Old 09-01-2016, 03:28 PM   #1
devsfan1830
Drives: 2016 Camaro LT - Blue Velvet
Anyone try routing a dash cam power cord around to the lighter outlet?
Previously tried hard wiring a dash cam (Z-Edge) to my 2016 Camaro using this guide: http://www.camaro6.com/forums/showthread.php?t=439766
Worked great but I immediately saw TPMS sensor loss in my front tires. Ripped all of it out and the issues were gone and have been gone for some time. I just decided to try out an alternate brand of camera, a Vantrue R2. This time I would like to avoid hardwiring again since I now suspect that the hardwire kits may have been the culprit throwing off excessive RF interference.
So I think I'm going to stick to using the included power plug with the camera. It has a super long cable for routing around the windshield but I was hoping someone has had some experience doing this already and had anytime to make the core as invisible as possible. I know I can tuck a cord into the headliner rather easy. Its the side pillars and under the dash that have me worried really.
devsfan1830 is offline   Reply With Quote
Old 09-01-2016, 04:28 PM   #2
MGD
MGD's Avatar
Drives: 16 Camaro SS
Try this instead the BCM hook up.
http://www.camaro6.com/forums/showthread.php?t=440254
I have it installed that way and never had any problems with it. Get you one of those converters and hook it up to the switched power in the overhead console. The converter hides in the console.
http://www.ebay.com/itm/Generic-12v-...1%26rkt%3D1%26
Interior: Adrenaline Red. SS/2SS, M6, NPP, Sun Roof, 8" Nav. Black 5 Spoke Wheels.
MGD is offline   Reply With Quote
Old 09-01-2016, 04:53 PM   #3
devsfan1830
Thanks. That's basically what I tried last time. Only with a different converter: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
When the TPMS issues started I tried fiddling with it and lost the blue clip in that plug down the center console. Cost me 75 bucks to buy an entire wire harness from a GM parts shop to replace it. In the end I don't even know what interfered. I was just so pissed off over losing that clip I just sent the camera back and threw out the converter. So you can imagine why I'm not TOO keen on trying that again unless there is an overwhelming group of people that have a converter that doesn't interfere.
Old 09-01-2016, 07:01 PM   #4
leadfoot93
Camaro Fan
leadfoot93's Avatar
Drives: 2016 Camaro 1SS Garnet Red
I needed a always on power source for mine since I was doing motion detection. I ran mine out to the front fuse box. I came down the front passenger side pillar, to the door, then through the quarter panel to the front of the car. When you close the door it doesn't pinch the wire. Unless you are looking at the door hinge when you open the door you will never see it. If you want to see a picture of it let me know.
I would have used the overhead light there but I had already did my radar detector there for the switched power. and didn't want to have too many things hard wired in there.
Ordered: Garnet Red Tint coat 2016 Chevrolet Camaro 1SS, Auto, NPP
1100 Status: 8/6/15
3800 Status: 10/13/15 VIN #116519
4200 Status: 12/19/15
Delivered : 12/28/15
leadfoot93 is offline   Reply With Quote
Old 09-01-2016, 08:25 PM   #5
Com69
Drives: 2016 Camaro 2SS 6M Nightfall Gray
If the cable is long enough, run it to the rear fuse box and add a BPD device. I have 4 cams, all routed to the rear, it's a lot easier than it sounds, I promise. Both pieces of the back seat pop out, so tucking the cord away is super easy.
Com69 is offline   Reply With Quote
Old 09-03-2016, 01:11 PM   #6
Allez
Allez's Avatar
Sounds like what I'd like to do. Any pics you could post would be greatly appreciated.
Allez is offline   Reply With Quote
Old 09-04-2016, 01:25 AM   #7
leadfoot93
Camaro Fan
leadfoot93's Avatar
I will take and post some pics tomorrow
1100 Status: 8/6/15
