Old 04-16-2017, 12:34 PM   #1
Basehit
Basehit's Avatar
Drives: 2017 2.0T RS
2017 CAI Install - What am I missing??
I'm stuck. If I could just get this connector to budge, I'd be able to throw my new Injen EVO3700 on in about 30 minutes.
All the vids I've seen are of 2016's - there is a catch-and-release button on those for easy removal. Unfortunately, I have no such luck with my 2017. I'm trying to figure out of there's some sort of special tool or gadget I need to get so I can pry this thing off.
Here's a photo of the bane of my existence:
Does anyone have experience with this? Any advice, videos, pointers or walkthroughs would be incredibly appreciated.
Basehit is offline   Reply With Quote
Old 04-16-2017, 12:38 PM   #2
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
Mishimoto and Jason@JacFab have remedied this situation with the tools they made for it. Chevy dealerships have them as well but that visit is at your own peril. I'm sure there was a walkthrough on here posted by someone.
Old 04-16-2017, 12:39 PM   #3
b0bsaget007
b0bsaget007's Avatar
Drives: 2016 2LT RS Blue Velvet
This has been documented with other 2017 owners; they changed the CCV clamp for the 2017 models. The 2016 models have a simple clip that slides in and out, but the 2017's are clamped on differently. There are two tabs that you need special tools to release; one is on the front side in your pic, where the triangle is pointing to, and the other is on the opposite side.
This video shows Mishimoto's intake installation, which shows how to remove the CCV hose on 2017 models.
EDIT: Seeing as this is your first post: Welcome to the forums!
PC: i5-6600; RX 480 4GB; 16GB DDR4; Samsung 950 PRO 512GB SSD
Car: 2016 Camaro 2LT RS 2.0T 6M Blue Velvet Metallic | ZZP Hi-Flow Catted Downpipe | Injen EVO7300 Cold Air Intake
b0bsaget007 is offline   Reply With Quote
Old 04-16-2017, 03:43 PM   #4
Basehit
Basehit's Avatar
Thanks for the pointers and reference guys - I will give this another go next weekend. Wonder why GM decided to switch to such a PITA connection.
Old 04-16-2017, 03:44 PM   #5
Evil-Bee-NH
603 Camaros
It's what GM does to keep us guessing.
Old 04-16-2017, 06:40 PM   #6
Michigan1LTRS
Blessed ❤️
Michigan1LTRS's Avatar
Drives: 2017 1LT RS I4
Ok, so I got this tool to remove the hose. Fits perfectly but it's not working. Is there a trick? I have other sizes as well, but this looks like the right one.
Old 04-16-2017, 07:24 PM   #7
Jason@JacFab
Most have had good luck using a fuel line disconnect tool of the right size. You can buy kits of the tools in different sizes at your local auto parts store
I've also been able to do it with just a bent up piece of welding Rod.
Old 04-16-2017, 07:50 PM   #8
Basehit
Basehit's Avatar
So I finally got my cai installed! Unfortunately, when I was removing this thing, I snapped one of the clips inside. It still clips on to my new cai, but my check engine light is now on. Is it safe to assume this could be the reason? I imagine I likely need to get a replacement tube or at least clip. Or maybe just seal it somehow. Kind of lost at the moment.
Old 04-16-2017, 08:16 PM   #9
Evil-Bee-NH
603 Camaros
Try some Loctite or something else and see if the CEL go's away otherwise it's probably the MAF.
Old 04-16-2017, 08:40 PM   #10
Basehit
Basehit's Avatar
Cool, thanks. Is there a fix for it if it is in fact the maf?
Old 04-16-2017, 09:27 PM   #11
Evil-Bee-NH
603 Camaros
Your MAF may be loose or damaged.
Old 04-16-2017, 09:36 PM   #12
Michigan1LTRS
Blessed ❤️
I would think if you do not have a good seal on the piece you broke, that is the source of your cel. Seal it, clear the light and see what happens.
Old 04-16-2017, 11:25 PM   #13
Basehit
Basehit's Avatar
So I realized that I did not disconnect the battery prior to my install. I went out, disconnected, waited about an hour and started her up. No cel light. I'm hoping my initial bonehead mistake of not unplugging the battery was the issue.
Old 04-17-2017, 12:32 AM   #14
Evil-Bee-NH
603 Camaros
If the CEL went away then it was because you didn't disconnect the battery. I'm assuming you must've unplugged your MAF sensor when you uninstalled your OEM Air Box that's what caused the CEL with the battery still connected. It's normal and a common oversight nothing to be worried about.
