Old 11-04-2016, 06:20 AM   #1
blazzin1
blazzin1's Avatar
Drives: 2010 2SS/RS R6P
Armageddon Twin Turbo?
My buddy is at SEMA right now and sent this pic to me.... Pretty massive set-up!!! Nothing I will ever be able to afford, but pretty cool to look at anyway!!!
blazzin1 is offline   Reply With Quote
Old 11-04-2016, 06:23 AM   #2
JKLNHYD
Defending the Nation...
JKLNHYD's Avatar
Drives: '16 Summit White 2SS, A8, Sunroof
I can't imagine the cost of this setup. I also can't imagine all the other mods you'll need to do to get this power to the pavement. It's almost overkill...
'16 2SS, A8, Sunroof, non-NPP
"SURSUM AB ORDINE"
JKLNHYD is offline   Reply With Quote
Old 11-04-2016, 06:41 AM   #3
blazzin1
blazzin1's Avatar
Absolutely! Like I said, nothing I will EVER be able to afford. Overkill for sure!!! But still, fun to dream about!!!
Old 11-04-2016, 07:09 AM   #4
gunny27
gunny27's Avatar
Why? Because you can!
2016 Red Hot 2SS A8 NPP
Front Chin Extension, Side Skirts, SS center caps, Tint all Lights and reflectors, Window tint 35% sides and back, 50% front. CAI intake, Catch can, Painted the intake cover Red to match
gunny27 is offline   Reply With Quote
Old 11-04-2016, 08:06 AM   #5
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
Check out their youtube channel . Pretty cool setup
Old 11-05-2016, 11:04 PM   #6
EXSSIVE
EXSSIVE's Avatar
Drives: 2016 Camaro 1SS M6
The plumbing of this setup is just horribly over-complicated. Bottom mounts are the way to go. I could see doing a top mount setup for a single but it just doesn't make a lot of sense for twins other than to show them off.
EXSSIVE is offline   Reply With Quote
Old 11-06-2016, 04:22 PM   #7
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
Over-complicated is the key word. Note it says port injection upgrade, so I'm guessing it has duel fuel systems, both direct injection and port injection. Unless they consider removing the more efficient modern direct injection and replacing it with the older port injection systems and calling it an "upgrade". Unfortunately to make this kind of power on a modern engine you have to get pretty complicated... It will be a unique beast when it is done.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 11-06-2016, 04:37 PM   #8
SGDM
SGDM's Avatar
Drives: 2016 2SS
And the heat that this set up will produce in the engine bay...
Who Dares...Wins
SGDM is offline   Reply With Quote
Old 11-06-2016, 04:55 PM   #9
EXSSIVE
EXSSIVE's Avatar
It's running a secondary port injection system to augment the factory DI system. Nothing wrong with this as it's whats needed to get much over the 1k hp mark reliably at this current point in time. It also keeps the off boost drive-ability of a stock vehicle if done correctly.
The heat is a huge issue as well. With the turbo's in the upper engine bay, they will see a lot less air movement than down beside the transmission.
I would be lying to say I didn't have a dog in the fight with my car currently undergoing work as the prototype for On3Performance but that aside, I think they could've found a better solution. It just seems like they wanted them to be top mounted so that everyone could see them.
Old 11-06-2016, 05:21 PM   #10
jessrayo
Speed Freak
jessrayo's Avatar
I know I saw some posts on the On3Performance kit and it looked well executed to me. What are your performance goals for your car? Are you planning on keeping the shortblock stock or are you doing engine work? I would love to drive and data log a dual fuel system on a road course to really test it. I still don't think that is the best but believe me I have been aware of the fuel problems in the LT motors and think it is great that people are finally coming up with some solutions.
Old 11-06-2016, 05:31 PM   #11
EXSSIVE
EXSSIVE's Avatar
Right now, I'm planning on maxing out the stock short block and doing a bunch of different events next year. Once we're done, I'm hoping to pull the engine, do a built, possibly stroked, short block and slowly creep up the power until I'm satisfied, lol.
Old 11-06-2016, 05:56 PM   #12
parish8
Drives: 17 SS a8
The whole duel fuel system isn't anything tricky to set up or tune. Anyone that can install a stand alone ECM and tune that would be able to do it and the driveabilty won't be any more difficult than tuning any stand alone. I like the port injection on this car. The hot parts are what looks busy to me.
