Old 02-11-2017, 05:32 AM   #1
RobertAvitia
BYND GARAGE
RobertAvitia's Avatar
Drives: 17' 1LT Turbo
Erase check engine light?
For some reason my obd2 scanner won't let me delete my codes. I know the codes are good and everything fine, I just want to get ride of the light on my dash. Can someone tell me how to do it or how you did it? Thanks!
RobertAvitia is offline   Reply With Quote
Old 02-11-2017, 05:40 AM   #2
Burly
Burly's Avatar
Disconnect battery for 15 minutes.
Burly is offline   Reply With Quote
Old 02-11-2017, 06:40 AM   #3
E-Ray
Drives: 2016 Camaro 2SS, Nightfall Grey
Take it to the dealer and have them do it.
E-Ray is offline   Reply With Quote
Old 02-11-2017, 07:46 AM   #4
Yellow6thGen
18 ZL1 A10 Convertible
Drives: White ZL1 Convertible
Autozone....
Yellow6thGen is offline   Reply With Quote
Old 02-11-2017, 08:07 AM   #5
toro1966
toro1966's Avatar
Drives: 2017 Camaro SS Convertible 50th
Most dealers will not simply clear a CEL. They would be liable if they did. So what they will do is tell you they need to diagnose it and then, if there is no issue, they will clear it.
toro1966 is offline   Reply With Quote
Old 02-11-2017, 09:09 AM   #6
E-Ray
Exactly, the OP's car is still under warranty, they need to make sure there is no problems.
Old 02-11-2017, 03:24 PM   #7
toro1966
toro1966's Avatar
Gotcha. I guess my initial thought was that one of the only ways you would "know" that there was nothing wrong and the CEL was erroneous was if you had modded something you knew would cause those CELs.
You are absolutely correct in that assuming nothing;s been done to the car, I would take it right into the dealer.
Old 02-12-2017, 07:32 AM   #8
ctrlz
What is brand and model of your scanner?
Old 02-12-2017, 09:10 AM   #9
MrChrisLS3
Drives: 2018 1SS M6
If everything is fine, then the MIL will go out on it's own. When, depends on the code. Certain codes require a certain amount of drive cycles with no faults found, once this is achieved the light goes out.
MrChrisLS3 is offline   Reply With Quote
Old 02-12-2017, 12:17 PM   #10
mekirk2
mekirk2's Avatar
Drives: 2016 2SS Ragtop Garnet Red
Originally Posted by Yellow6thGen View Post
Autozone....
Many Autozones and Advance Autos wont clear them anymore. They'll read them for you but they are not allowed to clear them.
mekirk2 is offline   Reply With Quote
Old 02-15-2017, 11:51 PM   #11
RobertAvitia
BYND GARAGE
This fixed it! All cleared away
Old 02-16-2017, 01:18 PM   #12
GroundhogSS
GroundhogSS's Avatar
You can get an ODB II port reader with blue tooth and the Torque app to read and clear the codes. Don't know if the app is for iPhones, I have Android. Lots of other nice info with that app.
Richard
Delivered: 08/15/2016
#TeamBeckyD
Old 02-16-2017, 02:04 PM   #13
Bodyslide
Bodyslide's Avatar
Drives: Traded in 2016 BLUE VELVET 2LT RS
This is a cheap one I have used on my Camaro. It has cleared one misfire code without isse.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Bodyslide is offline   Reply With Quote
Old 02-16-2017, 02:07 PM   #14
bybcous
bybcous's Avatar
Drives: 2016 Hyper Blue 1SS
You can also data log all aspects of the car with The 4 dollar torque app, i pi ked up a Bluetooth obd2 reader from ebay for 12 bucks, 1 year later, no problems.
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
