Old 01-24-2017, 07:06 PM   #1
gdgraph
gdgraph's Avatar
Traction Control Stopped Working After New Tires
I just installed new tires, I got the same set up as many others have gotten on the forum - 20x10" front w/ BFG 275/35 and 20x11 rear w/ BFG 305/35 and never heard of anyone having any issues.
After a few medium accelerations my traction control light came on and started to blink and continued to blink even after I came to a stop at the light. I was able to get it to go away by pressing the traction control button on and off but after this happened a few times my check engine light came on.
I saw on a thread on the Camaro5 forum saying that certain tires (if they change the overall diameter too much) can cause issues to the traction control sensors but I know many people with this same exact configuration and never heard of this issue occurring.
Anyone have this issue with their car? Anyone know what the fix is for this, can the traction control be reprogrammed/reconfigured, how much does that cost?
UPDATE:
(1) I know that the rear tire has is 0.8" larger in overall diameter than the front, this is what must have caused traction control issues. I know a 305/30 size tire should fix the issue, however you cannot get that size in the BFG Comp 2 and I want to run an A/S tire so a 305/35 is my only option
(2) I know a few people that ran these tires before me, none of them had this issue when I talked to them before I purchased these
(3) I unplugged my batter for 10 min and after that the issue went away
(4) I've been driving for 1,000 mi with this configuration and no issues, I can launch hard and traction control works fine, I can turn it all off and do a burn out and the turn it back on and it all works fine.
gdgraph is offline   Reply With Quote
Old 01-24-2017, 07:51 PM   #2
pinoyscorpion951
pinoyscorpion951's Avatar
Drives: 2016 Bright Yellow 2SS A8
That's weird. Do these cars have a yaw sensor or speed sensor that the techs may have damaged when they installed the tires? Maybe try disconnecting the battery/global reset.
pinoyscorpion951 is offline   Reply With Quote
Old 01-24-2017, 08:15 PM   #3
bybcous
bybcous's Avatar
Drives: 2016 Hyper Blue 1SS
That sucks, how did the rubbing issue work out?
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 01-24-2017, 08:31 PM   #4
mjwill25
Drives: 2016 Black 2 SS
Check your wire harness that is inside the drivers side rear wheel well. Most likely you have rubbed through it. I was almost through mine but caught it in time to where I was able to re-wrap it and move it over.
2016 2SS Black on Black, NPP, MRC with 6 speed, ARH Catted LT Headers, AWE Touring Exhaust, RotoFab CAI, Soler Performance TB and TC, GPI Ported LT2 IM, Pray Ported Heads, Pray Custom Grind Stage 2 Cam, DSC v2, BMR STB019H, Stance SF10 in Brushed Dual Gunmetal, Black Bowties, Black SEMA Grille, Smoked Tail Lights, Oracle Ghosted Side Markers
mjwill25 is offline   Reply With Quote
Old 01-24-2017, 08:35 PM   #5
cleoent
cleoent's Avatar
Drives: 16' Camaro E-Force SS
There have been NUMEROUS posts about 305/35s rubbing in the rear, specifically the wiring harness. That's the first place i'd check as it sounds like you may have rubbed right through it.
cleoent is offline   Reply With Quote
Old 01-24-2017, 08:45 PM   #6
gdgraph
gdgraph's Avatar
I am aware of the rubbing that has been reported, but not aware of any traction control issues.
I did relocate the wire harness on the rear driver side wheel prior to putting on the tires even though I haven't actually experienced much rubbing like others have.
That harness runs fuel gauges/fuel sensors, and maybe a mylink cable, all of those things function properly. That harness does not have have anything to do with ABS/traction control which is why I am wondering what the issue is since the only thing I can think of is different tire size messing with the TC sensors but nobody here has had that issue so I am currently stumped.
Old 01-25-2017, 06:42 PM   #7
gdgraph
gdgraph's Avatar
UPDATE:
So I unplugged the battery for 5 min and plugged it back in and the check engine light went away. I was worried the traction control/stabilitrak lights would blink but after some hard pulls it's running fine now. Turned the TC off and did a tiny burn out, turned the TC back on and it all still worked.
So no clue what the actual issue was, but it's all good now!
Old 01-25-2017, 07:39 PM   #8
Extreme Dimensions
Extreme Dimensions's Avatar
Drives: 2016 1ss Camaro
i had it happen to my car when switching over from stock wheels and tires to my new wider wheels and tires but it went away after a day or two
Andrew Bettridge
Account Manager
Extreme Dimensions
1-714-278-8000 EXT 17
andrew.bettridge@extremedimensions.com
Extreme Dimensions is offline   Reply With Quote
Old 01-25-2017, 08:42 PM   #9
gdgraph
gdgraph's Avatar
What! Where were you yesterday when I was freaking out thinking I broke my traction control haha!
Old 01-25-2017, 09:28 PM   #10
franksredhot
franksredhot's Avatar
Drives: 2016 Red Hot Camaro 1SS A8
I don't understand why people are going to 305/35 when stock is 275/35. The side profile is calculated as 0.35 X width. So when you increase width, you need to decrease the profile ratio to get the same sidewall profile.
.35 X 275 = 96.25 mm
.35 X 305 = 106.75 mm
.30 X 305 = 91.5 mm
So 305/30/20 would be closer to stock diameter. Either way the speedo is going to be thrown off and I expect traction control could be affected.
franksredhot is offline   Reply With Quote
Old 01-25-2017, 09:59 PM   #11
sub_ETCS_ret
sub_ETCS_ret's Avatar
Drives: 2019 Dodge Challenger Scat Pack
.30 X 305 = 91.5 mm
Yes but you can't have a smaller rear diameter than the front. That will really jack up the traction control.
Sent from my SM-G920V using Tapatalk
"Submariners are a bunch of intelligent misfits that somehow seem to get along, understand each other and work well together." - overheard from a surface officer explaining to another sailor about Submariners
sub_ETCS_ret is offline   Reply With Quote
Old 01-26-2017, 05:51 PM   #12
franksredhot
I think the stock front tire size is slightly larger in diameter than rear.
245/45/20 gives you a profile of 98 mm and 275/35/20 = 96.25 mm.
I'd like to go to 315/30/20 on rear = 94.5 mm (but still is smaller than stock)
Old 01-26-2017, 07:00 PM   #13
sub_ETCS_ret
Except it's 245/40 but yes you are correct, it's 98mm. When the back is spinning faster than the front, traction control is going to kick in. Thus if your tire in the rear is too much smaller than your front, then you're gonna have issues.
Old 03-18-2017, 10:30 PM   #14
Sunsnare98
Drives: 2017 camaro ss
Yup...you are 💯% correct. I'm surprised how many people don't understand how this works. ive tried 275-35 front and 305-30 rear and TC kicked in early because the CPU thinks the rears are spinning because it rotates faster because of the decreased height.
Rule of thumb...if you change the stock height stagger, make the rear taller. This way...the only issue you might have would be TC kicking in a hair later.
Sunsnare98 is offline   Reply With Quote
