Old 11-28-2016, 08:37 PM   #1
f0x
Drives: Silver 2016 Camaro R/S
JMS Pedal Max for TURBO LAG....
Getting my JMS Pedalmax for my 2.0 Turbo tomorrow.. Supposed to get rid of turbo lag and improve the overall performance.. I will post the results tomorrow..
http://www.jmschip.com/pedalmax-gm_v...015-ats-c7-ss/
f0x is offline   Reply With Quote
Old 11-28-2016, 08:47 PM   #2
Rosie2514
Drives: Bowtie's Only
Looks to me like a Vitnesse competitor?
A much more expensive competitor if they indeed do the the same thing.
Rosie2514 is offline   Reply With Quote
Old 11-28-2016, 09:30 PM   #3
f0x
Never heard of Vitnesse... Theres not much out there right now for the 2.0 turbos.. Not much shopping around I can do..
Old 11-29-2016, 05:16 PM   #4
f0x
OK.. So After installation and test driving, I must say.... WOW... Complete 100% Difference... Night and day... TOTALLY worth the money. I am so glad I bought this. Eliminated the turbo lag completely, Throttle response is AMAZING!!! I know this does not add HP, But it feels like a whole new car again.. THANK YOU Jms Chip!!!!
Old 11-30-2016, 10:55 AM   #5
Adp2017
Adp2017's Avatar
Drives: 2017 RS Turbo
Glad you are happy! you should do a 0 - 60 and see what times you can manage,
Adp2017 is offline   Reply With Quote
Old 11-30-2016, 11:14 AM   #6
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
why would the 0-60 change? You have 0-100% pedal position that translates to throttle position by the car.
When you want to go fast, you mash the peddle down and that takes an extremely small fraction of a second. 100% in the stock pedal should be 100% on any aftermarket pedal position sensor. Higher than 100% doesn't make any sense. So mashing the pedal will not produce any difference in performance (or shouldn't unless the aftermarket pedal sensor isn't working correctly and isn't hitting 100%).
All these aftermarket solutions do is change the rate at which (usually applying a curve) the position of the pedal is reported to the car. The curves they can apply may be more natural to particular people or more convenient etc.
Everything they do can technically be reproduced without them but depending on your driving style, it may be inconvenient and unnatural feeling. Also aftermarket tunes can do the same corrections for those considering having that done.
Old 12-03-2016, 07:36 PM   #7
f0x
Your absolutely right, But I think he was meaning the difference in time do to the fact that the turbo lag is completely gone.. When I hit the pedal it instantly takes off instead of it taking a few seconds for the turbo to kick in..
Old 12-03-2016, 07:38 PM   #8
f0x
I didnt check it before , So I dont know the times. BUT I will still check it out in the next few days and post the times... I know there is a complete difference in the take off. Instantly takes off when I hit the pedal.. LOVE IT..
Old 12-05-2016, 04:48 PM   #9
Marty McFlew
Drives: 17 SuperSport Camaro 6 on the Flo'
Same thing as a Sprintbooster
Marty McFlew is offline   Reply With Quote
Old 12-05-2016, 11:33 PM   #10
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
OP glad your liking the JMS I went with vitesse simply because I used them on my 5th Gen V6 and it was awesome I know little about JMS but from what I have seen their customer service is far better then vitesse and to those asking and arguing 0-60 if OP drives an auto you should definitely rev to around 2500 - 3000 RPM and launch with the controller it does hit slightly faster but not a huge difference if it's a 0-60 pedal mash honestly.
Old 12-06-2016, 12:27 AM   #11
camex
Drives: Sold
Is this easy to intall?
camex is offline   Reply With Quote
Old 12-06-2016, 12:54 AM   #12
Evil-Bee-NH
603 Camaros
They're both super easy to install but require a little contortion of the body. I found laying upside down with my feet around the headrest worked great. Not sure how the JMS plugs in, the vitesse you just unplug the harness from the pedal and plug the vitesse as a connector into those two now open connections a simple 2 sec calibration procedure and your good to go.
Old 12-06-2016, 01:00 AM   #13
camex
Drives: Sold
Thanks!!
Old 12-06-2016, 05:28 AM   #14
Nate...
Nate...'s Avatar
Drives: 2016 Camaro LTG
I have this JMS Pedal Max as well and agree that the throttle controllers make a big difference to the feel of the car.
I was under the impression that the JMS pedal max also has some predictive logic in it that will make the TPS ramp quicker, so it's not just about a x=y TPS remap, but also a legitimately quicker response in the right situations. *For example throttle blip for downshifting
2016 LTG Camaro in Hyper Blue with MRT V3 Catback and Brembo SS Brakes.
Nate... is offline   Reply With Quote
