Old 04-26-2017, 08:13 AM   #1
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Cheapest ramps for oil changes to clear splitter?
So I am coming up on my first oil change in a few hundred miles and I was wondering what ramps you guys were using? My Rhino ramps aren't even close to clearing my splitter, and I really don't want to rig anything up. Are Race Ramps my only choice? If so, what ones exactly? Best place to buy them from? I am far from cheap, but damn...$250 for plastic ramps lol?!
Thanks 1LE brothers.
Old 04-26-2017, 08:51 AM   #2
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
I thought the same too, but I relented and got the 2 piece set of race ramps for my ZL1. I bought mine thru Amazon. There is a 1 piece RR-56 and 2 piece RR-56-2. The 2 piece is more expensive than the 1 piece. I used them last weekend and had no issues getting the ZL1 up to do the oil change.
nancygrl is offline   Reply With Quote
Old 04-26-2017, 08:52 AM   #3
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
I actually got my rhino ramps to work, but I cheated by using the slight incline on my driveway and the raised lip of my garage slab. You might could accomplish the same thing by laying a piece of wood in front of the ramp to get those first few inches of clearance.
Old 04-26-2017, 09:27 AM   #4
FoCoCamaro
FoCoCamaro's Avatar
Drives: 2017 1SS 1LE (Krypton Green)
I ordered the 72" 2-piece Race Ramps for mine and like you, I wasn't keen on dropping that much cash on a set of ramps. At the end of the day I figured I've never heard of a set of Race Ramps failing (thus not killing my while I'm under the car), they work really well for what they are designed for, will clear the lip on a lowered car, and are light weight.
I figured as soon as I actually use them it will be money well spent.
FoCoCamaro is offline   Reply With Quote
Old 04-26-2017, 10:38 AM   #5
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Thanks guys, are the one and two piece the same dimension wise, just one comes apart for easier storage?
Old 04-26-2017, 10:57 AM   #6
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
I'm going to be "that" guy for a second, but it's really not hard to jack the car up. And you'd save all that money
seanblurr is offline   Reply With Quote
Old 04-26-2017, 11:10 AM   #7
AZ_1LE
Drives: 2019 ZL1 1LE
^^ Yea, I just jack the car up on one side to get enough clearance.
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is offline   Reply With Quote
Old 04-26-2017, 11:20 AM   #8
Bow Tie Affair
Drives: 6th. Gen ZL1
They are the same dimensions. They are two pieces so you can remove the rear section to gain more access from the side of the car.
Bow Tie Affair is offline   Reply With Quote
Old 04-26-2017, 11:49 AM   #9
davef
Drives: 2017 SS 1LE Garnet Red
Either jack it up or do the 2 pieces of wood trick shown above. $250 is pretty salty.
davef is offline   Reply With Quote
Old 04-26-2017, 11:56 AM   #10
FlowForm_Wheels
FlowForm_Wheels's Avatar
Drives: Turbo 4, SC V8 and Twin Turbo V8
Just go old school and jack the car up, place it on jack stands and get to work. Seems like the best option here if you want to save cash (assuming you already have a floor jack and jack stands).
FlowForm_Wheels is offline   Reply With Quote
Old 04-26-2017, 12:14 PM   #11
Sub
Sub's Avatar
Drives: 2017 ZL1
Rhino worked for my ss ok (are your cars lower?). I actually had the rear up on wood too - drove up at same time. Pretty easy... took a couple tries - sort of have to commit when going up! I recommend a spotter If your front ramps are sliding, put a rubber mat or thin carpet remnant under the ramps. I attached a piece of rubber floor treads under my wooden ones so they didnt slip - you can just see the little rubber strips in front of the wood ramps.
BTW, check your rhino ramps for stress cracks occasionally (I'm on my second set). I still use jack stands loosely placed under the frame rails in case they fail. A guy at my work had a lift failure and it messed him up pretty bad getting crushed! I dont take any risks under my car - horrible way to die.
My Car Blog and mods. Previous Chevys: 2016 2ss, 2015 C7 z51, 2004 C5 Z06
Sub is offline   Reply With Quote
Old 04-26-2017, 12:25 PM   #12
Tomiboy
Drives: 2017 Hyper Blue 1LE
Do you have a front splitter like the 1LE?
Tomiboy is offline   Reply With Quote
Old 04-26-2017, 12:38 PM   #13
Rockmonstir
Rockmonstir's Avatar
Drives: 2017 Camaro SS 1LE
^^^This
I pick things up then put them back down.
Rockmonstir is offline   Reply With Quote
Old 04-26-2017, 01:01 PM   #14
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Thanks guys for all the input. I would rather go this route than use my jack and stands. Just fast and easy to drive up, and down. No worries about jacking points and such either...
