Old 04-04-2017, 01:01 PM   #1
Brianw36
SNSTRSS
Brianw36's Avatar
Drives: 2016 Camaro 2SS A8
Flex fuel Kit Question
Sorry to ask this question but I can't seem to find the answer through search. Is it ok to completely install the flex fuel kit and drive the car without tuning it first? I don't plan on running e85 yet. I am waiting to get my headers installed before I perform the tune. Any help would be greatly appreciated. Thanks
2016 Black Camaro 2SS A8 NP
Brianw36 is offline   Reply With Quote
Old 04-04-2017, 04:00 PM   #2
Fraxum
Fraxum's Avatar
PM EFI tuning. Tim will help you.
Old 04-04-2017, 04:23 PM   #3
R3DLT1
Toyota Tech
R3DLT1's Avatar
Drives: 2SS A8
yes u can install it. im currently running mine without a tune. runs fine
2016 Camaro SS A8 Roto-Fab CAI: Drag set up 11.9 @116
Sold 95 Camaro Z28 Cam:Bolt ons: 12.3 @114
Sold 2013 Chevy Crzue LTX
R3DLT1 is offline   Reply With Quote
Old 04-04-2017, 04:25 PM   #4
Brianw36
SNSTRSS
Brianw36's Avatar
Thanks R3DLT1.
Old 04-04-2017, 05:01 PM   #5
Brianw36
SNSTRSS
Brianw36's Avatar
After some more searching I found a response from Tim about being able to hook it up without tuning. Thanks for the responses.
Old 04-04-2017, 05:06 PM   #6
EFI Tuning
EFI Tuning's Avatar
Drives: 2016 Camaro SS
The ECM doesn't look for the sensor until it is tuned. Installing it pre tune is fine.
DON'T drop the retainers! LOL You know who you all are.
EFI Tuning is offline   Reply With Quote
Old 04-04-2017, 08:27 PM   #7
JFM-jr
JFM-jr's Avatar
care to elaborate on this? ill be installing mine over the weekend
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB
Rotofab
ARH 1 7/8 longtubes hi flow cats AFM deleted E85
11.0@124.9
11.65@118.8 pump gas,stock tune/exhaust
New combo: Pray Performance Heads/cam
MSD intake manifold and Circle D 3C
554/491 on E85 all work & tuning done by Pray
JFM-jr is offline   Reply With Quote
Old 04-04-2017, 08:36 PM   #8
ULTRAZLS1
ULTRAZLS1's Avatar
The retainers for the fuel lines are screw on instead of clamp on like the originals.
Got to be careful. Can be a bit tricky to get the threads started. If they are not and one lets go to grab a wrench etc they can pop off.
I had one pop off in the same manner but luckily I didn't lose it.
Im guessing that's what they talkin about
Old 04-04-2017, 09:24 PM   #9
EFI Tuning
EFI Tuning's Avatar
The fittings that connect to the stock hard lines have screw in retainers. It is possible to drop the retainers and lose them into the black hole of the engine compartment. You absolutely do not want to run without the retainers installed as the fittings will likely come off the lines.
Sometimes I have some extra retainers on hand. Sometimes I don't and you will have to buy a new fitting just to get the retainer. The retainers also are not identical.
The retainer for the Racetronix has a slot in it to slide over the ride in the hardline. The other will sit behind the ridge.
Tim
Old 04-04-2017, 09:40 PM   #10
JFM-jr
JFM-jr's Avatar
I guess this will make sense when I have the kit in hand
Rotofab
11.0@124.9
Old 04-04-2017, 10:17 PM   #11
Snowblind
Snowblind's Avatar
I just installed mine, it's easier to understand it once you physically have it.
Finding plug 38 and inserting the wire correctly seemed to be the most challenging of the install. The pic pointing out which plug it was saved a ton of time.
Old 04-05-2017, 03:43 PM   #12
bybcous
bybcous's Avatar
Drives: 2016 Hyper Blue 1SS
Do you have a install guide somewhere, it looks pretty simple to install.
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 04-05-2017, 04:44 PM   #13
EFI Tuning
EFI Tuning's Avatar
http://www.camaro6.com/forums/showthread.php?t=477370
Old 04-05-2017, 06:34 PM   #14
SSnakeEater
Guilty as charged on dropping the retainer LOL. Tim was awesome and super patient with me during my install. Thanks again Tim!!!
SSnakeEater is offline   Reply With Quote
