Old 02-21-2016, 10:21 AM   #1
Smithr66
Smithr66's Avatar
Drives: 2016 Camaro RS
Steering pull in both directions
I just got my car two days ago and I am loving it! However it seems like the steering is pulling to either side and there is a road noise coming from one of the tires. Does this sound like something an alignment would cure? Would an alignment be covered under warranty on a two day old car? Anyone else experiencing this?
Smithr66 is offline   Reply With Quote
Old 02-21-2016, 11:35 AM   #2
Smithr66
Smithr66's Avatar
After reading into it a little I reckon this could be the nature of wide 20in rims. This is the first car I've owned with 20's.
Old 02-21-2016, 11:46 AM   #3
bballr4567
Drives: 2016 Camaro 1LT M6
Well, it's not the 20" wheels but its the 245 wide tires.
Now, the car will "track" more obviously than some of your past cars and that could take some time getting used to. Drive it on a known good road without wheel lanes (the indentation on the road) and see what happens. It should slightly pull to the right.
bballr4567 is offline   Reply With Quote
Old 02-21-2016, 05:39 PM   #4
63falcondude
63falcondude's Avatar
Drives: 16 Camaro, 11 Stryker, 00 Explorer
Cars should not pull to the right.
NGM, 2SS, 6MT, NPP, MRC, Nav, Kalahari, Grey Wheels
1100 12/14/2015
3000 1/8/2016 (TPW 2/1)
3800 2/1/2016
5000 3/5/2016
63falcondude is offline   Reply With Quote
Old 02-21-2016, 05:43 PM   #5
bballr4567
Yes, they should. It should be built in to SLIGHTLY pull to the right. You can have it adjusted when you get an alignment though and most do.
They do that for safety reasons. Im talking about a VERY VERY VERY slight pull. You likely wont ever even notice it.
Old 02-21-2016, 06:24 PM   #6
63falcondude
News to me. Thought that was a rumor.
1100 12/14/2015
3800 2/1/2016
5000 3/5/2016
Old 02-21-2016, 06:28 PM   #7
bballr4567
Friend has worked at the best alignment shop here in town. They get a lot of complaints from people when they get the alignment done with it pulling so slow to the right. If they want it straight, gotta ask for it.
Old 02-21-2016, 07:39 PM   #8
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
On a crowned road, your car will eventually move to the right.
Old 02-21-2016, 07:53 PM   #9
laynlo15
Drives: 2022 Lt1 A10
Mine does not pull in either direction, drives perfectly straight. Try it in the track mode. It could also have a low tire. We have customers come in all the time thinking their alignment is out but its sometimes a low tires. If your is pulling in both directions that could be the road your driving on. GM has had some rack and pinion issue on the new Camaro also, remember its electric steering, no PS pump in these cars.
Old 02-21-2016, 07:55 PM   #10
MiamiBlueCamaro
MiamiBlueCamaro's Avatar
Drives: Gen 6 Camaro RS
Check your tire pressure
Old 02-21-2016, 08:17 PM   #11
Smithr66
Smithr66's Avatar
Tire pressure is the first thing I looked at. All in range. There are a lot of semi trucks on i71, thats where I noticed it pull. Could just be the road. The road noise is what caught my attention more than anything, but like I said this could just be the nature of large rims and low profile tires. Haven't driven a car like this in ten years.
Old 02-21-2016, 09:15 PM   #12
63falcondude
Exactly.
1100 12/14/2015
3800 2/1/2016
5000 3/5/2016
