Old 01-24-2016, 01:51 PM   #1
chris227
chris227's Avatar
electrical issue
I have a 2lt v6 and was changing out the trunk bulb and it made a arc inserting the bulb. now my trunk light as well as my front left turn signal, and my rear right turn signal/brake light no longer work. lights hyper flash to tell me theirs a bulb issue, but no warning on the info screen. anyone have any possible insight into this?
Old 01-24-2016, 01:53 PM   #2
dreamingat30fps
Drives: 2016 2SS
Fuse?
dreamingat30fps is offline   Reply With Quote
Old 01-24-2016, 01:55 PM   #3
chris227
chris227's Avatar
Originally Posted by dreamingat30fps View Post
Fuse?
cant find no fuse at all, and if its like the 5th gens it should reset itself after a minute or 2 on the trunk light at least. The turn signal issue is odd, never seen that before.
Old 01-24-2016, 01:59 PM   #4
GTIanZ28
Drives: 2016 V6 RS Camaro 6MT
Fuse box is in the engine compartment. Definitely sounds like a blown fuse.
Summit White 2LT RS V6 ZN2 NPP m6 khalihari interior. Order placed 9/26/15 - Picked up 12/17/15!
GTIanZ28 is offline   Reply With Quote
Old 01-24-2016, 02:00 PM   #5
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Absolutely, I've done this before and it was always a fuse
Old 01-24-2016, 02:02 PM   #6
chris227
chris227's Avatar
Im checking everyone right now.
Old 01-24-2016, 02:09 PM   #7
chris227
chris227's Avatar
OK..Found it, it was a fuse of course it was the 2nd to the last one to check. Thanks
F-46 BCM7 was the fuse. was a 10. whew...started to panic. was really odd to me.
Old 01-24-2016, 03:10 PM   #8
GTIanZ28
If you look at the underside of the lid there is a diagram that shows all the fuses. You shouldn't have needed to pull them all.
Glad that was all it was
Old 01-24-2016, 03:30 PM   #9
chris227
chris227's Avatar
It was bcm7 fuse. Am I supposed to know that's the turn signal fuse? The label has no info related to tailights.
Old 01-24-2016, 04:23 PM   #10
GTIanZ28
Nope no way to know that.
Old 01-25-2016, 08:58 AM   #11
C5Txfan
C5Txfan's Avatar
Drives: 2004 Corvette
Trunk light out already ??
C5Txfan is offline   Reply With Quote
Old 01-25-2016, 09:21 AM   #12
63falcondude
63falcondude's Avatar
Drives: 16 Camaro, 11 Stryker, 00 Explorer
I never unplug the battery for simple stuff such as this but that probably would have avoided this issue. 20/20 hindsight here.
NGM, 2SS, 6MT, NPP, MRC, Nav, Kalahari, Grey Wheels
1100 12/14/2015
3000 1/8/2016 (TPW 2/1)
3800 2/1/2016
5000 3/5/2016
63falcondude is offline   Reply With Quote
Old 01-25-2016, 09:46 AM   #13
jdasnt3
jdasnt3's Avatar
Drives: 18 Silverado 1500
Were you changing the bulb to LED, or did the bulb already fail and you were putting a new incandescent in?
Old 01-25-2016, 10:02 AM   #14
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
it happens when the LED arcs while putting it in...if you arc, you probably will blow the fuse...
