08-19-2017, 09:10 PM | #1 |
Drives: ZL1/335i Join Date: Apr 2014
M6 bogging issue resolved on 2018s?
I'm getting ready to order my ZL1 in the next few days. Have the launch issues on the M6 cars been eliminated on the '18 models? I'm concerned with both the issue where the car loses power when trying to gently take off from a stop, and the issue where the car bogs (basically falls on it's face) when trying an aggressive launch. I'm guessing the latter is just torque management to protect the drivetrain, but makes for some lousy 1/4 mile times.
As much as I'd like a manual, these issues are pushing me toward the A10. Looking for some input from 2018 owners first. Thanks |
08-19-2017, 09:15 PM | #2 |
Drives: 2017 Camaro ZL1 M6 pdr roof CF blk Join Date: Mar 2017
the manual is awesome, get a Maimo ported throttle body (5 min diy)
its not as bad as it sounds in forum also becomes much less noticeable with TC off in tour to competitive mode in sport or in the other fancy traction modes in track |
08-19-2017, 09:19 PM | #3 |
Drives: Pre-production ZL1 M6 Join Date: Feb 2016
On that 17’s it’s as bad as it sounds in the forum. WAY noticible bog and cut to power.
08-19-2017, 09:27 PM | #4 |
11-12-2018, 03:59 AM | #5 |
Drives: Wd1ss Join Date: Nov 2016
Just picked up my 2018 zl1 m6 still in break in period about 325 miles,, can’t wait to get it to the track, but running out of time from winter setting in. If the track is still open in December I’ll post some times and see how the launches go..until then break in time blows
11-12-2018, 07:49 AM | #6 | |
11-12-2018, 09:10 AM | #7 |
Wow...I posted this over a year ago. I believe the answer is that nothing changed with the ‘18 models. I ended up ordering a 2018 A10 that I took delivery of in September of last year. No regrets.
11-12-2018, 09:37 AM | #8 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
Well, since Al's answer to the question was that we don't know how to drive a manual, I wouldn't expect anything to change.
11-12-2018, 10:13 AM | #9 |
No change in the 2018’s
It's been fun, done with GM.
2018 Camaro ZL1 (SOLD) - Blown Airbags 2017 Camaro SS F1FTY Member Journal (SOLD) - Bad Motor |
11-13-2018, 03:20 AM | #10 |
1.7,s is gonna be hard, I have experience with older manual cars at the track. I pulled 1.85,s usually but took a lot of practice..I just work to damn much to get out there and street launches are now where near the same thing, I think upping this gear ratio to say .410 or 456 would do this car wonders, the auto would pry go 10.5 on drag radials! Ha thanx for that tip on launch’s and just pedal the car down didn’t even think of that
11-15-2018, 11:25 PM | #11 |
Drives: ZL1 1LE A10 Join Date: Mar 2015
I had this exact same issue on my 2017 Corvette Z06.
Installing the Tony Mamo Throttle body did drastically change the feel. Stock there was a "bog" W/ Tony Mamo's Throttle Body it was tack sharp to the point that even the slightest foot twitch would cause the car to kick. I honestly would have preferred something in between. The "Bogging" described is really over exaggerated IMO. Sure it's true its annoying and for a 70k car it should be flawless so I get the complaint, but its not the end of the world. You learn to sort of pre-blip the throttle before a "normal" take off. If someone is complaining about bogging on hard launches, they're just not giving it enough gas (again IMO). Others' mileage may vary.
Current: 2019 ZL1 1LE A10 Mods: MPS4s Tires | Borla Atak | CF Steering Wheel Previous: 2018 ZL1 1LE M6 | 2017 Z06 Z07 M7 | 2017 GS A8 | 2015 ZL1 M6 | 2013 GT500 |
11-16-2018, 05:00 AM | #12 |
Drives: 17 ZL1 Join Date: Mar 2017
The manual is awesome and my prefrence. The boging issue for normal driving has been over blown. If your into drag racing the auto is the way to go, no question about that.
2017 ZL1 Coupe M6, Red Hot
Mods; AFE Pro 5R CAI, Kong Ported Blower and Snout, NW 103 TB, Griptech 2.31 Upper, Kooks 2",JMS Voltage Booster, Flex Fuel, Mighty Mouse CC,Jannetty Racing Tune, 680 rwhp |
11-24-2018, 01:21 PM | #13 |
Drives: 2018 A8 ZO6 black rose metallic Join Date: Nov 2018
Has the Mamo throttle body been a good fix for the m6 bog
11-24-2018, 05:08 PM | #14 |
Drives: . Join Date: Jan 2013
