Old 05-01-2016, 05:56 PM   #1
ender2664
Drives: 2016 2SS
Traction
For those with fi on their LT4...
If my traction control is off I can spin mid 1st even with a solid launch.
That being said I'd think adding this much additional power makes things difficult.
Did you put huge tires on? Do you not floor it in first? Just curious.
ender2664 is offline   Reply With Quote
Old 05-02-2016, 11:30 AM   #2
Tr6
The Dogfather
Drives: #1 off the line for a customer. '16
LT1 supercharged, will easily spin stock tires in 3rd maybe even 4th gear lol. 275 won't cut it and will need AT LEAST 305 rears. The 1LE and ZL1 (2017, new ones), rock 285/30/20 front, 305/30/20 rear for a reason haha. Plus the e-LSD which gen6 SS does NOT have which isn't a big deal on street use, but road course/autox it is good to have.
2SS, Garnet Red with Adrenalin red, NPP, MRC M6 coupe
#33 off the line #1 order for Customer.
Build thread HERE!
Story of my delivery HERE!
Tr6 is offline   Reply With Quote
Old 05-02-2016, 11:41 AM   #3
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Bigger Tires, Stickier tires...annnnnddd...
...practice.
Old 05-02-2016, 04:49 PM   #4
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
God, I was taking it easy and thought I would be fine, but he's right. I gave it a little more sauce today in 3rd and could feel it start to get a little loose back there. It's not that bad if you know when enough is enough, but keep in mind I basically have brand new tires on too.
After driving for 15 minutes on the highway I dropped to 4th to shoot around someone after letting them pass me in the middle lane. If you push it enough the same thing will happen. I was just kidding myself thinking I might be ok with these. You really have to be very conservative until you get wider tires. It only gets tougher as you pass the break-in and get more comfortable with the added power being there.
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge
93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno)
LesBaer is offline   Reply With Quote
Old 05-02-2016, 05:20 PM   #5
ender2664
Drives: 2016 2SS
I appreciate your honesty.
Can you please let me know how things go when you upgrade your tires?
Old 05-02-2016, 05:46 PM   #6
Tr6
The Dogfather
Thank you for the insight! While I do not have first hand experience as I don't have mine boosted but it's simple math! I am sure you can still drive just fine but just cannot slam the pedal to the metal because you will just spin! Which is still uber fun haha!
Build thread HERE!
Old 05-02-2016, 05:59 PM   #7
ender2664
Drives: 2016 2SS
I enjoy being able to press the gas pedal down all the way without being overly worried about spinning my car into on coming traffic.
I posted that statement in the general section and people told me not to get a SS, but I have experienced no such issues with it.
So I want to get a realistic idea of what to expect out of a boosted one, but it sounds so far that this MIGHT not be for me.
Old 05-02-2016, 07:18 PM   #8
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
Well I also should point out that the roads were damp when I left work today, as it had rained a little around 10-11am. If I had wider rubber, I don't think I would've noticed anything. It wasn't bad at all anyway, but I could feel it getting lighter back there and backed off. I also drove back (3 hour trip) in full-on rain on Sunday and had absolutely no issues at all - not even the slightest bit, and I was driving at the same rate as everyone else.
The rate of acceleration and sound is just intoxicating. There's absolutely no going back for me. You can get up to speed so quick, even with just the stock tires and not going WOT. When you realize how fast WOT would be, you just can't do that on public roads all the way up through 5th gear. I would probably be close to 100mph in 3rd before I redlined LOL.
If you can, go for a ride in someone's car first or test drive a Z06. I don't think it's as bad as you're thinking it is but it still might not be for you.
Old 05-04-2016, 12:12 PM   #9
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
While, I'm not driving a 6th gen, I will tell you that drag radials kept me from spinning at 110 mph in fourth gear. In fact even with 20 inch drag radials, the majority of my traction issues are solved. To further that, I would need to go to some 15,17,or 18 inch wheels.
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 05-04-2016, 12:26 PM   #10
Lucely Engineered
Lucely Engineered's Avatar
Drives: 2016 Camaro 2SS M6
If you're talking about daily driving a car "with that much power" it comes down to driver. If you can't control yourself and your car, you should not own a car like that. After all im pretty sure most of us are not Street Outlaws needing to put down all of the power on dirty streets.
As for the track is has to do with much more than tire width. People put down amazing times with a 275 drag radial, there is a whole class based on that tire. That said it has to do with tread, compound, suspension, track, width, sidewall, temp, psi, etc...
Lucely Engineered is offline   Reply With Quote
Old 05-04-2016, 12:42 PM   #11
1KillerSS
1KillerSS's Avatar
No offence here, but I dont care what kind of driver you are. You can't tell me that a good driver will keep from spinning their tires over a bad driver, if both of them are driving the same powered car, with their foot on the gas.
I will agree that a good driver can use his throttle better to keep them from spinning, but that's exactly what he is doing, feathering the throttle. When I go to the track, I want WOT all the way down the track. If I have to play with the throttle to keep from spinning my tires, then I'm not putting all the power that I can to the pavement.
And I couldn't agree more, its not always the wider tire that will give you the best traction.
Build thread
Old 05-04-2016, 12:58 PM   #12
Lucely Engineered
Thats what i was implying when i said control for the street. A good driver can control any spin, its no worse than driving a rwd car in winter. Thats also why i separated track use. If you want best track results, normally you have a different set of tires, because track oriented tires are not good on the street and vice versa.
Old 05-04-2016, 02:50 PM   #13
ender2664
Drives: 2016 2SS
I am not concerned about the track,this is my dd.
Old 05-04-2016, 07:05 PM   #14
1KillerSS
1KillerSS's Avatar
Drag radials will help big time on the street. My MT's only last about 5k to 7k miles, but the amount of traction I gain, without going to 17 inch wheels, is awesome.
Build thread
