Old 03-04-2017, 09:48 PM   #1
Quicksilver64
Quicksilver64's Avatar
Drives: 2017 ZL1 Nightfall Gray
First oil Change today
I changed my oil today at 600 miles. I'm too distrusting to let the dealer do it plus I just like taking special care. The engine definitely runs cool, the color was just like fresh oil. Very clean but I haven't really stressed it yet.
Interesting thing tho that I wanted to share, it had 11 quarts from the factory. I checked the dipstick a couple times previously and it was showing high. Now it hits the full mark perfectly.
Quicksilver64 is offline   Reply With Quote
Old 03-04-2017, 09:58 PM   #2
DenverTaco07
DenverTaco07's Avatar
Nice,love that NGM. I'll be doing my own as well. Are we supposed to do it 600 miles?
What size are those ramps?
Old 03-04-2017, 10:28 PM   #3
Quicksilver64
The owners manual doesn't recommend a change at 600, I have always preferred an early oil change on performance cars. It definitely didn't look like it needed it, no metal in the oil that I could tell or on the drain plug, but is cheap insurance.
The ramps are 56 inch long (2 peice) and 8 inches high. They worked great. Wish I had bought them long ago!
Old 03-05-2017, 08:41 AM   #4
Sooner Cole
Sooner Cole's Avatar
Drives: 2019 ZL1-1LE A10
Can you give us a little more info. Does the 17 ZL1 have the plate covering the oil pan and drain plug? Someone said 16 bolts to remove it? Also what oil filter and oil did you use. I believe the oil filter part # has changed? Manual says PF64, which is no longer available. Do you plan to change rear differential fluid? That part # has changed as well. Where did you get those low profile ramps, did they have plenty of clearance on the splitter? Sorry for all the questions, but I have been stressing leaving my car with the dealer for minor stuff like this and want to do this myself as well. Thanks!
19 ZL1-1LE A10
Sooner Cole is offline   Reply With Quote
Old 03-05-2017, 10:00 AM   #5
hawk02
Coupe Newbie
hawk02's Avatar
On a new car, I usually do the first oil change between 1200 and 1500 miles. Even though the Zl1 owners manual did not recommend changing the oil after the first 500 miles, I still followed the recommendation for the dry sump LT4 and did the first oil change at 600 miles. I figured it couldn't hurt. I plan to change the oil again between 1500 and 1600 miles and then at regular 3-5K intervals or once a year, which ever comes first.
Old 03-05-2017, 10:21 AM   #6
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
PF64 oil filter is available on Amazon for $6.18
Old 03-05-2017, 10:29 AM   #7
Quicksilver64
17ZL1
Part of the reason I did my own is to prevent a joy ride, but honestly my dealer is pretty dependable so I am sure it would have been OK.
There is no plate over the pan, plug or filter access is very easy once on the ramps. No issue on clearance and with these ramps plus they are two piece for ease of access. I got them at Amazon as well as the filters. Links below. The oil I use is Castrol Magnatec 5W30 Syn Blend. It is my favorite brand and one of the few Syn Blend, Dexos labeled I could find.
Here is a photo of the bottom, supplied by another fine member on thisthis site for reference as well.
https://www.amazon.com/gp/aw/d/B003Z...R56+race+ramps
https://www.amazon.com/gp/aw/d/B00AZ...rds=Delco+pf64
Old 03-05-2017, 10:38 AM   #8
Quicksilver64
Hawk02
I as well had the Z06 dry sump oil change in mind as well when I decided to change early. It never hurts.
Old 03-05-2017, 10:56 AM   #9
drag racer
drag racer's Avatar
Drives: SRT, dragsters, Chevy S10, Impala
If you read the owners manual for the LT4 crate engine, it has a break-in procedure much more resembling how I have always done my racing engines I build. Sounds like the car owners manual doesn't ask for any of this? I think you are spot-on in doing an early oil change.
BTW, here is what it says, basically two changes in first 500 miles:
The engine should be driven at varying loads and conditions for the first 30 miles or one hour without wide open throttle (WOT) or sustained high RPM accelerations.
Run five or six medium throttle (50%) accelerations to about 4000 RPM and back to idle (0% throttle) in gear.
Run two or three hard throttle (WOT 100%) accelerations to about 4000 RPM and back to idle (0% throttle) in gear.
Change the oil and filter. Replace the oil per the specification in step 1, and replace the filter with a new PF64 AC Delco oil filter. Inspect the oil and the oil filter for any foreign particles to ensure that the engine is functioning properly.
Drive the next 500 miles (12 to 15 engine hours) under normal conditions. Do not run the engine at its maximum rated engine
speed. Also, do not expose the engine to extended periods of high load.
...in pursuit of a '17 ZL1 Summit White A10...
02/24: order placed
02/27: 1100
03/22: ABANDONED - Got tired of screwing around with dealer BS and bought a Challenger SRT Hellcat!
drag racer is offline   Reply With Quote
Old 03-05-2017, 11:24 AM   #10
Evolvedx27
Evolvedx27's Avatar
Drives: 2017 ZL1
Exactly what I'm doing
Evolvedx27 is offline   Reply With Quote
Old 03-05-2017, 11:36 AM   #11
Sooner Cole
17ZL1
Thank you so much. Big investment on the ramps, but should pay for themselves eventually, not to mention peace of mind knowing it was done right and no one took a joy ride or damaged rockers, facia putting it on lift incorrectly.
19 ZL1-1LE A10
Old 03-05-2017, 11:55 AM   #12
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Google a stahlbus valve, with my ramps, I can do a 15 min change, never spilling a drop on my condo garage floor....
Old 03-05-2017, 12:19 PM   #13
Evolvedx27
Evolvedx27's Avatar
Drives: 2017 ZL1
Do they make a magnetic one? Like drain the oil completely first then take out plug to get rid of shavings.
Old 03-05-2017, 12:34 PM   #14
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
After the 1st chsnge, I'm not worried about metal shsvings/bits....
