01-08-2017, 11:52 AM | #1 |
Drives: 2019 Camaro 1LT Join Date: Aug 2014
Need to know if these will fit?!
I have a 2016 1LT. So no Brembos. Is there anyone that has put these 245/55/18 tires with steelies on their 6th Gen? There is a guy on youtube with a 6th gen 2SS that has these steelies on but he is using a 225/60/18 tire. My stock tires are 245/50/18 so how big a difference is a 245/55/18? I want to know if they will fit ok. I just want to use these for winter. I had a 2012 5th gen that had these BF tires and it was a lot better in the snow.
01-08-2017, 02:02 PM | #2 |
Car Enthusiast
Drives: 2017 Camaro SS FIFTY Join Date: Jul 2016
The YouTube video you saw was probably TopHatPlus
http://www.camaro6.com/forums/showpo...00&postcount=1
2017 SS Camaro FIFTY
6MT, Nav, NPP, Black Bowties, Mishimoto OCC, Skip Shift Eliminator, GM Footwell Lighting, NGM Splash Guards, GM Blackout Tail Lights (SOLD) Last edited by Mr. Grumpy; 01-08-2017 at 02:55 PM. |
01-08-2017, 05:31 PM | #3 | |
Drives: 16 Hyper Blue RS V6 A8, 09 Civic EX Join Date: Jun 2016
01-08-2017, 06:03 PM | #4 |
603 Camaros
Drives: 2017 NGM I4 1LT Coupe Join Date: May 2012
To give you an answer YES they will fit fine, like bdougwrx said they may be off a bit on readings but if it's for winter use who cares.
MY 2017 I4 CAMARO BUILD JOURNAL | YOUTUBE | INSTAGRAM | 316RWHP - 385 RWTQ HPTUNERS DYNO TUNE | 12.693s @ 105MPH 1/4 Mile |
01-09-2017, 04:23 PM | #5 |
Drives: 16 2SS NPP MRC Join Date: Aug 2016
I am probably the guy you watched on youtube?
They will fit just fine. I went 225-60-18's to narrow up the tire tread, if i put a 245 wide on the rim it would have been 245-55-18 with the same results. Rear rim will need to be spaced outward on a SS model WITH brembos. Your 1LT should fit on no problem. I am in the hunt for the centre caps and beauty rings though i really like the look of them! |
07-15-2023, 10:34 AM | #6 |
Drives: Chevy camaro Join Date: Aug 2022
I found some cheap 245/60/18s. Any know if those would fit a camaro with no brembos? Thank you.
07-15-2023, 12:00 PM | #7 | |
First, I don't think they will fit at 29.6" height, but second, even if they somehow miraculously did fit, you'd be maiming the car with this crap. Another thing is I am assuming here that you have a square setup, otherwise ABS and StabiliTrak will almost certainly misbehave and throw codes when one introduces a gigantic front/rear bias (height difference).
04-07-2024, 11:54 AM | #8 | |
