Old 05-18-2017, 04:31 PM   #1
Blast2hell
Drives: 2020 ZLE Rally Green A10
Holy Brake Dust Batman!
Wow, do these things put out some brake dust?! I wash my car and the next day I see brake dust all over the rims. Talk to me about what to do to prevent this? I know...more gas pedal, less brake pedal. What else can I do?
2020 Rally Green ZLE A10
(SOLD)2017 NGM ZL1 A10 Built 3/31
Sebring Best Lap Time 2:29 Video
Roebling Road Best Lap Time 1:25 Video
Blast2hell is offline   Reply With Quote
Old 05-18-2017, 04:33 PM   #2
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Install powerstop pads, nothing else but new pads works to stop dust generation.
Old 05-18-2017, 05:42 PM   #3
FLYNNZL1
Drives: Man
Send a message via ICQ to FLYNNZL1 Send a message via AIM to FLYNNZL1 Send a message via MSN to FLYNNZL1 Send a message via Yahoo to FLYNNZL1 Send a message via Skype™ to FLYNNZL1
Does anyone have the Powerstop part numbers for the 2017 ZL1?
FLYNNZL1 is offline   Reply With Quote
Old 05-18-2017, 06:04 PM   #4
MR 45TH
MR 45TH's Avatar
Drives: 2018 ZL1
One of the best mods!
2018 ZL1…Many mods to come
MR 45TH is offline   Reply With Quote
Old 05-18-2017, 06:27 PM   #5
Infern0
Bring It
Infern0's Avatar
Drives: In Between
Links!?
2017 Camaro ZL1 M6 - Everything but the sunroof - Sold
2010 Camaro SS - 650RWHP Daily Driver - Traded
Infern0 is offline   Reply With Quote
Old 05-18-2017, 06:35 PM   #6
pkincy
pkincy's Avatar
Drives: 2016 Corvette Z06, 2018 ATS-V
Powerstop, Hawk or Carbotech carbon ceramic pads all will lower the dusting over stock pads 80+%.
Perry
16 SharkGrey A8 Corvette Z06
18 Cadillac A8 ATS-V
pkincy is offline   Reply With Quote
Old 05-18-2017, 07:44 PM   #7
Bow Tie Affair
Drives: 6th. Gen ZL1
The only aftermarket brakes for the 2017 ZL-1 is from Racing Brakes and it is a complete CCB replacement kit. There are not front any aftermarket pads that will fit the 2017 ZL-1 that i can find. I believe the rear pads are the same as the C7 Z06.
Bow Tie Affair is offline   Reply With Quote
Old 05-18-2017, 08:22 PM   #8
pkincy
pkincy's Avatar
You are correct. I have emailed Carbotech to see if they plan on having the 1521s for the front axle anytime soon and Powerstop so far only makes Ceramic brake pads up to the Brembo 6 pistons on the 2SS.
Perry
Old 05-18-2017, 08:52 PM   #9
Evolvedx27
Evolvedx27's Avatar
Drives: 2017 ZL1
Is this your first performance car?
Evolvedx27 is offline   Reply With Quote
Old 05-18-2017, 09:28 PM   #10
unavailablezl1
unavailablezl1's Avatar
Drives: 2019 Silverado Z71 6.2L A10
Don't drive it. HaHa. Or sell it to me. Just take the thing to the car wash when the brakes are cold and power wash them They will squeak no more. Eventually they will slow down the dust. The rotors are new and rough.
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's.
Past Rides
2017 M6 Camaro ZL1 Hyper Blue
2016 M6 GT350 White with blue strips
2014 M6 Mustang GT Premium Track Pack Ruby Red
2012 M6 M3 Melbourne Red Metallic
unavailablezl1 is offline   Reply With Quote
Old 05-19-2017, 06:12 PM   #11
pkincy
pkincy's Avatar
My Carbotech guy says the 1521 is available for the ZL1. Do check out what he says with the front/rear pad numbers in case he is thinking of the 1LE or 2SS with Brembos. But here is what he said.
F::CT1405 1521 $267
R:CT1718 1521 $173
I use them on my Z06 and the braking is fine (not for the track however) and the dust is down about 80-90%. I was having to clean my wheels daily and it is now about once/2 weeks. A lot of the Y body guys swear by the Powerstops as they are way less costly.
If Adam is right about the pads these are the same pads as the 2015-2017 Z06 pads so would be readily available. But somebody needs to check the pad part numbers. I cannot find the ZL1 pad part numbers on any GM site or aftermarket site at this time.
Edit: Just chatted with Adam. He said GM got smart this time around and is using the same calipers front and rear on the ZL1 and the Z06, so your choices in pads are huge both for low dusting street pads in carbon ceramic and good race and track pads from the good manufacturers.
Perry
Old 05-19-2017, 07:53 PM   #12
Infern0
Bring It
Infern0's Avatar
Drives: In Between
Wow...some pricey pads.
Old 05-20-2017, 07:27 AM   #13
Rlhay2
Rlhay2's Avatar
Drives: 2017 ZL1
High performance, high reliability, affordability...you only get two.
Rlhay2 is offline   Reply With Quote
Old 05-21-2017, 06:54 AM   #14
sengli
sengli's Avatar
Drives: 2015commemorative vert 2SS
When I had my C6 it was the same thing. Even just tooling around produced so much brake dust that I was forever cleaning the chromed wheels. I had the black wheels on my Gen5 car, and it helped a lot because you couldnt see the brake dust quite so easily.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded
2015 commemorative vert 2ss
sengli is offline   Reply With Quote
