Old 03-10-2017, 09:28 AM   #1
Sub
Sub's Avatar
Drives: 2017 ZL1
TPMS install 13598787
Does anyone know the inch-lbs required for this sensor (aftermarket rim). 35 in-lbs maybe? Any install video/manual available? Thanks!
My Car Blog and mods. Previous Chevys: 2016 2ss, 2015 C7 z51, 2004 C5 Z06
Sub is offline   Reply With Quote
Old 03-10-2017, 09:45 AM   #2
Bow Tie Affair
Drives: 6th. Gen ZL1
The OEM sensors i have seen have the torque value printed on them. If they do not, i would torque them to 40 inch lbs. Make sure the body of the sensor lays flat against the barrel of the wheel.
Bow Tie Affair is offline   Reply With Quote
Old 03-10-2017, 10:38 AM   #3
Sub
Sub's Avatar
Drives: 2017 ZL1
Ok. I didnt see anything written on them..
Old 03-15-2017, 12:55 PM   #4
Sub
Sub's Avatar
Drives: 2017 ZL1
Follow up question... when I ordered 13598787 off of Amazon, it didnt include the outer stem nut. Does anyone know a part # for that? I could only find a maintenance kit with stem/cap etc.
The 13598787 did come with the cap and valve already.
Old 03-16-2017, 11:51 AM   #5
Nothwinds
Drives: 2016 SS Camaro
I got that same set from Amazon and I went to Advance Auto and bought this kit, It works perfect.
VDO Continental TPMS Service Kit Part No. SE54190
Nothwinds is offline   Reply With Quote
Old 03-16-2017, 05:43 PM   #6
Sub
Sub's Avatar
Drives: 2017 ZL1
Oh, wish I saw this a yesterday! I ordered the nuts from the dealer - $4 each.
Old 03-17-2017, 03:12 PM   #7
Sub
Sub's Avatar
Drives: 2017 ZL1
Just a follow up, the gm part # is 13581557 " TPMS Sensor Valve" and it was $4 at the dealer
http://www.gmpartsdirect.com/oe-gm/13581557 ($2.37 here)
Also the service dept told me the torque value is 89 in-lbs.. seems a little high. But I verified with him it was for the 16 camaro. Anyone have a service manual?!
Old 10-08-2019, 05:32 AM   #8
trublucamaro
trublucamaro's Avatar
Drives: 1967 Camaro
Has anyone experienced a different torque value? 89 does seem significantly high for these things.
1967 Base 327 - numbers matching 10C car - (TruBlu - Marina Blue inside and out, still own)
1986 Base V6 - 1987 (Calif.) RS - 1995 Base V6 (all sold)
2017 2SS “Tribute FIFTY” in Blue (HBM, 56R, 5VM, MX0, F55, NPP, RN2, RZ9, S0O, S0V, IO6 Tribute RPO: BR9, FTJ, 56Y, CJL)#teamBeckyD
trublucamaro is offline   Reply With Quote
Old 02-09-2020, 01:40 PM   #9
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Service manual says Tighten 9 N-m  (80 lb in)
Old 02-09-2020, 05:19 PM   #10
It's in inch-pounds, not foot-pounds.
