Old 02-13-2016, 01:45 PM   #1
tejesh83
Guide: How-to Hard Wire Radar Radar Detector
I hard wired my Escort Max 2 Radar Detector this morning. Here's a quick guide. Special thanks to forum member 2SSRS@Gen5diy for finding a switched 12V source in the console.
Originally Posted by 2SSRS@Gen5diy View Post
Pulled out my overhead console in the 2SS, so this may not work for your car, if you use the PU/W color wire from the rear connector, that wire is switched, here are some pics.
Now for the install:
  1. Pry the corners of the console. I used a plastic putty knife and a rag over the mirror to avoid damaging any trim.
    Name:  Step 1 pry.jpg
  2. Next, pry the center of the console. The console clips should now be loose, so give it a firm tug and the console should free up. Disconnect all wires and set the console aside.
    Name:  Step 2 pry more.jpg
  3. Route your power cable from the windshield, through the headliner, and grab it from the console opening. You can buy a fused mirror tap to save time (http://www.mirrortap.com/mt2000.html#Micro). I made my own out of an old telephone cord and a soldering iron.
    Name:  Step 3 route wire strip solder.jpg
  4. On the back of the plug that feeds the airbag light, tap the Purple/White (+12V) and Black (-GND) wires. Now's a good time to check the wiring with a meter and confirm your radar powers up. Make sure you start the car for your testing. I learned the hard way this wouldn't turn on with accessory power =)
    Name:  Step 4 tap purplewhite and black wire.jpg
  5. Press the wire taps firmly into back of the plug and use a zip tie and electrical tape to secure it in place.
    Name:  Step 5 zip tie and electrical tape.jpg
Finished results:
Name:  install interior.jpg
Name:  install exterior.jpg
2016 2SS - Summit White - MT - NPP - MRC - NAV
tejesh83 is offline   Reply With Quote
Old 02-13-2016, 04:15 PM   #2
tecboy
tecboy's Avatar
thanks for the write up...working on this myself.....the plug with these wires....what is the trick to get it to release from its socket?
2016 Black 2SS A8 NPP Sunroof - Tinted Windows - Black Chrome Wheels - Custom Striping - ASC Sideskirts/Splitter - GM Lowering Kit - Complete Sound System - DD LED Sidemarkers
tecboy is offline   Reply With Quote
Old 02-13-2016, 09:37 PM   #3
tejesh83
I used a flat head screwdriver. If you look at the image in step 4 above, place the screwdriver on the center white ridge, near the red clip. Push in and using the socket as leverage, give the screwdriver a little nudge/twist and it should slide right out.
Old 02-14-2016, 06:20 AM   #4
tecboy
tecboy's Avatar
I see what appears to be a notch in the white socket in the center...when you say push in and give a little twist...am i pushing the screw driver "under"(front to back in pic 4) the red part and twisting the red section up or is the screwdriver being put in the notch (top to bottom in pic 4) upright and releasing something on the front white portion..
I got as far as 2 map light plugs disconnected...its hard to see up in there to get a precise way to disconnect all the sockets
did you use actual taps into the socket or splice to the actual wire?
Old 02-14-2016, 08:34 AM   #5
Tr6
The Dogfather
Drives: #1 off the line for a customer. '16
Thank you for the fantastic guide! Much appreciate it! If you could post it up under the How To sub section, that would be fantastic! If you don't want to, I would be more than happy to do it for you.
2SS, Garnet Red with Adrenalin red, NPP, MRC M6 coupe
#33 off the line #1 order for Customer.
Build thread HERE!
Story of my delivery HERE!
Tr6 is offline   Reply With Quote
Old 02-14-2016, 08:37 AM   #6
tecboy
tecboy's Avatar
I ended up getting all plugs disconnected...took a little doing to figure out best position for the taps so that they actually stayed in..but all is well and detector installed...thanks again for your write up
Old 02-14-2016, 07:45 PM   #7
tejesh83
I'm not seeing an option to move the thread. Can you or moderator help move the thread?
