Old 02-29-2016, 10:36 AM   #1
TSloper
Drives: 2016 Camaro SS
Dyno / 16 Camaro SS (A8, stock)
I had some baseline pulls done this morning. The three runs were almost identical with the last run being the best. I did log on the scanner if anyone is interested in that data. Thanks to Chris at RPM Motorsports! All runs were done in 5th gear. The AFR curve is based on a stoich of 14.7 rather than 14.11 but the lambdas follow pretty closely to what the commanded should be.
410.40 RWTQ
391.66 RWHP
TSloper is offline   Reply With Quote
Old 02-29-2016, 11:16 AM   #2
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
I need to find a dyno willing to take my car in 5th gear I have even seen runs in 6th gear. Looking good
Sledgehammer70 is offline   Reply With Quote
Old 02-29-2016, 11:31 AM   #3
TSloper
What is their issue with 5th? It isn't pushing the tires out of their rated speed.
Old 02-29-2016, 01:09 PM   #4
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Great numbers...
Old 02-29-2016, 02:42 PM   #5
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
Sledge can confirm, but I believe 5th is running the car above 150mph. 6th would go to 170+.
Old 02-29-2016, 07:39 PM   #6
Richie Carbone
Richie Carbone's Avatar
Drives: My work van for now
They don't want you to hit "LUDACRIS SPEED"
Richie Carbone is offline   Reply With Quote
Old 02-29-2016, 08:21 PM   #7
TSloper
PLONKER shouldn't you be over with the kids in the land yacht forum?
The SS tires are Y rated. The max speed on my runs was 151. I don't see why anyone would question a 5th gear pull.
Old 02-29-2016, 09:23 PM   #8
jimmypop13
Drives: 2016 camaro ss
14.11 because up to 10% ethanol in most gas right?
2016 camaro 2SS hyper blue/Kalahari, A8, MRC, NPP, sunroof, SW headers through axleback, Circle D 3600rpm TC, Pray ported IM/TB, E85
Sold: 2002 Z28, NBM, M6, 460rwhp, 2009 HHR SS
RIP : 2002 WS6 Black, A4, 355rwhp
jimmypop13 is offline   Reply With Quote
Old 02-29-2016, 09:25 PM   #9
TSloper
Yup
Old 02-29-2016, 09:40 PM   #10
jdasnt3
jdasnt3's Avatar
Drives: 18 Silverado 1500
Looks great! Got to be satisfied with that.
Old 03-01-2016, 05:20 AM   #11
laynlo15
Drives: 2022 Lt1 A10
Good numbers, so no pulls in 6th gear at all. That is 1.1 and that where you'd normally get accurate numbers
Old 03-01-2016, 07:20 AM   #12
TSloper
For my use I was just establishing a baseline for my car that I can repeat consistently as I make changes down the road. The SAE correction alone is at best an estimate.
391 RWHP @ 15% loss = 460
391 RWHP @ 14% loss = 454
I'd say it's close enough
Old 03-01-2016, 08:49 AM   #13
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
Serious question. Can someone explain why the LT1 is rated at the same amount of hp and tq but consistently seems to put more hp and less tq to the rear wheels? Is it because it was dynoed in 5th gear and 6th is 1:1?
Edit: As pointed out below, more TQ, not HP.
Eric SS is offline   Reply With Quote
Old 03-01-2016, 09:01 AM   #14
jdasnt3
jdasnt3's Avatar
More torque. The OP shows more torque than HP, and stock on a Mustang dyno we did 402 HP and 404 torque. Final numbers with a PTB and tune are in my signature.
