Old 08-06-2017, 10:03 PM   #1
Epx998
|Engineer|
Epx998's Avatar
Drives: 2016 Camaro SS
AGP Twinturbo ..?
They made a TT kit right? I don't see it on their website, never went into production?
Epx998 is offline   Reply With Quote
Old 08-06-2017, 10:05 PM   #2
Epx998
|Engineer|
Epx998's Avatar
Nevermind I just saw an AGP post from Feb, they never made a kit for it - just custom stuff.
Old 08-06-2017, 10:41 PM   #3
hitmix300
2016 loaded 2SS
hitmix300's Avatar
Drives: Maverick X3 Turbo R
i heard huron speed is working on a kit right now from a friend.
hitmix300 is offline   Reply With Quote
Old 08-06-2017, 10:51 PM   #4
Robbs1le
Robbs1le's Avatar
Drives: 2017 zl1. Headers intake pulley e
Wonder why no one is producing a kit?
Robbs1le is offline   Reply With Quote
Old 08-06-2017, 10:56 PM   #5
parish8
Drives: 17 SS a8
Agp made and sold about 10 kits. I helped install one. It is pretty nice but not factory like nice like some of the blower kits.
Call them. I am pretty sure they will make more, it is what they do.
Old 08-07-2017, 08:46 PM   #6
Goertz
Goertz's Avatar
Drives: 2016 1SS Auto
My engine is almost finished being built and back in the car.
Then it is break in time and big power tuning around the end of the month is on the charts
416 stroker build, tsp ultra ibeams with diamond coated pistons, full headstuds main studs, valve train, cam with 32% overdrive (zl1 pump in tank)
direct port and direct injected, roughly 1600whp worth of fuel combined (about 750whp worth of 93 on di system and 800whp worth of fuel on direct port e85 system)
Goal is 1200whp or so on true pump gas and still get 30mpg due to keeping 93 oct in the main tank
Goertz is offline   Reply With Quote
Old 08-07-2017, 09:27 PM   #7
laynlo15
Drives: 2022 Lt1 A10
This is bad news for the rest of us. Goertz is on the move again.
Old 08-07-2017, 11:04 PM   #8
PackersFan26
PackersFan26's Avatar
Drives: 2017 Summit White 2SS
Love your build and have been watching your progress! But for most of us, this kind of setup won't be feasible financially. Any plans in the works for a 650-700hp capable kit without needing to go all crazy?
PackersFan26 is offline   Reply With Quote
Old 08-08-2017, 12:02 AM   #9
ninetres
ninetres's Avatar
Drives: Crush ZLE M6 | 2000 Corvette FRC
Very interesting WG plumbing. Never seen them coming off the housing quite like that....unless I'm seeing it wrong.
ninetres is offline   Reply With Quote
Old 08-08-2017, 10:29 AM   #10
Goertz
Goertz's Avatar
LMAO
I'm not that scary am I?
I'll still be on stock axels and drive shaft for a bit. Need to enjoy the car for a bit before I track it and break it again haha
Honestly I don't ever plan to turn it into a track car so it will only ever be a footbrake car. Just enough power to go fast.
Old 08-08-2017, 11:03 AM   #11
Goertz
Goertz's Avatar
Yeah
Can skip the Intercooled intake mani and go non bb turbo and that gets it down substantial
Old 08-08-2017, 12:14 PM   #12
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
What compression ratio pistons are you using? It might be tough to get 1200 on pump gas without knock. Your work is beautiful though. So is the hood cut out from a previous design or am I missing something?
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 08-08-2017, 02:14 PM   #13
Goertz
Goertz's Avatar
I have another hood new in box to go on my car
Pistons are 10.5:1
It will come to about a e50 mix at 1000hp and anything past that will be greater% of e.
Old 08-16-2017, 11:06 AM   #14
jessrayo
Speed Freak
jessrayo's Avatar
Pistons are 10.5:1
I just went with lower compression pistons but if you have access to ethanol that works.
I must say, those custom headers are a work of art. Other kits I have seen with the turbos up in the engine bay use a stock exhaust manifold and then wrap the exhaust back up to the top. That custom header makes the turbo location as efficient as the bottom mount and then they are protected. I assume you are going to wrap everything with the heat tape and that should eliminate all engine bay heat problems. I've got some experience with turbos and I must say this is a very good looking system. I've got no experience in manufacturing but if you can maintain the quality and put these kits out in any kind of volume I think you have got a winner.
