Old 04-28-2017, 04:23 PM   #1
Michigan1LTRS
Blessed ❤️
Michigan1LTRS's Avatar
Drives: 2017 1LT RS I4
Throttle body charge pipe, anything special about install?
Received my RPM throttle body charge pipe today. For those of you who have installed this do you have any words of wisdom or anything I should be careful about before I install this. Looks pretty straight forward, but you know how that can can go. The stock pipe connection at the throttle body looks like a ring connector. Does that just turn one way or the other and how far? Thanks for any advice you can give me!
Old 04-28-2017, 05:31 PM   #2
rickwelch69
rickwelch69's Avatar
Drives: 2016 1LT RS Turbo 4
it turns to the left (counter clock-wise) after the install you should start the car and let run for 1/2 a minute or so (until it idles down) maybe 3 or 4 times for the ecu to learn the new TB
2016 2.0 RS::K&N drop-in filter::RPM Catless down pipe::RPM Tune::Mishimoto Hot&Cold side charge pipes::65ish mm throttle body::289rwhp/328lbft
rickwelch69 is offline   Reply With Quote
Old 04-28-2017, 07:47 PM   #3
psykostevo
Drives: Smart
Assuming that you got the Larger Throttle Body and not JUST the pipe, do what Rick said. It helps the ECU learn the throttle body position. And avoid opening and closing the throttle body manually, as that can mess up the motor inside the TB.
psykostevo is offline   Reply With Quote
Old 04-28-2017, 08:26 PM   #4
Michigan1LTRS
Blessed ❤️
Sorry guys, my title is a bit ambiguous. I am only installing the intake charge pipe.
Old 04-28-2017, 09:08 PM   #5
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
You'll get a momentary CEL from disconnecting the MAP that will go away mine went away on the first dyno pull right after it was installed.
Old 04-28-2017, 09:42 PM   #6
Michigan1LTRS
Blessed ❤️
Ok thanks! I'll remember that.
Old 04-29-2017, 08:51 AM   #7
Corner carver
Corner carver's Avatar
Drives: 2017 Camaro 2.0T RS
I love the support, Camaro6 rocks! Good luck with the install Michigan1LTRS!
As Delivered: 2017 Mosaic Black 1LT RS 2.0T | M6 | HD brake and cooling | Bose & 8"screen | Front lip extension | Blade spolier | Black bowties | Painted splash guards
Installed Mods: 25% Window tint | Headlight, side marker and third brake light Phastek tint kit | GM black taillights with Gen5diy LED harness and bulbs | LED license plate bulbs | Gorilla lug nuts, black | GM 'performance' center caps | RS and sheild badges removed
Old 04-29-2017, 07:43 PM   #8
Beast-Y-Blue
Drives: Hyper Blue 2016 Camaro turbo
question? I just ordered my half pipe from RPM. I ve already received my 67mm throttle body. anyway is the rpm half pipe bigger in diameter than the stock?
Beast-Y-Blue is offline   Reply With Quote
Old 04-29-2017, 07:51 PM   #9
Michigan1LTRS
Blessed ❤️
When you order the pipe there is a box you have to check. Stock throttle body 59mm or upgraded 68mm. So I assume pipes are different.
Old 04-29-2017, 07:52 PM   #10
Michigan1LTRS
Blessed ❤️
Thanks CC! My first chance to install it will be Monday.
Old 05-03-2017, 11:23 AM   #11
Corner carver
Any luck?
Old 05-03-2017, 11:28 AM   #12
Michigan1LTRS
Blessed ❤️
Any luck?
Nope, my Grandkids came over Monday. For sure Saturday. I'll post up pics.
Old 05-03-2017, 11:58 AM   #13
Corner carver
Nice, family first!
Old 05-03-2017, 04:17 PM   #14
Beast-Y-Blue
I'm trying to install the charge pipe and throttle body... but I can't not remove the dawn pipe... question when turning it counter click wise, how far do I turn the pipe... do I need to remove any radiator hose. Does the pipe turn loosely but didn't come off. Am I not turning it enough? This is fustrating... any help appreciated
