Old 10-03-2016, 10:20 PM   #1
sub_ETCS_ret
sub_ETCS_ret's Avatar
Drives: 2019 Dodge Challenger Scat Pack
**Fixed** - Vibration under light acceleration
I read all the vibration threads and none seem to match what I'm hearing.
From a stop, and under light acceleration up to 5mph, I hear a vibration and then it goes away. I was also able to make it happen from a 35mph coast with light acceleration. I can feel the vibration at my feet but with a cursory look under the car nothing jumps out at me. I can see the heat shields and was thinking that it might be a harmonic vibration.
After checking the npp rattle threads, I'm fairly positive that not the issue.
If anyone knows of anything to check I would appreciate the info.
"Submariners are a bunch of intelligent misfits that somehow seem to get along, understand each other and work well together." - overheard from a surface officer explaining to another sailor about Submariners
sub_ETCS_ret is offline   Reply With Quote
Old 10-04-2016, 06:53 AM   #2
Slem
Slem's Avatar
Drives: 2016 Summit White 2SS (Auto) Loaded
Does this vibration happen all the time or does it go away after driving your vehicle for bit?
Slem is offline   Reply With Quote
Old 10-04-2016, 07:04 AM   #3
sub_ETCS_ret
All the time. Warm, cold, v4, v8. It really sounds like somethings loose. I'm going to get under the car today. There is a lot of aluminum under there, maybe something's loose.
Sent from my SM-G920V using Tapatalk
Old 10-04-2016, 07:24 AM   #4
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
If it is pretty much just till 5mph I am going to guess it is a harmonic thing, like a loose heat shield or something. That is too slow of a speed for it to be something more major...since you say after 5mph it goes away?
You said you HEAR it, usually you FEEL a vibration, so it's hard to say...
Old 10-04-2016, 08:09 AM   #5
sub_ETCS_ret
I feel at my feet too. It's probably a heat shield. I'll find. I was just curious if others might have it as well. Usually I have my music up loud enough that those kinds of things aren't heard but once you hear it, you can't unhear it or unfeel it.
Old 10-04-2016, 10:40 AM   #6
sub_ETCS_ret
Originally Posted by CreativeDawn View Post
I have a vibration when I'm in 1st and go to about 4000rpm's it gets realllllllllllllllly loud in the front of the dash ...I'll have to record it.
That's loud. I'm not sure I could actually record mine. Getting under it in about an hour. Hopefully I'll find it.
Old 10-04-2016, 01:53 PM   #7
sub_ETCS_ret
Found the problem. On the driver's side of the transmission is a shield protecting a cable. It also happens to be right below the driver's feet. One of the bolts was over tightened causing the shield to rest right on the transmission. Under light acceleration it was vibrating on the transmission and feeding up through the floor.
Old 10-04-2016, 02:35 PM   #8
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Nice find, all fixed then?
Old 10-04-2016, 02:40 PM   #9
sub_ETCS_ret
Yep. 10mm socket and all is good.
Old 10-04-2016, 06:47 PM   #10
Slem
Slem's Avatar
Awesome sub, glad you figured it out and thanks for the pics , things like this can potentially help others with the same complaint as you had. Well done.
Old 10-04-2016, 07:16 PM   #11
sub_ETCS_ret
Pictures on this site have helped me with other things. I thought it was only right to post my fix.
Old 10-05-2016, 10:08 AM   #12
jdasnt3
jdasnt3's Avatar
Drives: 18 Silverado 1500
Who knows, with its location to the engine compartment, it might have caused a little "false knock" and reduced your power. Great find and fix!
Old 10-16-2016, 05:03 PM   #13
Feefsmaro93
Drives: 2016 white 1ss A8
Does the 2.0t have this bracket/ shield because i have the same vibration but doesnt affect performenacr
Feefsmaro93 is offline   Reply With Quote
Old 10-16-2016, 05:32 PM   #14
Doyal_Mcneff
Drives: 2016 2ss
Thanks! This was driving me crazy. How much did you have to
loosen it?
Doyal_Mcneff is offline   Reply With Quote
