Old 05-09-2017, 12:58 PM   #1
unavailablezl1
unavailablezl1's Avatar
Drives: 2019 Silverado Z71 6.2L A10
ZL1 Undercarriage and jack points
I just got back from the dealer and they let me look at my car. I was interested where they jack up the ZL1. I took a bunch of pics. Kinda kool.
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's.
Past Rides
2017 M6 Camaro ZL1 Hyper Blue
2016 M6 GT350 White with blue strips
2014 M6 Mustang GT Premium Track Pack Ruby Red
2012 M6 M3 Melbourne Red Metallic
unavailablezl1 is offline   Reply With Quote
Old 05-09-2017, 01:40 PM   #2
Toons
Speed Racer
Toons's Avatar
Drives: 2017 ZL1
Funny, I just did the same thing yesterday. Did you notice the squeezed pipe reduction in the exhaust behind the brackets in your last pic? Has been a topic in other threads.
Toons is offline   Reply With Quote
Old 05-09-2017, 02:35 PM   #3
unavailablezl1
I do see the squeezed pipe. But it is fatter so the volume should be the same. Good eye
Current ride
Past Rides
Old 05-10-2017, 06:27 PM   #4
MoreSpeed
MoreSpeed's Avatar
They look like they jacked it up at the wrong points.
There are numerous threads in the Camaro6 non ZL1 forum. Here is one. http://www.camaro6.com/forums/showthread.php?t=433703
One had a video that specifically said that that back area is not designed to hold the weight of the car.
- Life is a highway... I want to ride it all night long...
Sold 2010 997 GT3, 2016 WRX, 2006 997 C2S, 2003 996 C4S, 2001 Boxster S, 1997 E420 AMG
etc..
MoreSpeed is offline   Reply With Quote
Old 05-10-2017, 10:06 PM   #5
TJay74
Bad thing is in the front, those large holes are where the jacking plate pins should go. It is where the factory carrier probably carried the car. If they took the plate off of their arm the pin would go right into the front holes.
Old 05-10-2017, 10:49 PM   #6
unavailablezl1
It looks like where he jacked it up is a pretty strong place. Let's hope that is his training as to where to. The large holes looks like the body and might crush, but ok for tie downs.
Current ride
Past Rides
Old 05-11-2017, 12:55 AM   #7
camaro5
camaro5's Avatar
Drives: X-15 Velocipede
+1
Great pics, all showing INCORRECT lifting points.
Good news is he was lucky enough to not crush the rockers (barely cleared the lift arm), and more.
Those giant slots in the rockers are to lift at the welded seam.
Put a set of these on and instruct service advisor to add note on warranty ticket.
https://zl1addons.com/collections/ja...nt=32532756929
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 05-11-2017, 07:56 AM   #8
unavailablezl1
Originally Posted by camaro5 View Post
+1
I think those jack points are for consumers as always as to where someone uses a scissor jack. If you look close, he was never close to the rockers. The place where he jacked it is the same area as where consumers are to place jack stands.
Current ride
Past Rides
Old 05-11-2017, 09:12 AM   #9
unavailablezl1
Well, if my car is screwed up, then they will have to fix it.
Current ride
Past Rides
Old 05-11-2017, 10:44 AM   #10
unavailablezl1
I just took it back to the dealer to show the Service Manager what a dumbass you have working for and check it for "square"
Current ride
Past Rides
Old 05-11-2017, 11:08 AM   #11
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
Yeah, I don't like the looks of those front points at all. The aluminum may seem strong but it is not made to carry the wright of the car. He should have used the pinch welds as mentioned above.
Eric SS is offline   Reply With Quote
Old 05-11-2017, 11:14 AM   #12
unavailablezl1
I might get lucky this time, but I want it documented that this was done wrong. I see that the aluminum frame is also part of the motor mounts. It could screw that up. Son of a bitch.
Wouldn't you know, the 2nd time in my life I get a free dealer oil change and both times they phuked it up. The last time was Honda 10 years ago.
Just now we put it up on the lift(drive on) and nothing looks bent at all. I went and looked at the other ZL1 on the showroom and it looks the same. So we shall see today at 3:30 when the body shop checks it out.
Current ride
Past Rides
Old 05-11-2017, 11:28 AM   #13
tateintx
tateintx's Avatar
Drives: 2019 Satin Steel ZL1
Hmmmmmm.... Classic? I have an appointment tomorrow morning with them for my first oil change.
tateintx is offline   Reply With Quote
Old 05-11-2017, 11:57 AM   #14
unavailablezl1
It will be OK. I got with the Service Manager (Joe Laubhan who is the top guy there) and I drove it on the lift and we both looked at it and it looks fine. Since it was a 4 point lift, not just jacking the whole car on one point, there is a good chance it is ok. But nevertheless, Joe said he will make sure this never happens again. But, the body shop is going to look at my car just to be safe and check it for correctness. If it is off, they will replace the cross-member.
Current ride
Past Rides
