Old 10-23-2016, 06:53 PM   #1
Fast2ss
Drives: 2016 2SS
2016 SS Rubbing Noise
Hi guys I have a 2016 Chevy Camaro 2SS I've only had it 40 days now it has 3300 miles on it and it low speeds when I turn to the left or to the right there's a rubbing noise but it does not appear that the tire is rubbing inside the wheel well at all. Any idea what this could be.
Thanks,
Rich
Fast2ss is offline   Reply With Quote
Old 10-23-2016, 06:56 PM   #2
Genesis7
Drives: 2SS
Yeah I also here this only when the car has just started and is cold, seems to be comming from the steering or suspension, anyone ideas?
Genesis7 is offline   Reply With Quote
Old 10-23-2016, 08:15 PM   #3
Doyal_Mcneff
Drives: 2016 2ss
Could be tire scrub. It's your tire rubbing against the asphalt. Runflats make it more audible and cold weather.
Doyal_Mcneff is offline   Reply With Quote
Old 10-23-2016, 08:21 PM   #4
n813ca
Drives: 2106 SS
My guess it's the rear differential like everyone else
Sent from my SM-G935V using Tapatalk
n813ca is offline   Reply With Quote
Old 10-23-2016, 09:27 PM   #5
Genesis7
Drives: 2SS
No this noise is not from the rubber. clearly not.
Old 10-23-2016, 09:29 PM   #6
n813ca
Drives: 2106 SS
Is it from the front or back
Old 10-23-2016, 09:54 PM   #7
davet435
davet
davet435's Avatar
Drives: 2016 2SS Mosaic Black
Send a message via Yahoo to davet435
It's the differential believe me. It sounded like my RF tire was rubbing when mine started.
For your reading pleasure: http://www.camaro6.com/forums/showthread.php?t=440272
Replacement car ordered 2/02/2016
2/03/16 2500
2/04/16 3000 no TPW
2/8/16 3000 TPW 2/29
2/18/16 3400
3/3/16 3800
3/4/16 4B00
3/5/16 4300
3/7/16 4200!!!
davet435 is offline   Reply With Quote
Old 10-23-2016, 09:55 PM   #8
n813ca
Drives: 2106 SS
I totally agree
Old 10-23-2016, 10:00 PM   #9
davet435
davet
davet435's Avatar
Seeing more and more of these. Wouldn't be surprised to see this one end up a recall. Especially when the rear end can lock up while driving.
2/03/16 2500
2/04/16 3000 no TPW
2/18/16 3400
3/3/16 3800
3/4/16 4B00
3/5/16 4300
3/7/16 4200!!!
Old 10-23-2016, 10:01 PM   #10
n813ca
Drives: 2106 SS
Totally agree
Old 11-02-2016, 08:47 PM   #11
Adrian97c
Adrian97c's Avatar
Drives: Wife's 14' IS 250
I heard this 3 mornings in a row... hasn't come back, but being that it just randonlmly happened at 10k miles, I expect to happen again... but trying to have a tech "replicate it" will be impossible.
-11% tint all around
Ordered • 2/06/16
Built on • 3/22/16
Adopted • 4/07/16
Sold on 2/05/16:
-Borla ATAK catback
-Range AFM delete
-15% tint all around
-Red LED interior bulbs
-55k white Cree LED fogs
-License plate LED bulb swap
-12" Sub Kit, BA amp swap
Adrian97c is offline   Reply With Quote
Old 11-02-2016, 09:52 PM   #12
sub_ETCS_ret
sub_ETCS_ret's Avatar
Drives: 2019 Dodge Challenger Scat Pack
Could it be this?
http://www.camaro6.com/forums/showthread.php?t=468879
"Submariners are a bunch of intelligent misfits that somehow seem to get along, understand each other and work well together." - overheard from a surface officer explaining to another sailor about Submariners
sub_ETCS_ret is offline   Reply With Quote
Old 11-04-2016, 10:28 AM   #13
zetatl
Drives: 2016 Blue Velvet 2SS
I was hearing a "clicking" noise from the front left wheel as well. Brought mine to the dealer and they had to remount and clean the tire/wheel and its been fine since.
It sounded almost like driving over leaves at slow speeds, especially noticeable turning hard left.
zetatl is offline   Reply With Quote
Old 11-04-2016, 05:52 PM   #14
davet435
davet
davet435's Avatar
Originally Posted by sub_ETCS_ret View Post
I know that isn't what's going on with mine. Mine only does it when turning. The more you accelerate when turning the worse it gets. It started only when turning left. Now it does it turning both directions and it's doing it for a longer amount of time before it finally goes away. Went to the dealership and told him I was having the problem and asked him to check the rear end fluid for metal shavings. He told me he would have to charge me to check it. That's our local Chevy dealer. I can't stand those &$?!/ (/&$!?. I just turned around and walked out. Not even worth my time to argue with them over such a little thing.
2/03/16 2500
2/04/16 3000 no TPW
2/18/16 3400
3/3/16 3800
3/4/16 4B00
3/5/16 4300
3/7/16 4200!!!
