Old 04-17-2017, 06:06 PM   #1
Canadian ZL1
Canadian ZL1's Avatar
Drives: 2017 ZL1, 1995 Trans Am
First oil change...I upgraded the oil to fully synthetic Mobil 1 5W30
So I just had my first oil change today as I was nearing my 1000 Km's. I actually took it in at 928 Km's. With that said they were going to use the dex semi synthetic oil BUT I opted to upgrade to the full Mobil 1 synthetic 5W30. What's funny is my first 4 oil changes are free BUT I have to pay the difference to move to the fully synthetic stuff. What I don't understand is why the car wouldn't call for 100% synthetic?
I think the next time I go for an oil change I will pay more to get the Mobil 1 15W50 oil. This oil is meant for supercharged engines. Anyone have any thoughts on this? I'd be curious to know what the Z06 calls for oil type?
_____________________
'17 ZL1 HBM|A10|NAV|PDR|CFW Hood|Sunroof
Canadian ZL1 is offline   Reply With Quote
Old 04-17-2017, 06:56 PM   #2
ZL1Goals
Drives: 2006 Vw Gti Apr Stg 2
the lt4 does not call for 15w50 stick to what is on the cap as the recommended oil
ZL1Goals is offline   Reply With Quote
Old 04-17-2017, 06:58 PM   #3
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
I used to run 15W50 Mobil 1 in my performance cars down here in Phoenix where it gets very hot but up in Toronto I don't really see a need to run that thick of oil. If anything, I would switch to the Dexos 2 oil that GM recommends for track use.
Eric SS is offline   Reply With Quote
Old 04-17-2017, 07:02 PM   #4
Zeke.Malvo
Zeke.Malvo's Avatar
Drives: 1969 Mustang MaCh1
Mobil 1 doesn't make a 100% true full synthetic. It's not bad oil, but not a true synthetic.
Sent from my SGH-M919 using Tapatalk
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtq
T56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear
Zeke.Malvo is offline   Reply With Quote
Old 04-17-2017, 07:06 PM   #5
ZL1black
ZL1Black
Drives: 2017 ZL1 1973 Camaro Audi A8L 4.0
I changed the oil and filter at 500 with Castro Edge Synthetic. Currently at 1600 miles and plan to change again some time this week. I realize GM offers a couple of free oil changes; however, I prefer to do it myself.
If you are in the Houston area and wish to do it your self, let me know. You are welcome to use my lift.
ZL1black is offline   Reply With Quote
Old 04-17-2017, 07:09 PM   #6
Canadian ZL1
Yeah good point about it not being that hot in TO and so wouldn't need the thicker oil. I'll look at the Dexo2 oil when I hit the track.
Old 04-17-2017, 07:11 PM   #7
Wish I was down near you. Lifts are so handy.
Old 04-17-2017, 07:14 PM   #8
unavailablezl1
unavailablezl1's Avatar
Drives: 2019 Silverado Z71 6.2L A10
Ok, that is a pretty bold statement that it is not 100% true full synthetic. When Mobil 1 pioneered synthetic and it does say 100%. But let's go with your statement. My father was a chemical engineer for Conoco Oil his whole life with patents.
He told me to get straight HD 30w oil. Never get multi weight. Whenever you get multi weight oil, the additive that makes oil change its weight according to temperature does nothing for lubrication. So you get less lubrication because of the let's say, 5% additives, so only 95% of the oil in the bottle actually lubricates.
Is this what you are talking about?
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's.
Past Rides
2017 M6 Camaro ZL1 Hyper Blue
2016 M6 GT350 White with blue strips
2014 M6 Mustang GT Premium Track Pack Ruby Red
2012 M6 M3 Melbourne Red Metallic
unavailablezl1 is offline   Reply With Quote
Old 04-17-2017, 07:18 PM   #9
unavailablezl1
I agree with thicker oil in extreme hot climates like Houston where it gets to 100 degrees for weeks at a time. I have always used 20w50 Castrol GTX most of my life and my cars go for many miles 100K+ and never any problems. Winters are mild so the 20w is just fine.
Current ride
Past Rides
Old 04-17-2017, 08:35 PM   #10
Zeke.Malvo
Zeke.Malvo's Avatar
No, just that their stock isn't true synthetic oil. It's actually been covered a million times on the message boards. You'd have to do a search. There are very few oils that are considered to be true synthetics. I personally run Mobil 1 because it doesn't bother me that it's not a true synthetic.
Old 04-17-2017, 08:46 PM   #11
Canadian ZL1
I appreciate the offer..that's one hell of a road trip for me...by the time I arrive I will need that lift for an oil change...ha ha.
Old 04-17-2017, 09:18 PM   #12
utsteve98
Drives: 2018 ZL1 1LE, 2017 Ford Raptor
As an engineer and the engineers I know recommend synthetic for direct injection engines. Coking of the valves have been issues on other engines. Not sure about the LT4. This occurs as regular motor will vaporize some and drop deposits on the valves. If there is no fuel spraying onto the valves that had a cooling and cleaning effect then coking can occur. This brings up the whole catch can debate but that's another issue.
utsteve98 is offline   Reply With Quote
Old 04-17-2017, 11:05 PM   #13
greaser2
greaser2's Avatar
Drives: 2017 A10 ZL1 KG
I've used Mobil1 in my new vehicles for years. When their competitors often compare their brand to Mobil 1 then that says a lot. I am 100% positive it is not 100% synthetic, it's still the best. As far as using M1 15w50, go ahead. It will be fine. Especially in hotter climates or when racing a bit.
greaser2 is offline   Reply With Quote
Old 04-17-2017, 11:14 PM   #14
Zeke.Malvo
Zeke.Malvo's Avatar
That's because of marketing and what sells. Mobil 1 has built a brand that people trust and respect, but it does not make them the best.
