Old 05-14-2016, 07:37 PM   #1
Jkfsu
Drives: 2016 5.0
How to race from a roll?
New to this car but let's say I'm doing a 40 mph roll. Do I put the shifter in manual in 2nd then hit it and switch to drive? I ask because the car doesn't shift on its own in manual mode and I hit the rev limiter.
Jkfsu is offline   Reply With Quote
Old 05-14-2016, 07:42 PM   #2
Zeke.Malvo
Zeke.Malvo's Avatar
Drives: 1969 Mustang MaCh1
You shouldn't be street racing.
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtq
T56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear
Zeke.Malvo is offline   Reply With Quote
Old 05-14-2016, 08:24 PM   #3
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
I'm assuming auto, how bout you leave it in Drive and punch it?
Old 05-14-2016, 08:32 PM   #4
ULTRAZLS1
ULTRAZLS1's Avatar
The slight downshift delay from a roll could cost one the race. I know what he's saying and I'm wondering the same.
Old 05-14-2016, 08:41 PM   #5
SuperSound
SuperSound's Avatar
Even when performance shift mode is active? If that split second delay is going to cost you the race the cars are identical or they were going to win anyway. I know you can also pull the downshift paddle for 2 secs(?) and it will initiate a maximum downshift on the C7, believe it's the same on the Camaro. Not sure if it stays in Manual mode at that point but probably does. Really if you are splitting hairs like this roll racing, you need to practice and a shift light set to the ideal time to execute a manual shift.
Old 05-14-2016, 08:49 PM   #6
ULTRAZLS1
ULTRAZLS1's Avatar
I'm not sure. I've just had one 10 minute test drive with a new SS. Felt almost as fast as my modded 2010 and I was sold lol.
I figured if I couldn't figure it out I'd put the pedal down soon after the second honk lol
Might only be a split second but a lot of people leave early as well... Further compounding the slight delay...
Old 05-14-2016, 08:53 PM   #7
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
Is 40 Mph where the car would already be out of 1st gear at 6500 rpm? if it is than your at the bottom of 2nd gear range. either go off 1st gear at 30 or 50 in 2nd gear.
Yes, put the car manually in what ever gear you want to go from and as soon as you floor it put it in auto mode or in the drive position and let it shift itself.
lt4camaro is offline   Reply With Quote
Old 05-14-2016, 08:55 PM   #8
SuperSound
SuperSound's Avatar
Yep that's the problem with it...too many variables. Which is why if that was a big deal to me, a shift light would solve those issue banging off the rev limiter. Trying to look at a analog tach down in a cluster when you are racing like that is never going to be that accurate, even if the tach doesn't have lag which not sure how good the one in the SS is.
Old 05-14-2016, 08:56 PM   #9
SuperSound
SuperSound's Avatar
Even better solution there. Didn't think of that.
Old 05-14-2016, 09:11 PM   #10
hotlap
hotlap's Avatar
I'm still within the breakin mileage so I haven't been able to play yet. I did ask a similar question regarding activating performance shift mode and was give this advice (below)
bybcous post a tunnel video of his car in performance shift mode that made me a A8 believer.
Originally Posted by bybcous View Post
Just press the button twice for competition mode and you can quickly rev your motor to get to performance shifting which i use when roll racing.
Stabilitrac/traction control button down by the driver mode selector.
Ronald Reagan -
Old 05-14-2016, 11:07 PM   #11
6th Gen SS
LT-Won!
6th Gen SS's Avatar
Drives: USB ISF 5.0
Did he say he was on the street.
6th Gen SS is offline   Reply With Quote
Old 05-14-2016, 11:12 PM   #12
Zeke.Malvo
Zeke.Malvo's Avatar
How many tracks have "roll races"?
Old 05-14-2016, 11:20 PM   #13
ULTRAZLS1
ULTRAZLS1's Avatar
They do them in certain places I've seen but not a regular drag strip. They look like air fields or something idk.
I do my roll racing in Mexico on long dark highways.
Old 05-14-2016, 11:33 PM   #14
6th Gen SS
LT-Won!
6th Gen SS's Avatar
Drives: USB ISF 5.0
Decommissioned (either perman.or temp. decom'd) airport runways are used for this.
Are you new to motor sports
http://shift-s3ctor.com/upcoming-events/
