Old 09-29-2015, 08:06 PM   #1
2000Firehawk
Drives: 2000Firehawk
Aaron Link - Lead Development Engineer - Gen6
Interesting fact, from an article in HotRod magazine:
We asked about any special engineering for the LT1 in the Camaro and Link pointed to the air/oil separator as, “an unsung hero of the car. We developed a legit air/oil separator for the LT1. That was near and dear to my heart. I spent a lot of time on that one.” As all Camaro LT1s will be wet-sump engines, Link told us the air/oil separator is cleverly packaged, so it’s hard to appreciate in the car. Its function is to keep oil out of the airbox and throttle-body—and therefore the combustion chamber—avoiding pre-ignition.
Cool...
A Big DI problem, that has been solved...
This has always been a problem, with the GM 2.0T DI engine
Hopefully this engineering feat, has been applied to the 2.0 T & the 3.6 V6
2000Firehawk is offline   Reply With Quote
Old 09-29-2015, 08:15 PM   #2
DenverTaco07
DenverTaco07's Avatar
to quote my 2 year old son - "it's Pretty Cool!"
Old 09-29-2015, 08:17 PM   #3
whiteboyblues2001
whiteboyblues2001's Avatar
Hopefully it will work as advertised. I believe the new system is integrated under the valve covers. I also hope that if it doesn't work good enough, that a catch-can can still be installed easily enough. Otherwise, I would suggest Seafoam.
whiteboyblues2001 is offline   Reply With Quote
Old 09-30-2015, 04:50 AM   #4
Curr
Probably doesn't like you
Curr's Avatar
Drives: 2022 WCT ZL1 M6
Yup, long time wrench turning buddy of mine suggested a couple tablespoons per tank of gas.
كافر
ΜΟΛΩΝ ΛΑΒΕ
железобетонное очко
Quod gratis asseritur, gratis negatur.
There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly.
Curr is offline   Reply With Quote
Old 09-30-2015, 05:14 AM   #5
GMGP5X
GMGP5X's Avatar
Drives: 2011 2LT RS VR 2008 Silverado 2500
Sea foam is great but with D.I. it will not help the intake system.
2LT RS VR / ARK DTS Cat back exhaust / Roto-Fab CAI / RPI stealth mud guards /Defender works billet chrome door sills/ DIY painted engine cover, trunk corners, and brake rotors / RX catch can / Team LLT badges. Team LLT
GMGP5X is offline   Reply With Quote
Old 09-30-2015, 08:22 AM   #6
joemosfet
joemosfet's Avatar
Drives: 2014 Camaro SS
'Vettes have had DI for a couple of years now, do they also have the same separator system and, if so, are there reports of oil in the intake indicating a catch can is still necessary?
SOLD: 2014 Camaro Coupe 2SS/RS M6 Blue Ray Metallic, NPP, Nav
2014 Stingray Premiere Edition Coupe #142/500 Z51 3LT M7 Laguna Blue, Magride, NPP, Exposed Carbon Fiber Roof, Carbon Fiber Dash, Suede Wrapped Interior
Canceled: 2016 Camaro Coupe 1AK37 2SS Coupe, G7E Garnet Red, BRJ Adrenaline Red Trim, F55 Magnetic Ride, NPP Exhaust, CF5 Sunroof, 56R Gray Split spoke w/ machined face, RN2 LPO Illuminated Bowtie, VYW Premium Floor Mats, W2D LPO Cargo Net
joemosfet is offline   Reply With Quote
Old 09-30-2015, 08:26 AM   #7
IOMike
Drives: 2022 F150, 87 Monte Carlo
They do not have the separator system. Not sure if they're having issues or not though.
IOMike is offline   Reply With Quote
Old 09-30-2015, 08:42 AM   #8
Ragnar
Destroyed by flooding
Ragnar's Avatar
Drives: Wife's car
This was a C7 with 5500 miles on the clock!
https://www.youtube.com/watch?featur...&v=7Pz0zTQ1bz0
Old 09-30-2015, 09:06 AM   #9
Stex
Drives: 67 goat, 69 goat ram air III
Solved? I think GM s first attempt may not be all as claimed. I would still run a catch can.
My third year AFM on my 5.3 was revised but still screwed the rings and burns oil. I do not trust GM engineering tell I see it is working 50,000 miles out.
As noted above, Vettes have issues requiring regular cleaning with BG etc...
Stex is offline   Reply With Quote
Old 09-30-2015, 09:09 AM   #10
joemosfet
joemosfet's Avatar
Well, catch can it is. Does a catch can handle both sides of the engine, or do people normally run two catch cans?
Old 09-30-2015, 09:10 AM   #11
mt3130
Drives: Coupeless :(
I read somewhere that Audi is now using direct and port injection to reduce engine emissions, but it helps with this issue as well.
mt3130 is offline   Reply With Quote
Old 09-30-2015, 09:27 AM   #12
Memphis43
Memphis43's Avatar
Drives: Chevy
Same as toyota I believe. I am hoping that everyone moves toward that that is using di.
Memphis43 is offline   Reply With Quote
Old 09-30-2015, 09:55 AM   #13
Ragnar
Ragnar's Avatar
Drives: Wife's car
On your car there is a clean side and dirty side.
Old 09-30-2015, 10:16 AM   #14
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
With DI you want to run top tier fuel, preferably premium, good, fully synthetic oil, and I would run a catch can. On most engines, the passenger side is where you would want it...
