Old 05-17-2017, 04:08 PM   #1
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
SS vs. Corvette break in
1500 miles for he SS and 500 miles for the Corvette. What gives?
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
zx9rmal is offline   Reply With Quote
Old 05-17-2017, 04:23 PM   #2
Artos
Artos's Avatar
Drives: A10 LT4
Vette has beak in oil & some sort of assembly lube that can cause it to foam...thus the 500mi oil change requirement. Besides that, they are somewhat similar in the recommended break in procedure. Mr. W had a post on it not too far back.
Artos is offline   Reply With Quote
Old 05-17-2017, 04:29 PM   #3
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
The vette has no break in oil, been discussed many times on vette site. It's Good old dexos 1 that should be changed at 500 due to oil mixed with sealants than can cause foaming at high rpm in dry sump systems.
But still no reason I know why theirs is 500 and ours is 1500. I'm still a tech editor there.....I'll check.
Old 05-17-2017, 04:57 PM   #4
Artos
Artos's Avatar
Drives: A10 LT4
Wish I could find that post...I recall the 500mi was tied to the oil, but overall the break in suggestions were pretty close. Sorry if I'm off on this.
I think he pulled them from the manual...I didn't pay too much attn because I don't have a vette & only focused on my own 1500.
Old 05-17-2017, 05:12 PM   #5
iPODFAN11
iPODFAN11's Avatar
Drives: 2019 Shock ZL1
Tied to the oil sure, but more specifically the degredation of the oil's anti foaming properties If I could link the PDF I googled I would, but search g_0000205212 and the first link that pops up is the PDF via CorvetteForum.com Below is the guts from that PDF:
To: Chevrolet, Buick, GMC, and Cadillac Dealers
2014/2015 Z51 and Z06 Corvettes – Additional Required Maintenance
The following message only applies to dry sump Corvettes that have not had their first oil change performed.
Some 2014/2015 Z51 and Z06 Corvettes may experience a condition that leads to oil leaking out from the air cleaner assembly. This
condition may be caused by running the engine continuously at a high engine speed with the first factory fill oil, resulting in silicone
sealants in the engine’s gaskets degrading the oil’s anti-foaming agents. The oil foam has no effect on the engine’s durability.
Effective Immediately:
GM is changing the required maintenance schedule for all 2014/2015 Z51 and Z06 Corvettes equipped with dry sump systems. The new
schedule will require the oil/filter be changed immediately after the break-in period, which occurs after the first 500 miles of operation.
Once the break-in oil change is performed and the Oil Life Monitoring system is reset, customers should follow the Oil Life Monitoring
system for all future oil change needs.
From Super Chevy mag, April 2002: "Most of the weekend Settlemeire was meeting and greeting and quickly became known as simply "The Camaro Dude" (note, even his initials are SS)."
Originally Posted by fbodfather View Post
we're certainly looking at it -- but right now, the emphasis MUST be on getting the Camaro V6 and SS out -- and having it exceed your expectations....
Once that's done....................
iPODFAN11 is offline   Reply With Quote
Old 05-17-2017, 05:13 PM   #6
TripleB
SoCal Mayhem
TripleB's Avatar
Drives: 2017 2LT Hyper Blue Metallic Camaro
Looking at my Corvette manual, it says the dry sump system in the Z51 package and Z06 needs the break-in oil change at 500 miles.
TripleB is offline   Reply With Quote
Old 05-17-2017, 05:28 PM   #7
SS376
SS376's Avatar
Drives: 2013 1SS LS3
Break-in isn't just for motors. Differential and transmission differences between Camaro and Corvette might account for the difference.
SS376 is offline   Reply With Quote
Old 05-17-2017, 05:56 PM   #8
Bigdog9586
Drives: 2016 Z06 coupe
Manual Vettes writhing dry slump got 500 extra paid oil change. My non dry slump auto Vette did not. Of course 14/15 Vettes also got 4 free oil changes or 5 with dry slump. 16's cut it back to 2 or 3 and all Z06's had dry even with auto so got the extra.
Bigdog9586 is offline   Reply With Quote
Old 05-17-2017, 05:59 PM   #9
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
Thanks for the replies. I'd just like to know specifically why WE need 1,000 more miles for actual break-in.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
Old 05-18-2017, 02:01 PM   #10
iPODFAN11
iPODFAN11's Avatar
The 1500mi applies to both the Corvette and the Camaro in terms of vehicle break in (RPM limiting, speed limiting, etc.). The 500mi oil deal on the dry sump Vettes is a separate deal from the 1500mi vehicle break in.
Old 05-18-2017, 02:13 PM   #11
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Nope...there is a diff...the vette is 500 miles below 4000 rpm, the Camaro is 1500...damned if I know why it's diff...maybe ask at the next camarofest event?
The vette owners manual:
The Camaro owners manual:
Old 05-18-2017, 02:17 PM   #12
iPODFAN11
iPODFAN11's Avatar
I wouldn't be surprised if they changed that after adding the dry sump break in however. I'll try to find a first publish 2014 book and see there. They both use the same engines LT! wise...
Old 05-18-2017, 02:19 PM   #13
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
No change in the books from 14 thru 17 on the vette....still 500.....the pics I posted are the 17 vette book and the 16 Camaro book.
Vette Books here:
https://www.corvetteforum.com/forums...cking-etc.html
Old 05-18-2017, 07:10 PM   #14
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
Thanks Glen. The mystery continues.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
