Old 03-17-2017, 06:16 PM   #1
E-Ray
Drives: 2016 Camaro 2SS, Nightfall Grey
E-Force Dyno Results
Had my 2016 SS Auto Dynoed at Futral Motorsports today. Kind of disappointed with the results. 505 H/P, 513 T/Q. This is E-force and everything else stock. I guess I'm happy with the power, for my daily driver. I need wider tires give me some better traction. Other than that I will leave it as is.
[IMG][/IMG]
E-Ray is offline   Reply With Quote
Old 03-17-2017, 06:35 PM   #2
1le32907
Drives: Summit white 1le ss
They a8 looks like it has a lot of drivetrain loss
1le32907 is offline   Reply With Quote
Old 03-17-2017, 06:45 PM   #3
Yellow6thGen
18 ZL1 A10 Convertible
Drives: White ZL1 Convertible
Did you get the stock numbers too?
Yellow6thGen is offline   Reply With Quote
Old 03-17-2017, 06:45 PM   #4
E-Ray
I agree, wonder how to calculate crank H/P with this A8 transmission. What I like is it is a safe tune, as requested.
Old 03-17-2017, 06:48 PM   #5
E-Ray
No, I never had it done until I installed the S/C. But you can see the difference between Edelbrocks tune and Futral's tune.
Old 03-17-2017, 07:26 PM   #6
Atomic Ed
Drives: 2001 Audi TT, 2016 Camaro
Did you have all of the nannies turned off? It makes a difference.
Atomic Ed is offline   Reply With Quote
Old 03-17-2017, 07:36 PM   #7
cleoent
cleoent's Avatar
Drives: 16' Camaro E-Force SS
91 or 93?
Leo
2016 e-Force 2SS
Instagram @cleoent
cleoent is offline   Reply With Quote
Old 03-17-2017, 07:37 PM   #8
E-Ray
I did not see if he had turned them off Ed, I would think that he did. Now you got me wondering, I will call him monday and confirm.
Old 03-17-2017, 07:37 PM   #9
E-Ray
Originally Posted by cleoent View Post
91 or 93?
93 Exxon
Old 03-17-2017, 07:45 PM   #10
cleoent
cleoent's Avatar
Originally Posted by E-Ray View Post
93 Exxon
Hmm. That's probably about 35 hp low.
What were your iats? I'm probably right around same power as you on 91. Edelbrock says that 91 to 93 is worth 35+ hp.
Leo
2016 e-Force 2SS
Instagram @cleoent
Old 03-17-2017, 07:46 PM   #11
cleoent
cleoent's Avatar
I just put my car in track mode on the dyno. Didn't turn anything off.
Leo
2016 e-Force 2SS
Instagram @cleoent
Old 03-17-2017, 08:09 PM   #12
E-Ray
He did say IAT's were high, did not dwell on the actual temperatures. But I did have to drive the car over 150 miles to get to the shop. So engine was hot from the start.
Old 03-17-2017, 08:12 PM   #13
cleoent
cleoent's Avatar
Is the 505 number with the custom tune ?
If the car is hot, can it still be tuned properly ?
The initial 48x number is what?
Leo
2016 e-Force 2SS
Instagram @cleoent
Old 03-17-2017, 08:17 PM   #14
Atomic Ed
You may be seeing some wheel spin in the upper RPM range given how the graph is dancing around.
Here's my dyno run with the all the nannies off/on. Be sure he does the full 10 sec hold on the mode switch to shut them completely off. Took us a while to figure this out.
Name:  20160608_161802 [193025].jpg
