![]() Drives: 2018 Hyperblue Camaro 1SS/1LE Join Date: Feb 2015
One Piece Driveshaft?
I want a 1-piece driveshaft for my 2016 Camaro 1SS m6... Does anyone know if there is one made for these cars yet?
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL-1 Join Date: Feb 2009
You mean A8. The IRS of the Camaro means you have halfshafts.
No I actually meant m6 <3 Sorryyyy
![]() Drives: 2016 Camaro SS M6 w/ NPP Join Date: Jun 2016
I just ordered, and should be receiving today the first 4" 1 piece driveshaft from GForce. They do offer a 3.5" which is good for up to about 700 rw. I highly recommend GForce for axles and driveshafts
Whipple 2.9, Custom New Era Performance cam,
E85, LT4 fuel system, Motec powered port injection, teeny tiny Nitrous Outlet system, Stainless Works LTs, Centerforce Triad, GForce 9" with strange pro case 3.50 gears. Carlyle 15" conversion 28"x10.5" MT ET Drag 28"x4.5" M&H fronts PB: 9.569 @ 151.05 |
I used to be Dragoneye...
The driveshaft connects the transmission to the differential...well before the IRS and axles...
Sometimes referred to as a prop shaft. In the Camaro, it is a two-piece unit, connected in the middle by a universal joint and bolted to the body. |
Can I order online? May I have a link ??? I'm get with the 3.5 I'm planning on keeping my car NA and doing my bolt ons it won't be until I pay this mother off before I go forced induction.
#7 |
#8 |
No problem.
![]() I been there...so eager to help, you miss that one important word, or thought while reading a post.
#9 |
Drives: 2016 Camaro SS Join Date: Oct 2016
I wish they would rate things in torque capacity not HP. HP ratings are meaningless on something like this.
#10 |
word!
#11 |
I agree, but I'm not out to change the world. I'm guessing that in most instances the torque does not exceed the HP rating, and often times is pretty close. Pretty much anyone whos been on a dyno can tell you exactly that HP number... You could throw in that no two dynos measure the same torque either...
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
why would they need a two piece driveshaft? is it to minimize vibrations? kinda weird as the diff is stationary compared to SRA.
the benefits to a 1-piece is less weight? strength? Last edited by 6spdhyperblue; 12-01-2016 at 02:23 PM. |
#13 |
![]() Drives: 2016 Chevy Camaro Join Date: Jun 2016
There's no scientific benefit to switch to a one piece drive shaft. The two piece actually has a function believe it or not. That unbelievably quiet and smooth ride you experience every time you drive it has alot to do with it. We have to throw away the old school chain of thought when it comes these new cars. The ONLY advantage you could have over a two piece shaft is if you plan on ditching the IRS altogether and going to a live axle set up which means your intentions are to be in the 1000+rwhp range. Other than that it's a total waste of money. Hell they even weigh the same....
