Old 07-25-2017, 06:14 PM   #1
Wolfiethefox
Wolfiethefox's Avatar
Drives: 6th Gen 2Lt Rs
3M Vinyl Accent Mod Underneath Front Headlights
So I've started to see the trend of putting black accents underneath the front headlights on 6th gens more and more on social media but I was wondering if it'd look just as good if it were a different colored accent? I've been thinking of doing those same accents but in red to match the color scheme I have going on for my car. I will note that I have full length rally stripes which is why I'd like to get some honest feedback before I attempt getting this done. Bottom Camaro is owned by @TopHatPlus on instagram.
Instagram: wolfiethefoxx_
Wolfiethefox is offline   Reply With Quote
Old 07-26-2017, 12:35 PM   #2
RayJay75
Z/LS
RayJay75's Avatar
Drives: 2017 MikaRay Z/LS
love your rs awesome look love the work you have done to it
IG: blu_zls
RayJay75 is offline   Reply With Quote
Old 07-26-2017, 12:37 PM   #3
RayJay75
Z/LS
RayJay75's Avatar
adding red accents under rs eyes may be to much got to see it first
IG: blu_zls
Old 07-26-2017, 01:10 PM   #4
Oramac2016
Oramac2016's Avatar
Drives: 2016 Camaro RS
Cheap mod. Id say try it and see how it looks. If it doesn't look as good as you thought it would, peel it off. I think it may look nice.
2016 Summit White 1LT RS, Brembo Brakes, NPP Exhaust,Front Glowtie, Rear Red Glowtie, Adrenaline Red Interior
Oramac2016 is offline   Reply With Quote
Old 07-26-2017, 06:38 PM   #5
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
Agreed. Less than $30 easily for the vinyl and some knifeless tape. If you hate it, trash it!
I bought two 10'x1' rolls, I needed both because I messed up the first time around
Install tip, I found using the squeegee difficult in such a small space with many curves, I used my thumb to slowly roll it flat with good results
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 07-26-2017, 06:47 PM   #6
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
I like the black. It reminds me of the 3rd gen and pre-refresh 4th gen. I like the throwback.
Eric SS is offline   Reply With Quote
Old 07-26-2017, 07:09 PM   #7
MGD
MGD's Avatar
Drives: 16 Camaro SS
Stripes
If you do it, do it right and follow the original strip design. Here is a mock-up how it should look.
Interior: Adrenaline Red. SS/2SS, M6, NPP, Sun Roof, 8" Nav. Black 5 Spoke Wheels.
MGD is offline   Reply With Quote
Old 07-26-2017, 11:10 PM   #8
Wolfiethefox
Thanks for the input guys, gonna order some vinyl and see how it turns out. I'll post the results after I finished
Old 07-26-2017, 11:12 PM   #9
Wolfiethefox
Thank you, I appreciate it
Old 07-27-2017, 04:35 AM   #10
Dubchitts
Dubchitts's Avatar
It took me a minute to figure out what you meant, but I agree. Only go as far as the rally stripes and round the edges to match. I don't have them, so mine was a little easier.
But then again op has custom stripes, in which case I would go to the lines on the bumper like mine
"Spitfire" 427ci
Old 07-27-2017, 09:57 AM   #11
SSTony
SSTony's Avatar
Drives: SS Camaro
Send a message via AIM to SSTony
On the bottom bumper how far did you bring the tape up going up on the bumper by the grill? I don't see a place on mine to for a good spot to stop[
QUOTE=MGD;9836788]If you do it, do it right and follow the original strip design. Here is a mock-up how it should look.[/QUOTE]
SSTony is offline   Reply With Quote
Old 07-27-2017, 10:43 AM   #12
Mighunter
Drives: 2017 Summit White 2SS
I have a summit white and I would really like to do some black pieces on the lower part of the front bumper (like the pic of the red car above that looks to have black carbon fiber).
Should I just get some from Amazon? What brand do people recommend? Also toying with doing the roof in black but i'm not sure I'm skilled enough to deal with the antenna.
Maybe I should just have someone do it! LOL
Mighunter is offline   Reply With Quote
Old 07-27-2017, 11:55 AM   #13
BrianL
BrianL's Avatar
Drives: 2016 2SS, Red Hot, NPP, Nav, M6
I really like seeing the black accent below the grill area. Headlights i'm on the fence still. Maybe too "busy" for me, but I can appreciate what all are doing to customize their rides. Anybody have a template?
BrianL is offline   Reply With Quote
Old 07-27-2017, 12:11 PM   #14
Mighunter
BTW to the OP, i would not do anymore than what you have. I think it would be too much IMO. I'm not even sure I like the black under the headlights on the red car, but the black on the lower grill looks sick!
accent, opinions, rs camaro, wrap
