![]() Drives: 2016 M6 Hyper Blue 2SS Join Date: May 2016
Cluster Gauges
I am not sure if they has been brought up at all, I searched and got nada.
So in the owners manual I noticed on Page 106 and 107 it has a boost gauge and the more you read a few other gauges. It says its all available on the up level Cluster, which the SS has (correct me if I am wrong). Can we change the gauge layout? I am pretty positive that we can not, and I would assume that the Boost Gauge will be for the ZL1? So its all possibly built in the programming? Edit: Okay after reading it looks like it is possible. I am not to sure as im at work and the car is at home. |
Sure, why not?
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon Join Date: Mar 2015
I wondered the same thing after browsing the manual. Life has been so busy that I haven't spent much time trying to figure it out. Please post if you do!
Retired from Car mfrs....
The actual gauge positions and functions are fixed, unlike the new Vette.
A Heartbeat Away.........
Drives: Not As Fast As I Would Like To Join Date: Mar 2016
Can't be positive but I believe the boost gauge is on the turbo only. Looked through all the menus and couldn't find it on my car.
2016 Hyper Blue Metallic 2SS | A8 | MRC | Sunroof | Nav | Mishimoto Catch Can | GM CAI | Hurst Shifter | Borla S-Type Exhaust | Body Color Splash Guards | 1LE Splitter | GM Dark Tail Lights | ZL1 Third Brake Light | Custom Fuel Door, Badges & Bowties | Oracle Side Markers | Blacked Out Stuff | Opti-Coat Pro+ The problem with this world is stupidity. I'm not saying there should be penalties for stupidity, but why don't we just take the warning labels off everything and let the problem solve itself. |
#5 | |
I figured as much. Makes you wonder if the software could be tweaked. I wonder if all of their software is Open Source? |
![]() Drives: Corvette 3LT Silver/two tone Red Join Date: Feb 2016
Boost Gauge is only in 2.0 Turbo. You will not see it in SS. Only on 1LT and 2LT with 2.0
2LT 2.0L, NFG/Kalahari, RTH-Black wheels , RS, ZN2, Y4Q, MX0, PCL 5/17 6000 5/9 5000 5/9 4B00 5/6 4800 5/5 Depart Thermal, CA; Arrived –Mira Loma, CA; pulled from customer –Mira Loma, CA; 5/4 Depart Carrizozo, NM 5/3 Depart Herington, KS 5/2 Depart: Hannibal, MO: Union Grove, Il: Beverly, IA 4/30 Arrive In Transit -Gibson, IN 4/29 Departure Battle Creek, MI 4/28 "bad order" Battle Creek MI; Mechanical problem with railcar 4/27 Departure -Charlotte, MI " 4200 4/12 4B00 4/9 3800 Built & VINed 4/1 3400;3/31 3300;3/12 3000 TPW 4/11 3/9 3000;3/3 2000;2/29 1100 |
#7 |
Pills are for Pansies
Drives: 2023 2SS Red Hot Vert Camaro Join Date: Jul 2008
How do we change the gauge themes (Technology, etc). I did it last week & forgot how. I couldn't find it in the manual.
#8 |
![]() Drives: 2016 Black 2SS Join Date: Feb 2016
hit the left arrow on the steering wheel scroll down to settings and then scroll to theme and change it.
Camaro 2SS
Black/Jet Black A8, NPP, MRC, NAV Low Gloss Black 5 Spoke |
#9 | |
![]() Drives: 16 2SS Convertible, 08 JKU Join Date: Jan 2016
The OS is a version QNX--- a type of unix OS for embedded applications.
'16 2SS Convertible - Blue Velvet, 6M, MRC, NPP, 56R, Nav, Ash Gray, & Silver Rally.
'08 Rubicon JKU - Jeep Green, 6 spd, 5" Terraflex, LoD Off-road armor, Warne 9.5, 4.88 gears, 37x12.5R17 |
#10 | |
Defending the Nation...
Drives: '16 Summit White 2SS, A8, Sunroof Join Date: Dec 2009
^^^This.
'16 2SS, A8, Sunroof, non-NPP "SURSUM AB ORDINE" |
#11 | |
I don't know about Boost, but you can definitely change the cluster. You can change between Standard, which shows the 4 clusters at the top, Technology or Media.
On the Steering wheel hit the left arrow button & then scroll down to Settings. I think it's the 2nd screen (press down arrow to see options) and it's called Display Theme or something - once on this hit the right arrow on the steering wheel and it'll bring up the options for Standard, Technology or Media - when you select one it takes a few seconds to be a little patient for it to change. Also, in the Settings if you scroll through you'll see something that's 6 or 7 pages or something like that. When you're on this screen hit the right arrow and it'll show you a list that's something like Info, Performance, etc. For instance, if you select Performance it'll list all of the screens that are available for you to be able to see on your display in front of the steering wheel. The ones that are already available for you to see are in blue & the ones that are currently not setup to be shown to you are in white, so if there are any that you want that are in white then you'll need to select them (do the same thing for Info any other other options that are listed). Then, once you go back to the Performance page, the new windows that you selected should be in the list for you now. This video actually shows you what I'm talking about.
2016 Camaro 2SS, Silver Metallic, A8, NPP, NAV, Black Interior
Mods: MRR 228 Glossy Black Rims: 20x10 & 20x11 (stock tires), Body Spear Stripes, Black Bowties & Smoked/Tinted Lights by Big Worm Graphix (Head, Tail, Side Markers, Rear Reflectors & 3rd Brake Light) Upcoming Mods: Window Tint, Black GM Splitter & Black Rocker Panels |
#12 | |||
When you have the top level Cluster you have all the gauges, but GM does not allow you to change the OS on the board, its pre programed but the rest are there. Quote:
not open Source.good info. |
#13 | |
![]() Drives: 2017 2SS Fifty 6spd NPP Join Date: Sep 2016
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Camaro 1LT Join Date: Jan 2016
gotta have some reason to buy a vette.