I'm glad it helped.
For the taps, I stripped an old telephone cord (about a 1/4") and put some solder on the red and green wires (center pins on my cord) to make them thicker/stiffer. I stuffed the wires behind the plug, making sure they made contact with metal crimps inside the plug. The telephone cord wire was a little flimsy, so I used a push pin to help seat them firmly.
Old 02-14-2016, 09:59 PM   #8
Tr6
The Dogfather
I'm glad it helped.
Thanks a mill for the guide again and don't worry about it. I got it taken care of for you!
http://www.camaro6.com/forums/showth...64#post8903964
Build thread HERE!
Old 02-14-2016, 10:08 PM   #9
jimmypop13
Drives: 2016 camaro ss
How do you tap wires in the socket? I guess I don't understand what you did. I can't tell from the pics what wires go to the radar detector and what don't. Did you buy taps? Do u have a link?
2016 camaro 2SS hyper blue/Kalahari, A8, MRC, NPP, sunroof, SW headers through axleback, Circle D 3600rpm TC, Pray ported IM/TB, E85
Sold: 2002 Z28, NBM, M6, 460rwhp, 2009 HHR SS
RIP : 2002 WS6 Black, A4, 355rwhp
jimmypop13 is offline   Reply With Quote
Old 02-15-2016, 07:48 PM   #10
tejesh83
You could use something like this: http://www.mirrortap.com/mt2000.html#Micro
But, I just made my own out of an old phone cord. In step 4, if you follow the wires closely, I took the red wire from the telephone cord and stuffed it behind the pin socket for the Purple/White wire of the airbag light and I took the green wire from the telephone cored and stuffed it behind the pin socket for the black wire.
I've attached some stock images from mirrortap.com that do a better job of describing how the the taps work. Its basically a pin that you wedge behind the plug/socket. It makes contact with the stock plug's wire crimps.
If you prefer, you could just use a standard wire tap as well. I've never personally used them and prefer to solder/splice instead. But if you insist on a tap, something like this should work: http://www.autozone.com/ignition/ele...?checkfit=true
Old 03-07-2016, 01:02 AM   #11
usmcfiredog
Drives: 2016 Black 2SS
Has anyone used the mirror tap shown above? When I tried I could not get it to stay especially because the distance is so short when using the mirror mount. Any suggestions?
Camaro 2SS
Black/Jet Black
A8, NPP, MRC, NAV
Low Gloss Black 5 Spoke
usmcfiredog is offline   Reply With Quote
Old 03-11-2016, 12:21 PM   #12
stella16
1959 Chevy Apache 4X4
stella16's Avatar
Drives: 2017 ZL1
nice write up !
I have considered hard wiring mine. Escort sells a kit.
A couple of questions:
I like having mine mounted lower, closer to the dash. Is it a tough adjustment having it mounted so high up?
I also like being able to mute it from the power cord. It's down low and a pretty natural reach. Have you considered mounting the escort live module somewhere?
https://www.escortradar.com/store/ESCORT-Live-Android/
stella16 is offline   Reply With Quote
Old 03-11-2016, 01:11 PM   #13
tecboy
tecboy's Avatar
I bought the mirror tap cable...also found it too short...I was disappointed ...what i ended up doing was cutting the plug off the end of the mirror tap cable...then took a phone cable...cut to length i wanted..then soldered to mirror tap cable...i wire tied the mirror tap cable real well...this way if the mount comes loose from windshield...it doesnt pull the taps out....I had the detector tear the rj11 plug off the cable when this has happened....when/if that happens again...i can easily solder a replacement phone cable in place vs taking everything back apart and reinsert the taps in to the socket
Old 03-16-2016, 10:53 PM   #14
usmcfiredog
Originally Posted by stella16 View Post
nice write up !
I have considered it but I don't feel like tearing the car all apart to run the escort wires
Camaro 2SS
Black/Jet Black
A8, NPP, MRC, NAV
