Old 11-25-2016, 08:21 AM   #1
ender2664
Drives: 2016 2SS
Exhaust gains
I tried search but couldn't find anything. I find that suspicious but I'll ask anyway.
I know I cannot get an exact figure but I'm just looking for as best an estimate as I can get.
What, roughly of course, would the following setup gain considering the car is otherwise stock:
Shorties to stock cats
3inch exhaust all the way from the cats (no muffler, no resonators etc, just 3inch all the way back)
30-35hp and 35-40trq to the wheels sound about right? Or are those to optimistic?
I'm hoping, but could be completely wrong, that with that set up and a Roto-fab that I'll be right around 500hp to the crank.
ender2664 is offline   Reply With Quote
Old 11-25-2016, 09:02 AM   #2
ModdedSS
ModdedSS's Avatar
Drives: 2017 Camaro SS 1LE
I'd say you're being pretty optimistic. The headers will help, but the straight pipe will not.
Show: C7 Carbon ZL1 Front Splitter/C7 Carbon ZL1 Side Skirts/Diode Dynamics LED Sidemarkers/Tinted Headlights, Fog Lights, and Rear Reflectors/20" Forgestar F14's in Bronze Burst
Go: 17" Forgestar F14s in Bronze Burst with Hoosier Drag Radials/Rotofab Intake w/ Dry Filter/EFI Flex Fuel Kit/Kooks 2" Longtubes with Offroad Connections/PRAY Performance Ported Intake Manifold/PRAY Performance Ported Throttle Body/PRAY Performance Ported Heads/PRAY Performance Tune
Suspension: Phastek Lowering Springs/BMR Toe Rods/BMR Control Arms/BMR Trailing Arms/BMR Strut Tower Brace
ModdedSS is offline   Reply With Quote
Old 11-25-2016, 09:04 AM   #3
ender2664
Drives: 2016 2SS
These (Blackheart) gains just advertising?
http://www.phastekperformance.com/se...xhaust&Submit=
Old 11-25-2016, 09:12 AM   #4
ModdedSS
ModdedSS's Avatar
I haven't seen any dyno proven gains to support blackheart's gains, I for one thought they were very optimistic when I first saw them. However, The blackheart still has mufflers while a 3inch straight pipe won't have any backpressure and would hurt an N/A motor while benefiting a turbo motor.
Old 11-25-2016, 09:38 AM   #5
ender2664
Drives: 2016 2SS
Hurt down low but gain up top, correct?
Old 11-25-2016, 10:36 AM   #6
ModdedSS
ModdedSS's Avatar
Correct
Old 11-25-2016, 10:38 AM   #7
ender2664
Drives: 2016 2SS
I haven't seen any dyno proven gains to support blackheart's gains,...:
Have you seen anything to refute them?
Old 11-25-2016, 10:40 AM   #8
ender2664
Drives: 2016 2SS
Correct
Car has plenty of power down low for me. Gains at the top of the power band are far more important to me unless I'm taking a big hit down low.
Old 11-25-2016, 12:18 PM   #9
ModdedSS
ModdedSS's Avatar
I haven't seen any dyno of the blackheart exhaust period, so I can neither confirm nor deny their claims
Old 11-25-2016, 01:38 PM   #10
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
It seems like the non NPP cars have the largest gains. So when you see dyno numbers advertised from the manufacturer. There is a good chance they took the lowest non NPP dyno number as a baseline, then added the parts and tuned the car and took the best dyno run they could get. Then they advertise the worst of the worst with the best of the best.
Full headers, high flow cats, and exhaust all the way to the tailpipe will probably get you about 20 rwhp give or take 5hp. Full catback will probably get you nothing. The Borla secondary cat delete midpipe and their axle back may get you 5hp.
Old 11-26-2016, 09:57 AM   #11
My87z28
Drives: 1987 Z28, 385cid, '16 Camaro 1SS
Considering the stock exhaust "manifold" is already a tri-y shortie header, I'd doubt there would be a ton of gain from an aftermarket shortie header. Full length headers on these cars with a single high flow cat and cat back exhaust are only seeing 25-35rwhp. So I'd doubt using a shortie header, retaining the factory cats and run 3" straight pipe would match it. As for the back pressure, I'm pretty positive that the factory cats produce well more than enough back pressure, hell one pair of high flow cats would produce plenty of back pressure.
Id save my money and go with full length headers when you are ready to tune. In the meantime get the ported intake & throttle body, CAI, delete the secondary cat, and have a 3" X-pipe exhaust installed. Even without a tune, it looks like these things should be good for around 35-40rwhp.
02/23/16: 1100, 03/16/16: 2500 # TGHR6N
03/16/16: 2500, 03/18/16: 3000 TPW : 4/11/16
04/8/16: built & VIN 04/11/16 - 04/28/26 : 4B00 Bayed QC hold, 04/29/16 : 4200 Rail yard
'16 1SS 6M, black with jet black interior, split spoke gray machined faced wheels, and black front/rear bowtie emblems.
My87z28 is offline   Reply With Quote
Old 11-26-2016, 10:15 AM   #12
ender2664
Drives: 2016 2SS
Are there any sensors after the primary cats?
I currently have my mufflers deleted and think the car sounds great! I figure if I run 3inch from the primary cats back it will probably be significantly louder since I gets rid of the secondaries and resonators? (Might start another thread to see if anyone has done this).
Old 11-26-2016, 12:37 PM   #13
Atra
Drives: 16' 1SS M6
I have seen with my own eyes the Blackheart dyno charts. My car has their headers and exhaust so I will soon find out if the claims are true. I have met the head of Blackheart and their engineer-super awesome dudes who are just car guys like us. Dunno why they would have reason to embellish the numbers
Nightfall Grey 1SS 56F Black Bowties
Atra is offline   Reply With Quote
Old 11-26-2016, 12:53 PM   #14
ender2664
Drives: 2016 2SS
Excited to see the numbers!
