Old 06-17-2017, 05:23 AM   #1
Arex
Arex's Avatar
Drives: 2016 NFG 2SS
Stock 2SS with NPP Rattle
Hey guys, I tried to search Camaro6 for rattle, and found some regarding the butterfly valves and rattle at idle.
However, my issue is rattle during medium to hard acceleration (WOT), sounds like it comes from rear exhaust/passenger side only. A very loud rattle during hard acceleration, especially after making a left.
Any ideas? take it to dealer?
2016 NFG 2SS NPP MRC
2015 GTI (totaled)
Arex is offline   Reply With Quote
Old 06-17-2017, 06:20 AM   #2
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
Problem many have had. Including me.
There is a fix, They glue the valve. Awesome isn't it.
Fix worked on mine for 4 or months. Rattles again.
If it is rattling now....it will rattle on idle eventually.
Dealer should know of bulletin.
Old 06-17-2017, 08:14 AM   #3
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
I live with mine! I pulled the fuse anyway so the valves are open all the time and it's set in track mode for the exhaust. The rattle does stop when the engine idles down though.
Old 06-17-2017, 08:26 AM   #4
LT4Greg
LT4Greg's Avatar
Yes by all means take it to the dealer because there may be something loose under the car and let them check it over.
Old 06-17-2017, 01:05 PM   #5
marknagy13
Markoon13
marknagy13's Avatar
Drives: Camaro 2SS
could be the exhaust hangar or mount. check those too for rubbing anywhere
marknagy13 is offline   Reply With Quote
Old 06-17-2017, 03:18 PM   #6
MAGAUSA
MAGAUSA's Avatar
Drives: 2017 Hyper Blue 1LE
I could hear my rattle under load as well as idle. They superglued it. I'm expecting it to return.
MAGAUSA is offline   Reply With Quote
Old 06-18-2017, 02:44 AM   #7
Arex
Arex's Avatar
oh no... =/
Alright, thank you guys for the information. Superglue? what the hell... maybe just demand a new exhaust if rattle comes back after they "superglue" it.
2015 GTI (totaled)
Old 06-18-2017, 06:00 AM   #8
bseiter98
Yep, they "glued" mine too but it didn't fix it. Next, they replaced the entire exhaust, problem solved...
bseiter98 is offline   Reply With Quote
Old 06-21-2017, 03:03 AM   #9
Arex
Arex's Avatar
I wasn't able to replicate the rattle today, did about 15 hard accelerations.
2015 GTI (totaled)
Old 06-29-2017, 12:27 PM   #10
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
Has anyone found a permanent fix for this beside pulling the fuse? I had the TSB done and my rattle came back about 2 months later. I use my stealth mode when backing in the garage and on early morning start ups. I would love for this problem to get fixed correctly!
Old 06-29-2017, 02:54 PM   #11
Davis0079
Drives: 2016 1LT V6
took my NPP in to the dealer at 10k miles. They said not only was the valves rattling, but the resinators broke loose. Gave me a completly new exhaust. $2800 warrenty work.
Davis0079 is offline   Reply With Quote
