Old 10-08-2016, 09:36 AM   #1
Eos
Eos's Avatar
Drives: Camaro Coupé 2.0T AT8 (EU version)
4 tips exhaust on 2.0 Turbo?
Hi there!,
I was wondering if someone knows how to go from a dual single-tip exhaust (standard) to the much better looking 4 tips exhaust as seen on the V8 SS versions.
Playing with the Camaro application it shows this possibility on the configurator, but I didn't hear anything about it as a regular Chevrolet option nor as an aftermarket accessory.
Got clues?
See you!!,
Eos
Eos is offline   Reply With Quote
Old 10-08-2016, 09:39 AM   #2
Michigan1LTRS
Blessed ❤️
Michigan1LTRS's Avatar
Drives: 2017 1LT RS I4
The only way I know as of now is to order the NPP rear fascia and then buy the dual tips to replace your single tips.
Old 10-08-2016, 09:48 AM   #3
Eos
Eos's Avatar
Hi!,
Thank you for your answer. Yes, I know the rear lower facia will have to be changed, but do you know if the current tips are simply on with screws or it should be going under some professional modification (such as cutting and soldering)?
See you!,
Eos
Old 10-08-2016, 09:59 AM   #4
Michigan1LTRS
Blessed ❤️
The tips will need to be cutoff and new tips welded in.
Old 10-08-2016, 09:05 PM   #5
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
Old 10-10-2016, 11:41 AM   #6
Adp2017
Adp2017's Avatar
Drives: 2017 RS Turbo
Originally Posted by Eos View Post
Hi there!,
Got clues?
See you!!,
Eos
Milan, Italy! I would love to see some pictures of your car with Italian backdrop. You must get a lot of looks driving a Camaro around those tiny roads. Kudos for supporting the European GM division.
Adp2017 is offline   Reply With Quote
Old 10-10-2016, 11:57 AM   #7
Evil-Bee-NH
603 Camaros
+1
Old 10-11-2016, 03:06 AM   #8
Eos
Eos's Avatar
Well.. I will tell you as soon as the car will be delivered to me!!
As far as I know, it should be on its way from Michigan to the harbor in Northern Europe where it should be custom cleared and (finally!) come to Italy..
I'll take some pictures and post them, Adp2017!
See you!!,
Eos
Old 10-11-2016, 05:51 PM   #9
Adp2017
Adp2017's Avatar
See you!!,
Eos
I look forward to it!!
