Old 08-16-2016, 12:15 PM   #1
fzr100098
Drives: 2016 2SS Hyper Blue
A8 Competition Mode
If you haven't tried it yet, you need to - now THAT is how an automatic is supposed to shift! Quick downshifts with rev match are bad ass, no way a manual can match that speed (up or down)
Best morning commute I've ever had, this car is awesome
fzr100098 is offline   Reply With Quote
Old 08-16-2016, 12:50 PM   #2
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
It's on another thread.
Try this - track mode with competitive selected.
Leave in D - punch down hard a few times on the gas pedal. It will then select performance shifter mode automatically. It will aggressively down shift and up shift. Enjoy the ride.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 08-16-2016, 12:54 PM   #3
R3DLT1
Toyota Tech
R3DLT1's Avatar
Drives: 2SS A8
This!
2016 Camaro SS A8 Roto-Fab CAI: Drag set up 11.9 @116
Sold 95 Camaro Z28 Cam:Bolt ons: 12.3 @114
Sold 2013 Chevy Crzue LTX
R3DLT1 is offline   Reply With Quote
Old 08-16-2016, 12:56 PM   #4
KMPrenger
KMPrenger's Avatar
Unfortunately, I see a auto vs manual thread coming since you just basically called out the manual folks.
But before that happens....
Was you in manual mode or auto?
I found out that if you are in manual mode and hold down on the shift down button continuously, it will then shift down automatically into the lowest gear possible. Pretty cool for those times you might be cruising along on the highway, and then want to nail it.
But I haven't gotten to try the performance shifting in track mode yet. I want to do that very much!
Do I just put it in track mode and then punch the gas to the floor a couple times, or what?
Old 08-16-2016, 01:05 PM   #5
Emoto
Sure, why not?
Emoto's Avatar
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon
Is competition mode only accessible when the car is in Track Mode, or can you get it while in other modes?
Emoto is offline   Reply With Quote
Old 08-16-2016, 01:06 PM   #6
fzr100098
Sport or Track - just double tap the traction control button and pops up on the main screen, no need to punch down on gas pedal etc
I left it in drive/auto mode - terrified a few ricers - huge fun
Old 08-16-2016, 01:12 PM   #7
Emoto
Sure, why not?
Emoto's Avatar
Thanks much!
BTW, those old FZR1000s were awesome bikes!
Old 08-16-2016, 01:15 PM   #8
HumanWiki
Drives: Car
Sport or Track mode, in D and then it will detect assertive drive habits. You will know when it's active because you'll get a message in the DIC saying Performance Shift Mode active and you'll notice very easily it holds gears longer up and down the RPM range. Even when braking hard, it will hold the RPMs up each gear down. Just romp on it a couple times. Usually for me, it needs to be a punch and lane change as it'll detect steering input and throttle changes.
You can pull the paddle shifter up a gear to exit or drive calmly for ~8s or more and it'll exit.
Driving this car, at least the A8 versions, around in Tour mode you'll feel it's a wee sluggish to shift, loosely steered and the throttle map is very averaged out. It's a much more responsive car in S and then again in Tr. Though, unless you manually change your steering, you'll find that Tr mode a slow/stopped wheel input will be a decent amount of effort if you're used to Tour.
I actually tinker with various custom modes.. Like, you have have Sport MRC, with Tour Steering and have it in Track mode for the rest. It doesn't beat you to death, it has light input, but the throttle and shifting are much more in line with what I like. However, just know that PSM will kick in sometimes when you don't want it.. and you'll have a high RPM revving engine that seems stalled here for a bit unless you manually exit it.
HumanWiki is offline   Reply With Quote
Old 08-16-2016, 01:18 PM   #9
BlackbeastSS2
If you want performance shifter mode right away when your cruising at any speed you do have to stomp on the gas pedal to get it right away. Or, you have to start driving aggressively and it will kick in at some point.
Old 08-16-2016, 01:20 PM   #10
KMPrenger
KMPrenger's Avatar
Thanks. I assumed it would automatically go into performance shift mode if I drove it aggressively....my 2010 did that. I just wasn't sure of how to get this car to go into the mode without having to first drive like a bat out of hell lol.
I think fzr100098 answered my question above.
Old 08-16-2016, 01:22 PM   #11
R3DLT1
Toyota Tech
R3DLT1's Avatar
Drives: 2SS A8
I notice you have to be above 40mph for it to work.
Old 08-16-2016, 01:22 PM   #12
HumanWiki
Drives: Car
Is that competition mode or performance shift mode?
I know comp mode is entered with a dbl tap of the TCS button. But I thought that perf shift mode was only entered with assertive driving and it will exit after a bit on its own if you slow up.
We've got two different modes in play here in the thread. Making sure I'm replying to the right ones as they're different modes.
Old 08-16-2016, 01:24 PM   #13
JaxChris
I accidentally came across it when in Track Mode. Have not been able to duplicate in Sport Mode. I did not have Competitive Mode on at that time as I didn't know it existed yet.
The DIC will display "Performance Shift Active" when this additional item is triggered. From there, your RPM's will not drop below 3k. I can see where finding a way to trigger this in advance would be useful for track days in the A8. Really helps you power through a corner when I did accidentally trigger it.
GM should just make a video tutorial on all these features and how to activate them. It is like a new easter egg I find each time I play with it.
Old 08-16-2016, 01:26 PM   #14
HumanWiki
Drives: Car
It's called out on Pg 210 in the owner's manual.
"Performance Shifting
While driving in Sport Mode (V6), or Sport Mode and Track Mode (V8), if Tap Shift has not been activated, the transmission determines when the vehicle is being driven in a competitive manner. The transmission may remain in a gear longer than it would in the normal driving mode based on throttle input and vehicle lateral acceleration. If there is a rapid reduction in throttle from a heavy throttle position at high rpm,
the transmission will maintain the current gear up to near redline rpm. While braking, the transmission will automatically downshift to the next lower gear keeping engine speed above approximately 3000 rpm.
If the vehicle is then driven for a short time at a steady speed, and without high cornering loads, the transmission will upshift one gear at a time, until 8 (Eighth) gear. After shifting to 8 (Eighth) gear, or coming
to a complete stop, the transmission will return to normal Sport Mode shifting."
