Old 05-26-2017, 10:31 AM   #1
pwells18
Drives: 2017 zl1 conv 6 sp- '18 trackhawk
Pulling the exhaust fuse
I was looking for more sound...(music to me)- not ready to do full exhaust or CAI (K&n is actually out of stock on it for zl1)-
chatted with a few members in the forum here..one of whom suggested I pull the fuse...(i keep it in track mode, so i didnt think it would matter)- well..
wow...wife drove off this am as i listened from the driveway..and wow..not so sure its louder under full throttle(i dont see how it could be) but when she let off the throttle...full blown blurp, blurp, crackle..crackle..
i suggest anyone looking for a little more music, do this bigly.
thanks again to those that assisted with the decision
-now if only somebody could help me put some pics up on here, of the beast.
pwells18 is offline   Reply With Quote
Old 05-26-2017, 12:46 PM   #2
Blown355
Blown355's Avatar
Drives: 2017 ZL1 A10
Doesn't being in track mode also stiffen up the steering?
2017 ZL1
A10
Redhot with stripe
Blown355 is offline   Reply With Quote
Old 05-26-2017, 01:29 PM   #3
pwells18
lol..not sure...i think so...havent taken it out of track mode in 2 weeks )
Old 05-26-2017, 03:47 PM   #4
Blown355
Blown355's Avatar
Awesome!
2017 ZL1
A10
Redhot with stripe
Old 05-26-2017, 04:00 PM   #5
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
Was this the first time you've heard the car from the outside, especially when cold? Likely that's what you are hearing, not the fuse. The only time the fuse pull comes into effect in track mode is at steady state cruising speed/rpm.
seanblurr is offline   Reply With Quote
Old 05-26-2017, 08:29 PM   #6
pwells18
yes...1st time ive heard it cold....from the outside..
and..."buzzkill" :(
Old 05-26-2017, 09:47 PM   #7
BSR-1
BSR-1's Avatar
Drives: 17 ZL1 M6 Black
Drive mode, Steering feel and exhaust sound are all controlled separately.
I felt the steering was rather high effort when I first got it so I tried the other modes. Aside from making it easier to turn it also adds in play in the system. I had to put it back into Track mode, I just can't stand that much play in the steering, even in Sport mode.
BSR-1 is offline   Reply With Quote
Old 05-26-2017, 10:11 PM   #8
BluinSC
Drives: BVM 1SS
If you have MRC and NPP you can do them all separately.
For myself if have
Steering-Sport
Suspension- Tour
Exhaust Track
BluinSC is offline   Reply With Quote
Old 05-27-2017, 07:36 PM   #9
BSR-1
BSR-1's Avatar
Question:
I can't be the only one to notice that the two outside tips (with the valves) are the only ones that are used. The two inside tips are clean and cool after parking while the outside two are hot and sooty.
Are the two of them just for looks?
Old 05-27-2017, 08:18 PM   #10
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
inner two are used when the valves are shut, outer two are also used when the valves are open (obviously most of the exhaust wants to go to the path of least resistance - the outer two).
Old 05-27-2017, 08:30 PM   #11
BSR-1
BSR-1's Avatar
So, if I put it in stealth mode (valves mostly closed) and drive around for a while the inner tips will blacken too? I mean there is a serious difference, like the inner two are never in use.
Old 05-29-2017, 10:07 AM   #12
pwells18
i keep it in track mode, all the time..has never been in sport, etc..and i have to clean all 4 pipes...comes right off with paper towel..hate to throw out a rag every other day
Old 05-29-2017, 11:02 AM   #13
KLR ZL1
H-Town Camaro Club Member
KLR ZL1's Avatar
Drives: 17 Hyper Blue Metallic KLR-ZL1
For myself if have
Steering-Sport
Suspension- Tour
Exhaust Track
This. Why do a fuse pull when you can customize it in the infotainment system. That was the only way to do it in the 5G ZL1. Hence the Mild to Wild switch you could add except this time Chevy did it for us.
KLR ZL1 is offline   Reply With Quote
Old 05-29-2017, 11:23 AM   #14
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Because you can't customize the exhaust in the display. Even in track it shuts down the valves at interstate speed.
