Old 02-27-2017, 11:37 AM   #1
hzisfrom1994
ZYJ
hzisfrom1994's Avatar
Drives: 2017 1SS Camaro/6 speed
Pinch weld bend?
First thing I bought was the magnetic jack pad from zl1addons to use it with my floor jack.
Realize the area got bend where I put my 4 jackstands on. Some, not all 4... Eww still definitely not happy.
Strongly encourage you to buy maybe 4 more jack pad for the jackstands..
Anyway, any method to fix the bend pinch weld? can I hammer it?
hzisfrom1994 is offline   Reply With Quote
Old 02-27-2017, 11:48 AM   #2
17txcamaross
Drives: 2017 Camaro 2SS
The jack stands I use have an area for the pinch weld. Seemed to work perfectly when installing the axle back exhaust.
May try purchasing new jack stands rather than jack pads. The jack pads show not to use with stands I thought.
Not sure on the other issue. I would think hammering on the weld and bending multiple times would cause it to lose structural integrity.
17txcamaross is offline   Reply With Quote
Old 02-27-2017, 11:50 AM   #3
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
I am definitely not happy with the process of jacking up the car. I bought the the ZL jack pads but not happy with them. I put them in the correct position and add their slippery surface puck and it has slide off and the jack pad tilts and causes the puck to slip off. I now use a regular hockey puck the I have scuffed up with a file so it does not slip. I have also scuffed up the bottom of the metal jack pad with a file to create a non slippery surface.
In my opinion the GM engineering department did not keep
In mind the regular Joe that likes to do garage work at home and jack up his car once in a while. Plus, what a mess when the dealership can even mess up your car by not positioning their jack pads correctly.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 02-27-2017, 11:54 AM   #4
hawk02
Coupe Newbie
hawk02's Avatar
Sorry to hear that your pinch welds got bent.
I have a ZL1Addons magnetic jack pad for my floor jack. I was a little leary about setting the pinch welds down on regular jack stands so I bought these stands and pads. I haven't tried them yet so I can't comment on how well they work. I'll let you know when I do use them.
Old 02-27-2017, 12:46 PM   #5
Capisce
Drives: 2016 2SS Camaro
Hawk,
I received the same stands as a gift and was wondering how i was going to use a puck for the pinch since the surface of them is.. interesting. Where did you get those pads that fit perfectly or did you notch them yourself?
2SS - Summit White - MRC - NPP
Capisce is offline   Reply With Quote
Old 02-27-2017, 02:58 PM   #6
nate.the.great
Drives: 2017 Camaro 1SS 1LE
I'm not happy with the ZL1 design either. I bought it with the magpad, and it still slipped off my jack, causing damage to my side rocker. Your floor jack saddle MUST be larger than the magpad. Ugh, hopefully this saves someone the same headache I'm dealing with now.
nate.the.great is offline   Reply With Quote
Old 02-27-2017, 03:15 PM   #7
crazydmc
ummmm
crazydmc's Avatar
Drives: 2016 2SS M6 Nightfall w/Blk Wheels
question... are you supposed to lift against the BOTTOM of the vertical pinch weld itself or are the pads designed to keep the lifting force off of the pinch weld and lift along side (around) the pinch weld?
I just use wood between the floor jack and pinch weld... the wood is soft enough to spread the pressure along 4" of pinch weld, and also keeps it from slipping.
crazydmc is offline   Reply With Quote
Old 02-27-2017, 03:17 PM   #8
camaromike77
camaromike77's Avatar
Drives: S O L D
Hey hzisfrom1994.
That REALLY SUCKS that one of the pinch welds is bent. One of my biggest fears....... I have no idea how, and if that is even repairable. Hopefully someone more experienced will chime in.
I currently have mine up on 4 jack stands for the Winter. It REALLY makes me nervous, as each of the pinch welds are sitting on the metal "V" on the jack stands. I did use my ZL1Addons magnetic jack pad with my floor jack to initially lift the car in order to place the jack stands down. It worked well for me.
Having read your thread, I just ordered a set of 4 Race Ramps FlatStoppers, to start using for my Winter storage months.
Again, sorry to hear of this and will be watching this thread to see if someone can chime in and give you some recommendations to possibly repair the pinch weld.
Club F1FTY
Old 02-27-2017, 03:22 PM   #9
crazydmc
ummmm
crazydmc's Avatar
i'd be interested in seeing a pic of how bent it is...
Old 02-27-2017, 03:24 PM   #10
camaromike77
Drives: S O L D
^^ Me as well. Would be greatly appreciated......
Club F1FTY
Old 02-27-2017, 03:59 PM   #11
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
Originally Posted by camaromike77 View Post
Hey hzisfrom1994.
I've had my car up on 4 jack stands as well and the pinch welds seemed to hold just fine. I used the normal jack stands you see everywhere (like the pic below) and it seemed to work no problem. I was a bit worried though but no issues. Maybe I just got lucky. I put it down VERY slowly on them. I'm always scared to try and use the type posted above as they just look so easy to knock over with such a small footprint. I'm sure they're not but they just appear to be that way.
Eric SS is offline   Reply With Quote
Old 02-27-2017, 04:23 PM   #12
camaromike77
Drives: S O L D
I agree 100%, and those jack stands are pretty much identical to the ones I am currently using.........Just ordered these (for future Winter storage):
Club F1FTY
Old 02-27-2017, 05:57 PM   #13
hotlap
hotlap's Avatar
I bought these to put on top of my old, flat top, jack stands. I use two floor jacks with two ZL1addon jack pads to lift evenly side to side and then set it down on the stands with the pucks.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Ronald Reagan -
Old 02-27-2017, 06:06 PM   #14
Tara Martin
Loves Camaros
Tara Martin's Avatar
Drives: Red '79 Z28, '24 Blk A10 ZL-1 Vert
I'm an old-timer, I guess, but a nice soft piece of wood has always worked for me, too! That, and I'm exceedingly cheap!
Old and new, sharing space!
Tara Martin is offline   Reply With Quote
