Old 06-07-2017, 03:13 PM   #1
NicD
Drives: Camaro
Accurate weight scale of the ZL1 A10
I have some digital race weight scales that are pretty accurate so I figured I would get an actual weight of the ZL1 instead of looking around online at specs, etc. Now my ZL1 has the 10 speed auto with the sunroof, other than that it's totally stock with no other options. I had just a tick over an 1/8th of a tank of fuel.
A bit heavier than I would like but overall it doesn't feel like it's pushing around that much weight which is pretty amazing in itself.
19 ZR1 | 16 Viper GT | 09 Z06 | 94 LS1 GT | 16 Denali | 19 CTS
http://www.gonicd.com
NicD is offline   Reply With Quote
Old 06-07-2017, 03:14 PM   #2
NicD
Drives: Camaro
And for comparison my C7 Z06 with the A8, stage 1 aero, PDR, and standard iron brakes. Totally stock, same fuel level at just a tick over an 1/8th of a tank.
Old 06-07-2017, 03:21 PM   #3
Dethsupp0rt
Drives: None
That looks about right. Someone else recently weighed one and it was a tick over 3900 (probably had more fuel).
I was worried about the weight, coming from an M3 which was nearly 400 lbs. less. The chassis is so good though, it doesn't really feel like it's nearly 2 tons.
Dethsupp0rt is offline   Reply With Quote
Old 06-07-2017, 04:33 PM   #4
Dwille
Drives: 2022 SS 1LE
Thanks for posting these. That is great information, and its useful to see a direct comparison to the C7 Z06.
Dwille is offline   Reply With Quote
Old 06-07-2017, 05:19 PM   #5
Tex
Texas Military Forces
Tex's Avatar
Drives: 2017 ZL1 Red Hot Auto
Awesome I have the same options but also the PDR. I don't understand the weights listed on the door jam.
2017 Red Hot ZL1 Automatic (Sunroof, PDR & NAV)
2/10/2017 status: ordered
2/23/2017 status: 3100 TPW 3/6/2017
3/06/2017 status: 3400 TPW 3/6/2017
3/10/2017 built 4200 VIN# 1G1FK1R65H0193462
3/18/2017 Delivered to me!
2016 Camaro 2SS (wife's car)
M228 Black Wheels
2010 Camaro SS (totalled by son)
Tex is offline   Reply With Quote
Old 06-07-2017, 05:38 PM   #6
7WSM
7WSM's Avatar
Drives: 2017 ZL1 A10
Weighed my A10, no sunroof, 1/2 tank of gas last month when I was at the track and it weighed 3905 without driver. Probably get it under 3900 if I would have taken all my shooting gear out of the trunk including the heavy rubber trunk mat. Front was 2120lbs and rear was 1785lbs over the axles.
7WSM is offline   Reply With Quote
Old 06-07-2017, 05:49 PM   #7
Ron_Robinson1
Ron_Robinson1's Avatar
Drives: A Static line to a pack tray & ZL1
Send a message via AIM to Ron_Robinson1
My Z needs a diet
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4)
SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129
SOLD-2011 SS M6: Blower, Cam, Alky, LTs.
Ron_Robinson1 is offline   Reply With Quote
Old 06-07-2017, 07:10 PM   #8
Blown355
Blown355's Avatar
My 2017 ZL1 with sunroof and 1/2 tank of gas.
3905 lbs.
2017 ZL1
A10
Redhot with stripe
Blown355 is offline   Reply With Quote
Old 06-07-2017, 07:20 PM   #9
unavailablezl1
unavailablezl1's Avatar
Drives: 2019 Silverado Z71 6.2L A10
You should take those 3 cases of beer out of the trunk too.
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's.
Past Rides
2017 M6 Camaro ZL1 Hyper Blue
2016 M6 GT350 White with blue strips
2014 M6 Mustang GT Premium Track Pack Ruby Red
2012 M6 M3 Melbourne Red Metallic
unavailablezl1 is offline   Reply With Quote
Old 06-07-2017, 07:47 PM   #10
ssrallyred
ssrallyred's Avatar
Drives: 2017 Summit White ZL1 M6
The weight on the door is gross weight. Its basically the limit of the car itself, the total weight of driver plus 3 passengers in this case and cargo.
ssrallyred is offline   Reply With Quote
Old 06-07-2017, 08:21 PM   #11
edc901
edc901's Avatar
Drives: 2017 ZL1
How much extra does the sunroof way? Would it be safe to say non-roof A10 cars are much closer to 3800?
2017 Camaro ZL1
Hyper Blue - A10
edc901 is offline   Reply With Quote
Old 06-07-2017, 11:12 PM   #12
laynlo15
Drives: 2022 Lt1 A10
Where is the difference, maybe the rear suspension is heavier, brakes maybe. I my 1ss is down to 3640 with a 2300 magnuson and slicks and skinnies with full interior and 1/4 tank and just ran 10.78@129 in 92 degree heat and 3650 DA. That means that with the drag pack its about 3783 which is way lighter then the 15 Zl1
Old 06-08-2017, 08:14 AM   #13
Tex
Tex's Avatar
Dang! No wonder it was so high, thanks.
M228 Black Wheels
Old 06-08-2017, 01:38 PM   #14
NicD
Drives: Camaro
Looking around online it looks like most people who have taken out sunroofs on other vehicles similar in size have weighed them anywhere between 20-30 lbs.
