Old 06-25-2017, 09:26 PM   #1
cooden
cooden's Avatar
Drives: '16 Camaro 2SS & '15 Durango R/T
The amazing sound from Whipple, Corsa, ARH & Roto-Fab.
I was at a charity cruise-in today and when leaving, my buddy got a pretty good video of my '16 SS leaving the event. These beautiful sounds are the result of the Whipple, Corsa Xtreme, ARH 1-7/8" Long Tube Headers and Roto-Fab Cold Air Intake. Car is putting 570hp and 596tq to the rear wheels.
'16 2SS: Summit White/Adrenaline Red/A8/Whipple Supercharger/ARH Longtube Headers/Corsa Xtreme Exhaust/Roto-Fab Cold Air Intake/Eibach Pro Kit/M228 Wheels/Lots of GM Accessories
cooden is offline   Reply With Quote
Old 06-25-2017, 10:21 PM   #2
Razor2SS
Drives: 2017 1SS
Sounds great!!
Razor2SS is offline   Reply With Quote
Old 06-25-2017, 11:36 PM   #3
Epx998
|Engineer|
Epx998's Avatar
Drives: 2016 Camaro SS
I have a summit white A8 as well, I think you built out exactly what I am looking to do to mine here in calif.
Epx998 is offline   Reply With Quote
Old 06-26-2017, 12:42 PM   #4
marknagy13
Markoon13
marknagy13's Avatar
Drives: Camaro 2SS
Sounds nice! Can't hear the whipple though.
marknagy13 is offline   Reply With Quote
Old 06-26-2017, 01:04 PM   #5
Stryfe
Make America Fast Again
Stryfe's Avatar
Drives: 2016 HBM 1SS - M6
Why does it seem like supercharger whine is so much more apparent on mustangs? Is it just me?
Stryfe is offline   Reply With Quote
Old 06-26-2017, 03:32 PM   #6
marknagy13
Markoon13
marknagy13's Avatar
Drives: Camaro 2SS
I'm guessing because it's because they have a smaller engine and typically have more PSI boost so the charger spins up faster? Just a guess.
Old 06-26-2017, 05:49 PM   #7
MGD
MGD's Avatar
Drives: 16 Camaro SS
You need to read up on superchargers. They are belt driven. Go from there.
Interior: Adrenaline Red. SS/2SS, M6, NPP, Sun Roof, 8" Nav. Black 5 Spoke Wheels.
MGD is offline   Reply With Quote
Old 06-26-2017, 07:05 PM   #8
marknagy13
Markoon13
marknagy13's Avatar
Drives: Camaro 2SS
I think you need to read up. They have different gearing and pullies to allow for higher RPMs and boost levels lol
Old 06-26-2017, 08:23 PM   #9
MGD
MGD's Avatar
Gearing doesn't matter at all, as the lob shafts are 1:1.
different pulleys changes the gear ratio from the crankshaft to the super charger. smaller pulley, faster rotation, more boost. Spin-up time, the same as it is directly linked to the crank shaft.
Old 06-27-2017, 09:57 PM   #10
MGD
MGD's Avatar
Let's see it...was your sowing successful?
Old 06-28-2017, 09:21 AM   #11
DiGiam
DiGiam's Avatar
Drives: 2016 NFG SS A8
the amount of supercharger whine is usually related to the superchargers efficiency. Like the 03 04 cobra. It had an eaton M112 and was horribly inefficient so it whined a lot from the factory and really screamed with a smaller pulley. This new whipple is probably very efficient and you wont hear much whine until you can really pulley it down and get it spinning.
2016 NFG 1SS A8. Pray ported intake manifold, Rotofab dry cai, kooks 2" catted longtubes, E85,
DiGiam is offline   Reply With Quote
Old 07-03-2017, 10:42 PM   #12
Oil Man
Oil Man's Avatar
Drives: 2016 2SS, 2018 ZL1 A10 (RIPx2)
Most of the reason for supercharger whine is air friction across the vanes. The harder you thrash on it, the more friction/noise/heat you create. They all run necessarily tight tolerances, but some run tighter tolerances and larger volumes than others.
Depending on the drive system, and whether the belt uses cogs and straight-cut gears, there could be noise made there too. When GMC roots blowers were common in hot rodding, some would drill relief holes in the grooves of the blower drive pulley to allow compressed air to escape and not add to the noise.
Oil Man is offline   Reply With Quote
Old 07-03-2017, 11:04 PM   #13
Snowblind
Snowblind's Avatar
Sounds healthy
Record that sweet sound and make it your ringtone, I did something similiar and now I don't answer the phone half the time.
Old 07-04-2017, 11:39 AM   #14
KILLA BEE
Black lightning
KILLA BEE's Avatar
Drives: 2021 ZL1 1LE A10
Whatever for all the iother shit, YOUR CAR SOUNDS GREATTTT. PERIOD
[ 2021 Camaro ZLE 10 speed
KILLA BEE is offline   Reply With Quote
