Old 06-22-2017, 07:44 AM   #1
MR 45TH
MR 45TH's Avatar
Drives: 2018 ZL1
This may be to hot.
Whatcha think
2018 ZL1…Many mods to come
MR 45TH is offline   Reply With Quote
Old 06-22-2017, 08:00 AM   #2
locktyght
locktyght's Avatar
Drives: 2023 LT2 Redline
Originally Posted by MR 45TH View Post
Whatcha think
Only a tad, most tunes like to keep it around 62,500 or so.
2015 1LE sold
2016 2SS sold
2023 LT2 Redline
locktyght is offline   Reply With Quote
Old 06-22-2017, 08:29 AM   #3
ProCharger
Drives: Many C7's
Some of these gauges have been scanning the wrong PID's off the OBD2 data.
(obviously there is no IAT2 for these cars)
I saw one the other day that said "IAT"
But it was actually reading the Trans Temp...and labeling it IAT
(when I double checked the data with another device that allows me to read the raw data off the CAN)
So the guy was like "My IAT is 203 degrees"....
I was like... well actually your trans is 203 degrees.... your IAT is 78. LOL.
So make sure everything jives on these new cars.
Each model sometimes the CAN data addresses change, yet the gauges/monitors don't always know that.
ProCharger is offline   Reply With Quote
Old 06-22-2017, 08:41 AM   #4
MR 45TH
MR 45TH's Avatar
Drives: 2018 ZL1
Yeah I'm not sure what is going on. But the IAT will show that temp as well, which is throwing a CEL and causing the fans to go nuts!. When I put my handheld scanner on it this is what comes up, P0097, P0102, P2199
Old 06-22-2017, 08:49 AM   #5
ProCharger
Drives: Many C7's
Well IAT2 isn't a Valid can address on these cars. Since there is no IAT sensor.
However, make 100% sure your MAF harness doesn't have a pin that got pushed out of the harness. (basically, push on all the wires, and make sure they are fully seated)
I have heard of them backing out, when the extension harness is plugged in.
Old 06-22-2017, 07:28 PM   #6
MR 45TH
MR 45TH's Avatar
Drives: 2018 ZL1
Found a few issues.
Pulled out pins on the MAF extension cable
And a cracked MAF sensor. No idea how this happened. It does sit close to the fan shroud but not touching. Maybe under hard acceleration it moved enough to hit it.
Old 06-23-2017, 09:23 AM   #7
ProCharger
Drives: Many C7's
If you trim the end of the silicon tube (by the throttle body) about 1/4 of an inch.
It won't touch anything near the fan.
Some cars are a little different then others.
So we left that tube just a tiny tiny bit long just in case.
(if it was to short it would rub on the bracket)
That pin can just be slid back into place until it clicks in.
Then you will be good to go.
Old 06-23-2017, 09:43 AM   #8
MR 45TH
MR 45TH's Avatar
Drives: 2018 ZL1
Yeah I trimmed about a 1/4 inch off, may need a touch more. I just don't want to end up on the other end and rub the belt tensioner .
Would I be better off running the metal tube like what comes in the race kits?
Old 06-23-2017, 09:47 AM   #9
ProCharger
Drives: Many C7's
I wouldn't....
It's even bigger so you will spend more time trimming it to get it "just right" to fit without hitting anything.
Plus you don't get the insulation effect of the silicon,
AND your tune would have to be totally redone for the new MAF location.
The silicon tube is awesome, and its what I would run on my personal car.
