Old 12-22-2015, 10:17 PM   #1
SkipNWis
SkipNWis's Avatar
Drives: 2016/SS Has had 4 Gen 5's
Question tire size?
Anybody know what tire size is the Biggest you can go front and Rear. I was running 20" 315's in the rear> Please PM with anything you Know What's the biggest tire size you can get front and rear? and stay with the Stock Black rims ?????
SkipNWis is offline   Reply With Quote
Old 12-22-2015, 10:57 PM   #2
08z51c6
Drives: 2016 Camaro SS - A8, MRC, NPP
The stock wheel size are 20X8.5 and 20X9.5 inches. I personally wouldn't try and run a 315 series tire on a 9.5 inch wheel. The widest I would go is a 285 or possibly a 295 but even that's pushing the limits. Tirerack recommends a min rim width of 10.5 inches for a 315 tire.
08z51c6 is offline   Reply With Quote
Old 12-22-2015, 11:44 PM   #3
BrianInJackson
Drives: toyota mr2
A 255/40 front and 285/35 "should fit". Can't see why it wouldn't. Not sure if stock offsets will allow for the extra 5mm on each side. Once again, can't imagine not fitting. Going any bigger than that and it's time for new rims. I would suggest a stickier tire for extra traction before trying to go wider than that without new wheels. We are all in the learning phase on what works. Good luck.
BrianInJackson is offline   Reply With Quote
Old 12-23-2015, 04:47 AM   #4
GhostEye07
GhostEye07's Avatar
Drives: '16 Camaro 2LT RS
Currently have on (no issues)
315/35 R20 20x11 in the Rear
275/40/R20 20x10 in the front
Tried on Pirelli P Zero
305/35 R20 20x11 had an issue with the driver side rear tire causing contact with the carpet. Looks like there is a small carpet bulge for a cable.
2016 Camaro 2LT RS E85 V6
Build Thread | My Instagram
GhostEye07 is offline   Reply With Quote
Old 12-23-2015, 09:01 AM   #5
lDejavul
lDejavul's Avatar
Drives: Camaro SS
So the 315 fits fine but the 305 rubbed?
Kooks ceramic coated headers -1 7/8 in. x 3 in
Pray ported 95MM TB
Pray ported MSD IM
Rotofab CAI
BTR 225 CAM
PRC 312 CC Ported Heads
Katech Oil Pump
DSX Flex Fuel E-85 kit
QTP exhaust cutouts
Full JLAudio Stereo Build w/ 13-W6
lDejavul is offline   Reply With Quote
Old 12-25-2015, 01:13 PM   #6
laynlo15
Drives: 2022 Lt1 A10
If your going to lower it you should stay in the 285 area on a 9.5 or a 10 so you can tuck it. I'll be doing the bmr 1.2 on mine like I have on my 15ss, but probably will do a 40 series in the rear, don't really like the short side wall and 35 series up front.. Really won't know till I get my 16 hear and I'll order in a couple of sets of wheels and tires at work to figure out the best set up. I'll lower it first and then wheels and tires. I'll tuck the biggest I can without any rubbing. Since I sell custom wheels and tires for a living it makes it a little easier for me to get it done.
Old 12-28-2015, 03:10 AM   #7
GhostEye07
GhostEye07's Avatar
Yes its a little weird my guess is, because the Pirelli are a little bit different than the 315 acceleras tires i had on
Old 12-28-2015, 10:10 AM   #8
chuckclanton
Drives: 2021 Camaro 2LT
Why do you want wider tires? If it is for better handling you need
wider wheels. Even going 10mm wider on the tires distorts the tire sidewall
in the wrong direction! The stock tire size is optimum for the wheel widths.
If for inline traction maybe a 10mm wider tire in the rear might help.
chuckclanton is offline   Reply With Quote
Old 11-30-2016, 12:02 AM   #9
Scorch9890
Drives: P1SC @8psi Stage 2 intercooler 8SP
I'm having the same issue here. I have 20x10s in the rear and it looks like I can't find a size they make for drag radials that fit these wheel wells. Why the hell are the gen 6 wheel wells so small. Chevy should have expected a car like this to be used at the drag strip... Another issue I have is why is the gearing so low? What can I do to make a 305/35 fit or hell even a 275/40
Scorch9890 is offline   Reply With Quote
Old 08-22-2017, 11:09 AM   #10
EddieM92
Instagram- _2sslow_
EddieM92's Avatar
I'm looking at the Mickey street ss 295/65r15 for my 16 Camaro SS would those fit ????
Instagram- _2sslow_
2011 Camaro LT RS (Sold)
2011 Range Rover Sport HSE (Sold)
2016 Camaro 2SS NPP, TSP headers & Xpipe, Skid e85, CAI Intake, MSD IM, 95m TB, BigPowerRacing Tune, H&R Lowering springs, BMR sway bars
EddieM92 is offline   Reply With Quote
