Old 06-11-2017, 04:20 PM   #1
gilgamesh
Drives: 2015 Charger SRT Hellcat(732rwhp)
Ported tbody issue
No names, I'm not trying to start a bash.
I just tried installing a ported tbody on my Z and it IMMEDIATLY popped codes about the "throttle body sensor bank high and low " and the car ran like complete shit, and struggled to idle.
I checked everything and then rei stalled the stock system. Car ran fine. Rei stalled the after market--- same issue. And back and forth two more times to make sure I didn't mess up the install SOMEHOW.
Anyone have any ideas before I send it back?
UPDATE!!!!!!
So I will let you know the company in question is Katech. The reason being is that they have been outstanding with fixing the situation. When I called and reported the issue, one of their techs called me back immediately and let me know they had had a bad batch go out and overnight ed me a new, tested one, no questions asked.
Mistakes happen....customer service like this is what keeps us coming back in spite of it. Highly recommend them.
Drive-ability wise...I noticed an IMMEDIATE change in throttle response and smoothness of power delivery. To anyone that is thinking about doing either a CAI or Tbody mod I HIGHLY recommend them both. Completely changes the feel of the car.
Rides-
2015 Hellcat Charger-732rwhp/708rwtq
2017 ZL1 6M- Rotofab CAI, Katech ported Tbody
gilgamesh is offline   Reply With Quote
Old 06-11-2017, 04:30 PM   #2
Dethsupp0rt
Drives: None
Sounds like a bad sensor rather than anything to do with the actual porting work.
Maybe check the connection where the plug goes in and ensure there's no debris or anything in there that would prevent a good connection with the plug.
I'm sure whoever you got it from will take it back if it's defective.
Dethsupp0rt is offline   Reply With Quote
Old 06-11-2017, 04:47 PM   #3
Send it back and simply don't do this mod. At least you didn't send back the original for core yet.
Old 06-11-2017, 04:50 PM   #4
Originally Posted by 13vertss/r's View Post
Put you old one back in and see if it keeps doing it. If not, then TB. If it does, bad connection or sensor.
That's what he has done 3 or 4 times already.
Old 06-11-2017, 05:03 PM   #5
13vertss
13vertss's Avatar
Drives: 2013 Camaro convertible 2SS/RS
That's what happens when you read most but not all the post.
13vertss is offline   Reply With Quote
Old 06-11-2017, 05:25 PM   #6
USP45
Drives: 2017 ZL1 A10
Try installing the new one and removing the negative terminal for about 10 minutes. I know if you unplug the MAF while there is still power to the car that the ecu will pop codes..... Just a thought.
USP45 is offline   Reply With Quote
Old 06-11-2017, 08:36 PM   #7
TheRedhead
TheRedhead's Avatar
Drives: 2018 Red Hot ZL1 1LE
How much power is the ported body genuinely going to add?
TheRedhead is offline   Reply With Quote
Old 06-11-2017, 09:01 PM   #8
BSR-1
BSR-1's Avatar
Drives: 17 ZL1 M6 Black
http://www.camaro6.com/forums/showthread.php?t=497065
BSR-1 is offline   Reply With Quote
Old 06-11-2017, 09:02 PM   #9
gilgamesh
Seems like the aftermarket one was over ported and is making shit go crazy at idle. I even tried swapping electronics between them to rule that out. Le sigh. Guess it goes back.
Rides-
Old 06-11-2017, 09:05 PM   #10
TheRedhead
TheRedhead's Avatar
Originally Posted by BSR-1 View Post
Much obliged.
Old 06-12-2017, 08:44 AM   #11
soceur77
Drives: 17 NFG ZL1 17 GTR 22 RS6
ummm i think you should name the company so buyers can be in the know, both companies that I know of selling the ported TB have both had good reviews, so one negative experience shouldn't matter, but lets potential buyers be aware. This is what the forums is about.
soceur77 is offline   Reply With Quote
Old 06-12-2017, 09:18 AM   #12
Dethsupp0rt
Drives: None
I'm just curious what the issue is, as I'm on the fence about getting one. Going to do the CAI first, then maybe the TB.
Do you have pictures of the one that is causing the issues?
Old 06-12-2017, 09:28 AM   #13
IneedAZ
IneedAZ's Avatar
look at above link and u will see which brand it is
Old 06-12-2017, 10:17 AM   #14
soceur77
Thanks!! I was silently hoping it wasn that one as I ordered last week, time will tell if this was a one of issue or what...
