Old 11-11-2016, 03:57 PM   #1
oilgear
Drives: Camaro ss, Cadillac, Kawasaki ZRX,
No lift shift on m6
The M6 cars are supposed to have a no lift shift setting for drag racing? Has anyone tried this feature?
oilgear is offline   Reply With Quote
Old 11-11-2016, 04:31 PM   #2
Michigan1LTRS
Blessed ❤️
Michigan1LTRS's Avatar
Drives: 2017 1LT RS I4
http://www.camaro6.com/forums/showthread.php?t=467834
Old 11-11-2016, 06:51 PM   #3
Ian SS
Ian SS's Avatar
Drives: 2016 1SS, 2017 JKU Wrangler
Yes and yes. Works flawlessly.
SLO 1SS - sold
1SS MRC NPP 6MT
2018 Ram Rebel 4x4 5.7
Ian SS is offline   Reply With Quote
Old 11-12-2016, 02:03 PM   #4
Steve 2016 SS
Drives: 2016 Camaro SS
Pedal to the floor!!
Steve 2016 SS is offline   Reply With Quote
Old 02-12-2017, 08:43 PM   #5
KyWildcats
Z Bowman
KyWildcats's Avatar
Drives: 2010 2SS (SOLD), 2016 2SS, 2007 Z71
Mine doesn't like to do it shifting 1 to 2 grind the gears 2-3 3-4 are perfect tho.
2016 2SS M6 Bo White Ported MSD, Bo White Ported TB, Flex Fuel Kit, Drag Pack, Rotofab, Ryan Stevens GPI tune, 15” conversion
Fastest Bolt On N/A M6 Record Holder 11.268 @ 120.268
2010 2SS/RS A6 (sold)Mods: Borla Atak Catback, Stainless Power 1 7/8 Headers, TSP VVT-3 Cam, 3200 Yank Stall, CAI Inake, Ported TB, 18" MT ET STREETS
KyWildcats is offline   Reply With Quote
Old 02-13-2017, 12:39 PM   #6
Corner carver
Corner carver's Avatar
Drives: 2017 Camaro 2.0T RS
Although I haven't updated the thread yet (will confirm info and update in the spring) it was brought to my attention that the no lift shift will work at lower RPMs than the 6000 I orginally thought
FYI I have NOT confirmed the less than 6000rpm info
Old 02-13-2017, 04:56 PM   #7
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
It will work at any rpm basically as long as the throttle is at least 93% floored and you are going over 31 mph according to the stock tune tables. If done right, you should hear a pretty loud "crack/pop" from the exhaust on the shift when it burns off the excess fuel from the no lift shift.
Old 02-13-2017, 06:08 PM   #8
Joe's_cool_1le
Drives: Black 2017 Camaro SS 1LE
lol. I get that crack without doing. I must be a speed shifter!
Or I just have some really bad gas!
Joe's_cool_1le is offline   Reply With Quote
Old 02-14-2017, 11:09 AM   #9
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
No, it's not you...I get it at times too on a high rpm shift. It's the CFCO (clutch fuel cut off) dumping the unneeded fuel as well...the open NPP will make it pretty noticeable when it ignites and gives you those loud crack and pop noises.
First time I heard it, it scared the crap out of me lol...it was loud, almost like a gunshot...yours like that too?
Old 02-14-2017, 12:03 PM   #10
Joe's_cool_1le
Lol. Yeah man I about ducked.
Old 03-04-2017, 10:31 AM   #11
Chevy71
Drives: 2016 2SS
What does the transmission do to avoid slamming your clutch and tranny with that sudden load drop?
Chevy71 is offline   Reply With Quote
Old 03-04-2017, 10:50 AM   #12
You're probably letting out on the clutch too quickly. It should shift just fine.
This feature is on all V8 models.
It just comes natural after a while.
Old 03-11-2017, 08:53 AM   #13
Chevy71
Drives: 2016 2SS
We had three or four warm days in a row here, so Thursday I took my car for a ride. I tried this no lift shift and it felt like I was dumping the clutch on it and broke the tires lose (2nd - 3rd shift). It did not feel like it did anything fuel wise and made no noises. I probably did it wrong, but I left the throttle on the floor.
Old 03-11-2017, 02:00 PM   #14
oilgear
Just have enough brk in miles now to start running harder. Haven't tried the no lift feature yet, but a couple of runs up to 6000, in 1,2nd and 3rd with just a fast lift shift there is a very noticeable delay or pause between shifts. Will this change if I use track mode, and turn off traction control (I was in sport mode)?
