Drives: 2SS Join Date: Sep 2016
Weird...
When I change my exhaust mode from stealth to track or sport I hear a squeaking noise comming from the exhaust pipes.. is it normal?? its ****ing loud and you can here from inside of the car!
Dam Chevy ****ing build quality... ![]() Anyone has any thoughts? please...? |
![]() Drives: 2016 Camaro SS Join Date: Jul 2016
Mine does it too. Its just the valves opening and closing
Well now the fun begins, you get to fix it. It's just one of the valves rubbing on the inside of the pipe. If you don't have the tools, take it to a muffler shop. If you were closer, bring it over.
![]() ![]() Drives: future 2016 SS Join Date: Sep 2015
This is part of the valve rattle and squeak so often discussed.
![]() Drives: 2016 Camaro 2SS Join Date: Feb 2016
Very familiar with it, the Dealer replaced my entire exhaust to correct the problem after trying to lube the NPP valves.
#7 | |
Drives: 2017 Camaro 2SS 6MT Join Date: Aug 2006
Hell I wouldn't take it to a "muffler" shop even after the warranty. It ain't a $90.00 muffler special. I seriously doubt a single 6th gen on American roads has yet to exceed its 36,000 mile warranty. |
#8 |
![]() Drives: 2016 Summit White 2SS (Auto) Loaded Join Date: Jul 2016
There is a procedure to correct this problem by lubricating all 4 valves.... there is a detailed post on this site showing the procedure
#9 | |
When your car is under warranty documentation of every little thing is very important. |
#10 |
The BEAST
Drives: '16 2SS, '89 Wife Join Date: May 2015
Here's the fix, so damn easy... don't bother with the dealer visit, its a dry squeak, not a big deal. the valves aren't rubbing, its more than likely the inner springs.
http://www.camaro6.com/forums/attach...5&d=1459299075 for a squeak? did he lube it thru the holes or inside the pipe where the valves are? a replacement for that seems like too much unless the valves were sticking shut/open ; I doubt he lubed it right.
#11 | |
Which is why you should take it to the dealer. He got a new exhaust out of that. I fail to see the problem you make it out to be. When it's out of warranty do whatever you want. But even for the most seemingly simple and basic issues, while under warranty take it to the dealer. |
#12 |
![]() Drives: 2017 Camaro 2SS Convertible Join Date: Jun 2016
GM doesn't build Exhaust Systems, they buy and ASSEMBLE them. You need to complain about the supplier...
2SS Convertible, Mosaic Black, Red Hashmark, Adrenaline Red Interior, A8, NPP, MRC, 56R Wheels 6/6/2016 Dealer entered order 6/7/2016 Received order # TMXWV0 - Status 1100 6/11/2016 Status 3000 6/22/2016 Status 3400 - TPW 6/27 6/29/2016 My car is born!! 7/13/2016 Status 4300 7/14/2016 Status 4B00 7/18/2016 Status 4200 7/25/2016 Status 4800 7/29/2016 Status 5000 - Drove home!! |
#13 | |
The BEAST
just a waste, but to each their own. The squeak will return, just a matter when. nothing stays lubed forever really
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
...So now if someone is advised to "lube their muffler bearings", it is to be taken seriously?
My, how things have changed....lol... |
