Old 10-26-2015, 06:04 AM   #1
GMGP5X
GMGP5X's Avatar
Drives: 2011 2LT RS VR 2008 Silverado 2500
NPP Cut away photos
NPP muffler does not look as large as it does on photos I have seen on the car.
2LT RS VR / ARK DTS Cat back exhaust / Roto-Fab CAI / RPI stealth mud guards /Defender works billet chrome door sills/ DIY painted engine cover, trunk corners, and brake rotors / RX catch can / Team LLT badges. Team LLT
GMGP5X is offline   Reply With Quote
Old 10-26-2015, 09:36 AM   #2
MaximumHP
Drives: 06 GTO
hmm, interesting. It is pretty much straight through when the valve is open. when closed the exhaust must have to go through the perforations, into the center section through that pipe and then who knows what and eventually out through the other tip, that's a convoluted path.
MaximumHP is offline   Reply With Quote
Old 10-26-2015, 02:27 PM   #3
rotis
rotis's Avatar
Drives: 2019 ZL1 1LE
Oh, wow. I'm kinda shocked at what it looks like inside. I can't believe the exhaust has to go through those perforations when the valves are closed. That explains why the manual says not to do any track driving with the exhaust in 'stealth' mode.
rotis is offline   Reply With Quote
Old 10-27-2015, 02:39 AM   #4
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
Interesting way to accomplish what they are doing.
Sledgehammer70 is offline   Reply With Quote
Old 10-27-2015, 09:37 AM   #5
Denis
Denis's Avatar
Drives: 2010 SS
oh wow....im wondering how restrictive that will be when the butterfly is closed. seems like there is going to be a jump in power between stealth mode and track mode.
Denis is offline   Reply With Quote
Old 10-27-2015, 09:52 AM   #6
joemosfet
joemosfet's Avatar
Drives: 2014 Camaro SS
I really doubt it. If there is, it will be negligible, and you won't feel it. I doubt it would even show itself in a 1/4 mile.
SOLD: 2014 Camaro Coupe 2SS/RS M6 Blue Ray Metallic, NPP, Nav
2014 Stingray Premiere Edition Coupe #142/500 Z51 3LT M7 Laguna Blue, Magride, NPP, Exposed Carbon Fiber Roof, Carbon Fiber Dash, Suede Wrapped Interior
Canceled: 2016 Camaro Coupe 1AK37 2SS Coupe, G7E Garnet Red, BRJ Adrenaline Red Trim, F55 Magnetic Ride, NPP Exhaust, CF5 Sunroof, 56R Gray Split spoke w/ machined face, RN2 LPO Illuminated Bowtie, VYW Premium Floor Mats, W2D LPO Cargo Net
joemosfet is offline   Reply With Quote
Old 10-28-2015, 08:45 AM   #7
NASTY99Z28
Drives: 99z28 with bolt-ons and a mwc fab 9
Most aftermarket mufflers can varry between 5-10hp. After seeing this its hard to believe that you can't feel or see the difference between wide open and a few poked holes!!!!
I like my woman like my milk shakes, THICK!!!!
NASTY99Z28 is offline   Reply With Quote
Old 10-28-2015, 11:00 AM   #8
LesserO2Evils
GM repeat offender...
Drives: 16 2SS
That is quite the interesting design. Nothing like what I envisioned in my mind.
'16 2SS, Summit White. A8. MRC. NPP.
Ordered:09/03/15. Received 12/22/15
INCOMING: ‘22 ZL1, Satin Steel. A10. PDR.
Ordered: 03/02/22.
LesserO2Evils is offline   Reply With Quote
Old 10-28-2015, 11:46 AM   #9
Curr
Probably doesn't like you
Curr's Avatar
Drives: 2022 WCT ZL1 M6
That is complete unlike what I thought it looked like on the inside. Great post, thanks.
Love that it's a flat out muffler bypass open! Hells yes.
كافر
ΜΟΛΩΝ ΛΑΒΕ
железобетонное очко
Quod gratis asseritur, gratis negatur.
There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly.
Curr is offline   Reply With Quote
Old 10-28-2015, 12:49 PM   #10
DenverTaco07
DenverTaco07's Avatar
cool thanks! They should put an adobe flash illustration together, so we can see the flow.
I sort of get it (maybe?), when the flap is closed exhaust fills the void (all chambers) before escaping and obviously no exhaust exits via the outer two tips, when open the path of least resistance is the outer tips and seems to me that the majority of exhaust would then flow through the outer tips.
anyway, someone smarter than me please chime in.
Old 10-28-2015, 01:28 PM   #11
Geno
Drives: 2013 Hyundai Genesis Coupe GT
Any pictures of the stock, non NPP muffler inside? It would seem to me that design with pin holes would create terrible back pressure. I wonder if the standard muffler is engineered like that????
Geno is offline   Reply With Quote
Old 10-28-2015, 02:14 PM   #12
KMPrenger
KMPrenger's Avatar
Very interesting!
When closed, the exhaust comes out the perforated holes, into the wide open muffler space, and has to find its way out of that exhaust hole which routes to the pipe that comes out on the opposite side of the can.
Wow.
When open...it is pretty much straight through.
I would be a bit shocked of the NPP closed versus open isn't good for 5 - 10 HP.
Begs the question, do we get 455 HP at closed, or at full open (or maybe something inbetween? lol)
Old 10-28-2015, 02:24 PM   #13
DenverTaco07
Originally Posted by KMPrenger View Post
Very interesting!
But straight through dual exhaust...mostly, would you agree? I mean it's not straight thru quad exhaust although i'm sure some of the exhaust when wide open would still leak through the perforated holes and then find itself back out as you described, but my guess is that wide open 80 or 90% of the exhaust travels through the outer tips.
I admit I'm guessing based on no real knowledge on the issue though.
Old 10-28-2015, 02:47 PM   #14
joemosfet
joemosfet's Avatar
It is my opinion that the amount of flow between closed and open is negligible. The upstream catalytic converters are much more of a flow restrictor than the perforated and rerouted exhaust.
The picture doesn't really do it much justice, but I think if you were to see this in person, you would see that the path of flow, while convoluted, is still extremely free flowing. The amount of surface area provided by the perforated holes, when all added up, is likely near or even over the 2.5pi (assuming they're 2.5" pipes).
As free flowing as when the cutouts are open? No. Does it make a difference in power? Negligible. Maybe at high rpms the difference would show up on a dyno.
Now, of course all of my speculation is based on experience with several different exhaust systems, as well as knowledge about fluid dynamics, so I could be completely wrong. And, if they were to fill the empty spaces in the muffler with rockwool or fiberglass (often used to increase sound dampening capabilities) my opinion might be a bit different.
