fuse display and radio came back on and still no luck with USB then powered car on for a bit then off and my link Froze again with no sound
. any ideas?
Old 08-21-2017, 08:00 AM   #5
whiskeyfed
Pat
whiskeyfed's Avatar
Drives: 2017 Camaro 1LT I4 Turbo A8
. any ideas?
Head over to the electronics section brotha
Follow me on Instagram @whiskeyfed
Subscribe on YouTube Whiskeyfed Camaro
Follow my Build Thread The WhiskeyFed Camaro
Current Modifications: JacFab Boost-O-Lator, Injen Evolution CAI, ZZP Catless Downpipe, RPM 3" Charge Pipe, Mishimoto Oil Filtration/Coolant Systems, R1 Concepts Brakes Package, Eibach Pro-Kit Lowering Springs, PTP Lava Exhaust Wrap & Turbo Blanket
DYNO SHEET: 297whp / 374wtq
Tuned by #danytechtuning
whiskeyfed is offline   Reply With Quote
Old 08-21-2017, 09:19 AM   #6
BIGG_FRANCO
Drives: 2017 camaro
Any links to it I'm on my phone can't figure it out..thanks man
Old 08-21-2017, 09:21 AM   #7
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
This Is a known software glitch from early on. I don't think it's been corrected. The USBs can come and go , it has nothing to do with your cord or anything else. If you disconnected your battery and reconnected it , that's all you can do , the next move is take it to the dealership.
The reason to disconnect the negative is to pull all the current out of the car much like you turn off your computer and turn it back on to reset it. Like "Ctrl-alt delete". Unfortunately the car still holds some current, it takes A bit of time for the capacitors to drain, so the longer you leave it off the better off you are..e.g. Disconnect before you go to bed , and reconnect when you get back up in the morning. Techs have a faster way to drain, they pull off both battery cables, then touching them together. That drains the car instantly.
Old 08-21-2017, 10:21 AM   #8
BIGG_FRANCO
Drives: 2017 camaro
Ok I'll try that I'll leave it off for the night..when I reconnect it do I try it right away or let it sit for a bit? Also I can only get to the negative side of battery and not positive. I really don't want the dealership to touch it
Old 08-21-2017, 10:26 AM   #9
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Let it sit for 5 minutes after you reconnect it up. When you go to start it, it will not start, it'll interrupt the start. like the battery is dead. try a second time and the car will start. All your settings will stay, except the HUD vertical position and door indexing. The driver display will tell you what to do to correct the door indexing.
Disclaimer: it may or may not fix it. It might be in your dash. This is just the universal reset method.
Old 08-21-2017, 10:52 AM   #10
BIGG_FRANCO
Drives: 2017 camaro
One last shot before I take it in
Old 08-22-2017, 10:11 AM   #11
BIGG_FRANCO
Drives: 2017 camaro
Well I unplugged the negative all day and night and still no usb.. Not sure if it rained radio settings were still there,also had me correct windows but car started up first try. There's a circle head phone like jack between the two USB anyone know what that is???
Old 08-22-2017, 10:38 AM   #12
whiskeyfed
Pat
whiskeyfed's Avatar
Aux cord input
Old 08-22-2017, 08:29 PM   #13
BIGG_FRANCO
Drives: 2017 camaro
Aux cord input
Thanks man
